Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. dirt t
    dirt t
    Subscribe
  2. 340HilbornDuster
    340HilbornDuster
    Sorry it's getting out a hand....
    Did some more research...
    Lucas Replacement Wiring Harness Smoke kit, P/N 530433, along with the very rare Churchill Tool 18G548BS adapter tube ...
    The IBM smoke canister may refresh my old CPU's
    One for the road...
    Sent from my SM-G930T using The H.A.M.B. mobile app
    VANDENPLAS, OahuEli, brEad and 2 others like this.
  3. 1-SHOT
    1-SHOT
    from Denton
    Some times a little laughter is the best .
    OahuEli and loudbang like this.
  4. 340HilbornDuster
    340HilbornDuster
    Some Bling paint (to protect the metal) till i can afford / find a good chrome shop to have them re-chromed.
    CPU's landed today...fix up Ol' Smokey again...
    Bought Diodes @ Manfreds (Ind.Elec.) today! 20190114_190741.jpeg 20190114_190715.jpeg 20190114_190528.jpeg
    Sent from my SM-G930V using The H.A.M.B. mobile app
    OahuEli, brEad, Dannerr and 4 others like this.
  5. loudbang
    I like the gold stacks. :)
    Stogy and 1-SHOT like this.
  6. 1-SHOT
    1-SHOT
    from Denton
    Gold Stacks are good.
  7. 340HilbornDuster
    340HilbornDuster
    SO, I was going "a little overboard" with the Squirt stuff!
    I was requested by admin to remove it (& I DO RESPECT THAT!!)..
    I Really Appreciate the heads up and TOTALLY AGREE!
    Thanks for keeping my Build Post up!!...
    Just a small part of my project and I'm trying hard to keep a Traditional
    appearance...
    YOU GUYS! THANKS FOR YOUR SUPPORT!
    Gives me spark when i feel like chillin' in the hammock!
    WIRING:
    With the wiring gremlins I've had...
    I decided to take the Back Board and Dash out...
    Redo / clean up all the FU'd wiring, from redoing the relays 3x.
    Get rid of those Chinese Relays.
    New fuse block! gl*** fuses would probably have fallen out at first pot hole.
    Upgrade with some "electric check valves".
    Looking for a military quick connector with enough pins for the dash...
    Everything's so crammed in there it would help when trouble shooting in the future!
    Move Spark away from sensitive equipment.
    etc. etc. etc.
  8. 340HilbornDuster
    340HilbornDuster
    OT?......lesson learned....
    this is what happens when you rush it
    this thing was living in there...
    Didn't need to remove the body harness connector..but it works!
  9. 340HilbornDuster
    340HilbornDuster
    New fuse / relay box.
    5 relays 10 fuses
    Hide some wires behind the board.
    brEad, loudbang and AndersF like this.
  10. 1-SHOT
    1-SHOT
    from Denton
    Where did you get the fuse box ?
  11. 340HilbornDuster
    340HilbornDuster
    E-bay...
    Search for
    Bussmann RTMR 15303-5 waterproof fuse panel.
    There's a bunch of different versions....relays....research...!
  12. 340HilbornDuster
    340HilbornDuster
    different versions
    Up to 30 amp relays you can fit 5
  13. 1-SHOT
    1-SHOT
    from Denton
    Thanks, Frank
  14. 340HilbornDuster
    340HilbornDuster
    It's a little pricey paid 90 bucks for mine with all the connectors and 5 30A relays.
    But is really compact and good quality
  15. 1-SHOT
    1-SHOT
    from Denton
    That's really not a bad price. Did you get Mike Sierra working?
  16. brEad
    brEad
    Looking forward to seeing more on the wiring!
  17. 340HilbornDuster
    340HilbornDuster
    Mike Sierra got a new. Charlie Papa Uniform.
    Works great.
    Just have to fix the Gremlins in the wiring and get the coil away from the wiring harness
    Stogy, OahuEli, Dannerr and 1 other person like this.
  18. loudbang
    Wow so much power "what's the frequency Kenneth?" :)
    Stogy and OahuEli like this.
  19. 340HilbornDuster
    340HilbornDuster
    Dash - Refresh paint.
    + Holes for indicator lights.
  20. OahuEli
    OahuEli
    from Hawaii
    Man that's wiring is some scary looking stuff! At least you got the smoke kit working but is it calibrated? Trying to put smoke back into a 22 AWG wire when your settings are on 10 AWG wire can create real problems.:rolleyes::D
    loudbang and Dannerr like this.
  21. 340HilbornDuster
    340HilbornDuster
    Painted Dash / Cowl support & steering column...couldn't reach before...
    Soldered a piece of copper tubing to the horn wire...made a bushing from a screw driver handle.
    "Quick Remove Steering Wheel Horn Connector." 20190303_145154.jpeg 20190303_143858.jpeg 20190303_143933.jpeg
    brEad, AndersF, loudbang and 2 others like this.
  22. 340HilbornDuster
    340HilbornDuster
    Not period correct....but with everything crammed in there it's a Great Space Saver ..
    And those $#!+ relays are gone. 20190305_163743.jpeg 20190305_163854.jpeg 20190305_171123.jpeg
  23. 340HilbornDuster
    340HilbornDuster
    New fix required...
    Put the terminal strip on...
    Screws Facing DOWN!? Wasn't a problem when I attached the harness on the table
    Some ***** used the bracket that was on it...PITA to terminate...upside down...!
  24. Stogy
    Stogy
    I know very little of these wiring dilemmas but applaud your conviction to finding the solutions on your own...this is a form of plateau in the build...I am confident you will hang glide off the end of that with your solution...;)
  25. 340HilbornDuster
    340HilbornDuster
    Dash board quick connector...
    Testing the pins.
    Had to redo first connector 9-10 had some solder between 'em...argh! 20190313_185703.jpeg 20190313_201008.jpeg 20190313_203712.jpeg 20190314_180321.jpeg
  26. 340HilbornDuster
    340HilbornDuster
    Spent a day making these tiny little brackets... Now some paint so they don't rust...
    Kinda F1 inspired...lower radius is longer...creates down force at high speeds...................................................................................(I'm just kiddin!) 20190413_181704.jpeg 20190414_120727.jpeg 20190414_135634_002.jpeg 20190414_143733.jpeg 20190414_152315.jpeg 20190414_152331.jpeg 20190414_164151.jpeg
    OahuEli, USMercUte, patmanta and 4 others like this.
  27. loudbang
    If you flip them over will they help you do a wheelie :rolleyes:
    OahuEli likes this.
  28. 340HilbornDuster
    340HilbornDuster
    Finished the other Dash connector last night..... Real PITA! 20190417_213054.jpeg
    OahuEli, brEad, loudbang and 2 others like this.
  29. loudbang
  30. 340HilbornDuster
    340HilbornDuster
    That IS Plug to Plug...(only One!)
    I ŦƱƈĶȜƉ ÜƤ the first female connector trying to de-solder and re-doing it...
    (I probably don't have the right Soldering Iron for this job...
    Had to hit it with a Propane torch to melt the solder...)
    PITA!..But it's done!...Onwards and Forwards!
    nunattax and brEad like this.
