Technical What should I cast?
Discussion in 'The Hokey Ass Message Board' started by flathead 37, Jan 2, 2019.
  1. I need A COOL BAT logo Hood size My modified is called THE BAT so........? Br*** or bronze
  2. 56sedandelivery
    56sedandelivery
    Dang, forget about the carb scoops; that HEMI, will do do more than ******, ******, or any crane company, ever could! I am Butch/56sedandelivery.
  3. willys36
    willys36
    Here are a couple castings I made over the years. Necessity is mother of invention! How about making various styles of valve cover breathers? Really popular but very few are made, most are not vintage looking with logos on them. And vintage ones on ebaY cost the national debt.
    Made this faux Hilborn injector to make my Willy look like it has a blown hemi.
    Cast this 180deg, equal runner length 4bbl manifold for the 230 series Chevy straight 6s.
  4. BJR
    BJR
    How about some cool finned valve covers for big block 472 and 500 Cadillac engines?
  5. oliver westlund
    oliver westlund
    is there any reason i cant sand cast finned valve covers for my 394? i guess im asking if theres something i should watch out for? i was thinking id take the stock ones off and add fins with foam or something then create my sand mold off of that...should work right??
  6. TWKundrat
    TWKundrat
    First off the stock valve covers would be too thin of a cross section for cast aluminum covers. Also with the shrinkage of the casting you'd probably run into issues with the fit. Not that you couldn't start with stock valve covers as patterns but by the time you build up the extra material you need and add all the draft angles and fillets so the patterns can be removed from the mold, you probably would be better off starting from scratch.
    oliver westlund likes this.
  7. oliver westlund
    oliver westlund
    roger that! thats why i asked first! i just looked up offenhausers and theyre 360+ bucks and take 7 months to get em. plus having one off covers would be sweet. sounds tricky though
    https://www.jalopyjournal.com/forum/threads/47-coupe-build.1133545/
  8. oliver westlund
    oliver westlund
  9. TWKundrat
    TWKundrat
    A good read for some really basic beginner foundry work is Dave Gingery's "The Charcoal Foundry" book. Used to be sold through Lindsay Books but unfortunately they're not around any more. I'm sure it's still available though. The book tells how to get started on the cheap and sticks to the super basic principles of foundry work as to not overwhelm or discourage a beginner.
  10. bchctybob
    bchctybob
    You could recreate the old Hildebrandt starter switch-overs for 303-394 Oldsmobiles. It replaces the bottom of the Olds bellhousing and moves the starter to the p***enger's side for steering box clearance. The casting looks easy enough but the machine work would have to be pretty accurate.
  11. TWKundrat
    TWKundrat
    I actually just bought one of those two days ago and I was thinking it didn't look too difficult to cast. The machining is pretty basic too.
  12. oliver westlund
    oliver westlund
    sign me up for one if you can get it to work! i was just looking at my lack of space in my 47 haha
  13. milo1303s
    milo1303s
    Aspell that brings us all back in time !!! LOL
  14. rustymetal
    rustymetal
    368 Lincoln 3 or 2 intake
    blue57ford likes this.
  15. TWKundrat
    TWKundrat
    If I didn't have a thousand other projects in the works I'd probably give it a go, but I don't think it'll happen any time soon.
  16. flathead 37
    flathead 37
    Just completed my first prototype print of what i would like to cast first. A finned carb scoop of my design. Next i am going to print the actual pattern itself. 20190127_141348.jpg 20190127_141413.jpg 20190127_141423.jpg
  17. flathead 37
    flathead 37
  18. 51 mercules
    51 mercules
    Halibrand 101 Quick changes.
    IronTrap likes this.
  19. Rocky
    Rocky
    Classified Editor
    I've seen finned aluminum valley covers for Buick nailheads, big block mopars and I think Y-block fords but I've yet to see one for a Pontiac V/8. That's what I'd like to see.
    classiccarjack likes this.
  20. classiccarjack
    classiccarjack
  21. Commodoreswab
    Commodoreswab
    from West TN
    DSC01318 (2).JPG IMG_20150505_072641.jpg DSC01319.JPG Mortar1.jpg If you want something to strive for heads for a Zephyr, they run around 4k for a pair. I have done a bit of casting and when I get settled in TN in a couple years I will be building my foundry geared more towards bronze. My background is more in casting cannons and larger pieces so I want something where I can pour 2-400 pounds of bronze. Yes, I have dealt with numbers like this before.
  22. mopacltd
    mopacltd
    Are you using a wood mold casting?
  23. jazz1
    jazz1
    Lots of good ideas but for sure start small. Personalized gearshift handle for your ride. Valve covers with a silhouette of your ride for project #2
  24. Commodoreswab
    Commodoreswab
    from West TN
    What are the size limits on what you can prototype?
  25. CNC-Dude
    CNC-Dude
    There is someone on the Fordsix forum that is supposed to be pulling that project off.
  26. 348/409 valve covers in the style of Cal Customs and/or Weiand :D
  27. Bert Kollar
    Bert Kollar
    How about some retro taillights like Packard we could use a change from early Chevy lights
  28. 48fordnut
    48fordnut
    I would be interested in a deco dash panel for 2 5/8 gauges with a place for a 3 3/8 speedometer.
    This is something not made.
    Good luck,
    jim
  29. LSJUNIPER
    LSJUNIPER
    from ct
  30. 56don
    56don
    If I am not mistaken, I think Moon has some of those. I saw some somewhere when I was rounding up parts for my 348 but I am not sure where it was. I decided to wait until later to buy some.
