Technical New hemi owner
Discussion in 'Traditional Hot Rods' started by Omarsvette, Oct 31, 2018.
  1. 34Larry
    34Larry
    Not sure if this will help but this is what I put in my 34. Not being as well informed as are many of the guys replying to you here, I have no idea what this is in terms of numbers and all. I bought the engine/trans as a package and was happy to just get one. The weld on the bellhousing is because it fell off a jack stand while positioning where it needed to go. ( I stood up, walked over, turned off the lights and left for the rest of the day.) The worst part is that that bellhousing is so wide inside that small space that it was a challenge to get the accelerator positioned.
    Moderators: I know I'm trespassing on the site with this shot because of being non-triditioal, excuse me but just thought I'd give "Omarsvette" a hand here with what I had no help with when blindly rushing into a build I had no help or expertise in.
    Dog_Patch likes this.
  2. Omarsvette
    Omarsvette
    from Arizona
    Thanks looks cool, that’s a flathead?
  3. Omarsvette
    Omarsvette
    from Arizona
    5B92F980-D0B8-47F3-B31E-7FABA04823C4.jpeg Does anyone know what this cut off rubber hose is for? It’s on the passenger side, water?
  4. slayer
    slayer
    heater hose.
  5. Omarsvette
    Omarsvette
    from Arizona
    Thanks, I can just plug it since in not using a heater
  6. 34Larry
    34Larry
    :confused:? yep flat as can be
    Bandit Billy likes this.
  7. 34Larry
    34Larry
  8. Atwater Mike
    Atwater Mike
    A guy came over and saw my 354 Chrysler hemi with the heads off, asked the same question. "Flathead, right?"
    We went out back to the other shop, and he asked about my DeSoto hemi, heads off. "Flathead, little one. V8 60?"
    I was gonna take him out to lunch, but he was already there!
  9. Atwater Mike
    Atwater Mike
    My 276" DeSoto has a cast 2 bbl intake. If anyone has seen these old 2 bbl intakes, they will see that there is ONE casting for both 2 & 4 bbls, just the holes and bolt bores are designated. Lots of room on the 'pad'...I'm going to open the 2 bores up to accommodate a nice 650 Holley 4 bbl. At least until I find a used 4 jugger...
    @34Larry, your Chrysler hemi is beautiful.
  10. Omarsvette
    Omarsvette
    from Arizona
    lol yeah i just made a fool of myself!!
  11. Omarsvette
    Omarsvette
    from Arizona
    cut me some slack, im new to hemi world. us chevy guys are pretty basic haha, 34larry love the valve covers. thats in my plan. im also considering a dual intake.
  12. I used the Hot Heads adapter (it cam with a bunch of parts I bought) and a 46rh trans out of a early 90 dodge that had a 318.
    Hot Heads also has an adapter for the small block chev bigger choice and easery to find.turbo 350,th400,2004r,7004r,4l60,power glide.
    Mine in 63 f100 with 46rh and lots of money
    Dog_Patch and Bandit Billy like this.
  13. [​IMG]
    Hot Heads adapter for a th350......this is a 1954, 331
  14. Omarsvette
    Omarsvette
    from Arizona
    I ended up getting a hotheads adapterfor a th350, very easy to install. Plus super easy to get a th350.
  15. Omarsvette
    Omarsvette
    from Arizona
    Are you using the HH Oil filter adapter?
  16. I got my adapter from TR Waters ,Vt.
  17. Omarsvette
    Omarsvette
    from Arizona
  18. My biggest grip with the early 331 is intake selection and cost.
    If you run the coman ones like this hot heads intake then you have to use tubing Or an or hose to remote thermostat housing.
    If you are lucky enough to find an intake with a thermostat housing built in there pricy.I plan to use this with 2- holley 450 2 barrel carburetor.
    Here's my hot heads trans adapt and oil filter adapt 20190118_113352_Film3.jpg
    Lil'Alb and Dog_Patch like this.
  19. Omarsvette
    Omarsvette
    from Arizona
    no dont use the dual intake!! your single looks better. you could just sell me the dual and not worry about linkage, carbs, etc:D
  20. Omarsvette
    Omarsvette
    from Arizona
    is your oil filter pointing up? cant tell on your photo. mine from HH, points up 30degs, like the original. when i removed the original filter there was a spacer looking thing still attached to the block. is that supposed to come of. i have called HH yet.
  21. it point up just like the factory did.
    I felt lucky I got the intake 2 years ago and it was $524 for the 2x4 it was in very good cond. I have see them go for $2400
    Im not real sure why I put the hemi in the 63 F100 it was built and it fit the hemi will be worth more then the truck LOL
  22. its got lots of nice parts in it the man I got it from had $8000 in receipts for parts and machine work just need to be put together $2000 well invested
    Lil'Alb, Dog_Patch and triumph 1 like this.
  23. Omarsvette
    Omarsvette
    from Arizona
    that looks good. i have never seen hemi heads off. i understand the hemi shape CC.
    i think it will look good in your truck. i would love a hemi in my 56 chevy.
  24. Omarsvette
    Omarsvette
    from Arizona
    you have a different timing cover and cam?
  25. Yes it's a hot heads aluminum timing cover and the cam was an erson grind made for 1956 and up 354
  26. chevy2tom
    chevy2tom
  27. classiccarjack
    classiccarjack
  28. sunbeam
    sunbeam
    My buddy Gary Byers had a 62 Corvette running a push button Flite behind a 327 using a manual valve body Damm that thing was cool shifting gears by pushing buttons. If you want to push buttons a have a slip yoke drive shaft 1965 was the only year.
    classiccarjack likes this.
  29. DDDenny
    I never could type!
