Projects 1946 buick sedanette with top chop
Discussion in 'Traditional Customs' started by Lines, Jul 4, 2018.
  1. Lines
    Lines
    from Germany
    Here are some pictures of my new projekt a 1946 Buick Sedanette Roadmaster.
    The body isnt to bad and its almost complete.
    The car will be fixed up for regestration first and the customised bit for bit in the traditional style.
    Outback, UNSHINED 2, swade41 and 13 others like this.
  2. mgtstumpy
    mgtstumpy
    Looks fantastic, 'C' bodied Buick 50 or 70? Very similar to the OEM 2 tone colour scheme on my 46 Olds sedanette; pawnee beige over new ivory.
    Is that original paint as I can't see that colour scheme on the Buick chips?
    Future plans are?
    Ron Funkhouser likes this.
  3. Lines
    Lines
    from Germany
    Hi. Its a 76 model. The paint and interior isnt original it had been repolstered in the colors of the paint. I think buick didnt have these colours as an option. The car came original in black.
    Plans are getting it fixed for registration and fixing it up bit for bit and customising it in traditi**** style.
  4. Corvette Fever
    Corvette Fever
    from Michigan
    That should make a very Kool ride....I had a 47 Roadmaster convertible they are rare and make an interesting ride.
  5. Lines
    Lines
    from Germany
    I havent had a ride in it yet. I had a1958 Buick Super but I can amagine that the 40s modells have a different ride.
  6. Lines
    Lines
    from Germany
    I like the style and build of Hans Ola Christenson's 1947 Buick.
  7. BJR
    BJR
    That Buick looks great! With a buff job it should shine. What do you need to do to get it running?
  8. Lines
    Lines
    from Germany
    The pictures are as I colected the car. Car is washed and looks better (from the distance). The brakes need to be be rebuilt , parts came in yesterday. We had the engine running for a short time before the carb started to leak., ran good and smooth as it should(my first straight8). Electrics need to be repaired and small stuff. Need new wheels. I cant make up desissions wich ones to take. At the momet there are old 8.20 mounted. I mesured the rim size and it came to 6.5x15 so I think the rims came from a 49 model. At the moment Im thinking of mounting some G78x15 wich have a total diameter of 27.6 to the original 7.10 wich have 27.98 and 28.88 but I cant find a decent picture of this car with G78 mounted. I had mounted a L78 which is far to big for the look to the car.
  9. 'Mo
    'Mo
    Griznant, blowby and mgtstumpy like this.
  10. Lines
    Lines
    from Germany
    Thanks, It looks so cool. Do you have any idea what size of wheel he could be running?
    They look like 7.10 or 8.20
  11. 'Mo
    'Mo
  12. Lines
    Lines
    from Germany
    Some new pictures.
    I cut out the trunk floor and will be building it new and instal a other gas tank with the filling from the inside of the trunk.
    Interior has been dissambled complete and for good the floor pans are in good shape.
  13. Lines
    Lines
    from Germany
    Some new pictures of progress I did.
    Cut out the inner and outer rocker panel. It had been fixed bevor but the sheet metal parts had been welded over the old rusty metal. So cut everything out and build new parts with fresh metal.
  14. Lines
    Lines
    from Germany
    The door was fixed bevor and the mesurment of the door woren't the same as on the driver side. Luckily the driver door wasn't fixed and I was able to take the mesurments of it. To fabricate the new rocker panel I wanted the door to sit in propebly and not build the rocker to fit the misswelded door.
    So build a new floor part for the p***enger door. Next step is to rebuild the bottom outer skin of the p***enger door.
    UNSHINED 2, Hnstray and mgtstumpy like this.
  15. Sporty45
    Sporty45
    I had to do very similar work to the rocker panels on my 47 Olds coupe. It was a lot of work and I took lots of measurements first. I used rocker panels from Chevs of the 40's, as they are the same as my Olds panels fortunately. Not sure about the Buick though.
    IMG_20180607_161338693.jpg IMG_20180708_155730429.jpg IMG_20180805_154959408.jpg
    Big mike 1968, tb33anda3rd and Lines like this.
  16. Lines
    Lines
    from Germany
    Thats a nice pice of metal work you did there. Thats what I like.
    Sporty45 likes this.
  17. Fortunateson
    Fortunateson
    Looking forward to more pics. I have a '47 56S and a '47 56C, Sedanette and Convertible, stashed away waiting patiently so the work you do may be the work I have to do. Good luck...
    Big mike 1968 likes this.
  18. Orn
    Orn
    Nice Buick!
  19. Fortunateson
    Fortunateson
    I'm pretty sure that 15" rims became available in '47 for the Roadmasters.
  20. Lines
    Lines
    from Germany
    Yes the 15" came in 47. I have 15" on now with 8.20 tyres. This car needs big tyres. As I bought it it had 6.70 on they looked way to small.
    RDR likes this.
  21. Lines
    Lines
    from Germany
    New progress in p***enger door
  22. Lines
    Lines
    from Germany
    As soon the front edge of the door is finished it can be installed back to the car. Then the rockers can be built.
    The fade away parts will be welded to the door when the front fenders are bolted back to the car to line them up
  23. Lines
    Lines
    from Germany
    Progress of the p***enger door. Door is mounted and fits in good. Next step is rebuild the lower part of the A pillar to then fabricate the inner rocker panel an floor part.
    UNSHINED 2 likes this.
  24. Lines
    Lines
    from Germany
    Rebuilding the bottom a pillar part
  25. wookster
    wookster
    love the Buick Sedanette's
    Awesome
  26. deepfreeze88
    deepfreeze88
  27. Lines
    Lines
    from Germany
    Thank you. Im giving my best and learning:)
  28. Lines
    Lines
    from Germany
    Got a bit further. Took ages of mesurments and bending to get the inner rocker panel and the top rocker part in to match the door conture. At least there is a nice 10mm gap between them.
    UNSHINED 2 and spurgeonforge like this.
  29. Lines
    Lines
    from Germany
    These are pictures from the driver side.
  30. Lines
    Lines
    from Germany
    This is what I cut out from the p***enger side.
