Technical New hemi owner
Discussion in 'Traditional Hot Rods' started by Omarsvette, Oct 31, 2018.
  1. Bandit Billy
    Bandit Billy
    Original paddle shifters?:cool:
  2. Edsel had push button shift right on the steering wheel.
    classiccarjack likes this.
  3. Omarsvette
    Omarsvette
    from Arizona
    Here’s a thought, convert my th350 to button shift!!;)
  4. Omarsvette
    Omarsvette
    from Arizona
    And while we are talking about converting, I still have the original distributor. Points, I assume. It would be beneficial to go electronic? Which one?
  5. gatz
    gatz
    Omar,
    I've got a new Accel 59301 electronic distributor that I intended to use on my 331.
    For the run-in, I did put it in, but decided later to go with points.
    If you're interested, shoot me a PM, and I'll send pix and info.
    gatz
  6. Omarsvette
    Omarsvette
    from Arizona
  7. sunbeam
    sunbeam
    I went this wayhttp://www.gofastforless.com/ignition/points.gif
  8. bostonhemi
    bostonhemi
    Great job looking nice.
    Omarsvette likes this.
  9. Omarsvette
    Omarsvette
    from Arizona
  10. gimpyshotrods
    gimpyshotrods
    Electronic Control Unit:
    Good old Mopar spark box.
  11. Omarsvette
    Omarsvette
    from Arizona
    Wow that’s new to me. Mopar thing. What is the purpose of the ecu? Is it like fords ignition module? All Mopar points distributors use it?
  12. 57 Fargo
    57 Fargo
    It is like fords ignition module just less prone to failure. Not needed with points, used with electronic ignition.
    That should get the ford guys riled up! Lol
  13. sunbeam
    sunbeam
    If used with points a very small amount of current passes through the points making points last much longer and hotter spark. Factory it was used with magnetic switch distributor.
  14. Omarsvette
    Omarsvette
    from Arizona
    Any of you guys changed over to a one piece balancer
  15. gimpyshotrods
    gimpyshotrods
    It doesn't balance anything.
    It's a harmonic dampener.
    If it were truly one-piece, it would be called a hub, and, while it might be good for driving a blower belt, it wouldn't do anything to dissipate torsional issues coming from the crankshaft.
  16. Omarsvette
    Omarsvette
    from Arizona
    So leaving it like original, a two piece harmonic dampener, is best?
  17. gimpyshotrods
    gimpyshotrods
    Yes.
  18. rod1
    rod1
    I went with the 340 dampener from hotheads.I had an original that "looked good"on it,came out from the paint store .Started it,had a funny ringing sound.Opened the hood,the outer ring had separated,but had slipped inward toward the crank ,came off and was spinning on the crank.I had dodged a bullet.
    gimpyshotrods likes this.
  19. gimpyshotrods
    gimpyshotrods
    A 340 dampener is a good solution.
  20. Omarsvette
    Omarsvette
    from Arizona
    Ok I see it on the website. And I think he recommend it if mine was bad, that 340 is a one piece to look like the original?
    These dampener come off the same as the Chevys do?
  21. Bandit Billy
    Bandit Billy
    I got one for my Desoto from Hot Heads.
    Stuck my SBC water pump on temporarily tonight to see if the pulleys are going to line up properly. Looks right on. An awful lot of spacers had to be used though, it still engages the hub but barely.
    bostonhemi likes this.
  22. DDDenny
    Thems' some shexy rocker covers Billy!
  23. gimpyshotrods
    gimpyshotrods
    Any chance I could get you to toss a tape measure across that dampener?
    I need to order the correct diameter degree ring, for my blower hub.
  24. Bandit Billy
    Bandit Billy
    7" Diameter.
  25. gimpyshotrods
    gimpyshotrods
    Sweet! Thanks!
  26. Bandit Billy
    Bandit Billy
    Any time!
  27. Omarsvette
    Omarsvette
    from Arizona
    This would be the proper manifold for my motor? 5CEF7332-5BC3-4D8B-A1B4-AA5FB2E37844.png
  28. oj
    oj
    That Edmunds would be tits unless you find one of these: 001 (4).JPG
  29. loudbang
    That's a rare piece but I don't know if it will fit your engine. There is a thread here on the HAMB for Edmund intakes but can't find it at the moment.
  30. tubman
    tubman
    We would need to see a bottom view. The '51-'53 heads have smaller ports than the '54's, so if was made for the early small port heads, it wouldn't be ideal for your engine. I have used later manifolds without the water outlets on the earlier blocks a couple of times. The NPT threaded holes in the manifold can be connected with the proper fittings and heater hose to a remote thermostat housing and you're done. I have a later Weiand dual quad on the '54 New Yorker engine in my dirt car. I think I can dig up a picture if you want to see how I did it.
