Projects Build Thread ~ '58 Chevy Stepside
Discussion in 'The Hokey Ass Message Board' started by Black_Sheep, Jul 14, 2010.
  1. belair
    belair
    Much respect.
    loudbang and Black_Sheep like this.
  2. Black_Sheep
    Black_Sheep
    Then it was time to set the cab back in place. After cleaning the dust and cobwebs off the ch***is new cab isolators were put in place, some poly pads replaced the rubber and shim setup on the front cab mounts. I thought it would take a lot longer to put the cab on by myself, it went on in a matter of minutes.
    catdad49, loudbang and Stogy like this.
  3. Black_Sheep
    Black_Sheep
    Then I started wiring things up, built an instrument cluster, added sound deadener and tended to countless other details inside the cab.
    IMG_0388.JPG 22815634_1467967983240678_3167342082497621869_n.jpg steeringcolumn.jpg steeringfit2.jpg floorplate.jpg 23376491_1479688435401966_4851684653788681073_n.jpg IMG_0550.JPG heat2.jpg 27749892_532412997145140_5945443677072160913_n.jpg
    catdad49, loudbang, Stogy and 2 others like this.
  4. Black_Sheep
    Black_Sheep
    Then I pushed the cab and ch***is into the corner and started on the other body panels. The front fenders needed some patches on the bottom corners behind the wheels, otherwise it was just a lot of filling, block sanding, priming, block sanding, etc. I used a new tailgate from MAR-K without "Chevrolet" embossed in the center so I could add a little custom touch. I also used their rear sill and both bedsides due to major issues discovered when everything was stripped. Their stuff is top notch! The metalwork was uncharted territory for me, but that's how you learn. Lots of mock up and re***embly but it paid off when it was time for final ***embly...
    IMG_0478.JPG IMG_0491.JPG IMG_0358.JPG IMG_0359.JPG View attachment 4166586 IMG_0487.JPG IMG_0513.JPG IMG_0514.JPG 29340051_1601305303240278_3661073906007015424_n.jpg 29314474_1601305323240276_1716092635959001088_n.jpg IMG_0565.JPG
  5. Black_Sheep
    Black_Sheep
    I got the fenders and door as close as I could but they were still not ready for paint. A local shop finessed them into shape and gave everything a final coat of 2K. With that done my attention turned to the inner fenders, core support and anything else I could get done while waiting for my turn at the paint shop. IMG_0495.JPG 26169448_518501708536269_1039991610683052266_n.jpg 29365524_1601465896557552_145047810159411200_n.jpg 36471644_1711819438855530_8454458919618609152_o.jpg latch.JPG 29060944_1608307545873387_7274129468135850080_o.jpg 35861400_1695722887131852_2071063282017370112_n.jpg 32506950_1657579094279565_6037805062678380544_n.jpg 32673403_1658405004196974_138651126386917376_o.jpg
  6. Black_Sheep
    Black_Sheep
    Last one for tonight, final mock up of the interior so I could fit the carpet and padding. The interior is starting to look like something. I also prepped and painted a bunch of miscellaneous parts. Some areas got a coat of SEM bedliner for long term durability.
    IMG_0515.JPG 27751994_1565490653488410_7221447507049820260_n.jpg 29064673_1608357635868378_4075893325694002975_o.jpg 29497775_1608383299199145_4753958038991918429_n.jpg IMG_0564.JPG IMG_0591.JPG IMG_0593.JPG 31924522_1648106558560152_2432916196555751424_n.jpg 31950272_1648107268560081_5701057507590406144_n.jpg 34135475_585716325148140_3736660090556514304_n.jpg 33624355_1667798906590917_5123367763280134144_n.jpg
  7. Lone Star Mopar
    Lone Star Mopar
    Black_Sheep and loudbang like this.
  8. Black_Sheep
    Black_Sheep
    I cleaned up the front of the engine and put the core support and radiator back on. The truck would have to be running to load it on the trailer and haul it to paint. I also got the doors hung and adjusted, no way I want to hang doors with fresh paint. I hauled over all of the loose body parts so the painter could get started on them. The rest of the truck couldn't go until the car which was painted before mine was picked up.
    Finally the day came and I loaded it up for the short trip to the painter's shop. 31935684_1648305011873640_4076819524714758144_n.jpg 31958784_1648431878527620_1360121460089159680_n.jpg 36726596_1720002204703920_6856244886618767360_n.jpg 37103935_1730096900361117_5404215855154200576_o.jpg 38033560_1756635131040627_4128332400390307840_o.jpg
  9. Black_Sheep
    Black_Sheep
    Over the following month or so the painter would send me progress reports which really freaked me out at first. The shop lighting made the color look much darker than it actually was.
    Bryan the painter cut and buffed the loose parts so I could haul them home and get started ***embling the box while he finished polishing the cab.
    38287570_1759387017432105_1023341714221301760_n.jpg 38199992_1759386987432108_3040375020619563008_n.jpg 38864923_1770324839671656_8597591543731191808_n.jpg 38878195_1770324903004983_7641268679585300480_o.jpg 39292274_1780923631945110_6294317741004292096_n.jpg
  10. Black_Sheep
    Black_Sheep
    39072738_1774319532605520_6980822891235377152_n.jpg 38985051_1774319565938850_6476648603187150848_n.jpg 39086617_1774319699272170_1439461179767390208_n.jpg 39080080_1775479079156232_8852622823412203520_n.jpg 39140966_1777584268945713_8097294915366551552_n.jpg 39050557_1775275812509892_6893913218683502592_n.jpg 35302396_1689440007760140_9111441499744108544_n.jpg 39120543_1777584302279043_8553949126906085376_n.jpg I ***embled the box and oak bed wood. In case you're wondering, there's 20+ coats of Helmsman's satin spar polyurethane, sanded every 2 coats. Stainless bed strips and hardware hold everything together. SEM Rock-It bedliner was rolled on the bottom of the boards and inside the rear fenders.
  11. Black_Sheep
    Black_Sheep
    Then the day came to bring the rest of the truck home. A few friends came over and helped set the box in place and get it lined up. I put 3M strip caulk between all of the sheetmetal panels before bolting them together to avoid paint to paint contact and hopefully prevent squeaks. It's finally starting to look like a truck again.
    Once the back end was done it was time to turn around the truck and start on the front.
    39875586_1790665547637585_7996622849043333120_n.jpg 39835100_1790719057632234_8376109275801452544_o.jpg 39937442_1792328657471274_6154644704458702848_n.jpg 39914720_1792328670804606_6285356832907067392_n.jpg 39994514_1795573350480138_7662782780656320512_o.jpg 40002168_1795709247133215_2768809594317701120_n.jpg 39975707_1795709007133239_5518189392243458048_n.jpg 40049759_1795707357133404_5126716188503572480_n.jpg 40137778_1795707240466749_5958186470773620736_n.jpg 40079684_664277063958732_3595621851411251200_n.jpg 40062109_664276970625408_4322580916351270912_n.jpg
  12. Black_Sheep
    Black_Sheep
    More ***embly...
    cowldone.jpg 41423835_697985253921246_8369209247631671296_n.jpg 40444601_1801264169911056_7055773583833825280_n.jpg 41215808_688495361536902_8659393580499992576_o.jpg 41445865_1813174878719985_8424354682092126208_n.jpg 41363496_1813174865386653_15607601916018688_n.jpg 41412321_1813174885386651_8966486576842407936_n.jpg 41334463_1811675065536633_3489863182304935936_n.jpg 40784925_1806637466040393_8987832379619934208_n.jpg 41652882_1817802641590542_3570797619045203968_n.jpg 41708584_1817801974923942_2121365058519826432_n.jpg 41669268_1817801948257278_6876506214449020928_n.jpg 41673213_1817801934923946_5402507746660581376_n.jpg 41936482_703472766705828_4659754734058471424_n.jpg 41990882_703478506705254_6741128033530281984_n.jpg
  13. Black_Sheep
    Black_Sheep
    While waiting for my good friend Warren to free up a little time on his schedule to help hang the front end sheetmetal, I got the interior all put together. Again, the mock up process sure made final ***embly go smoothly...
    41942316_1819802748057198_6275553832046952448_n.jpg 41756913_1819771861393620_4404751912830763008_n.jpg 41808242_1819818158055657_9060233102890106880_n.jpg 42168868_1823490897688383_6565333776564486144_n.jpg 42650307_707556659630772_1050965148572844032_o.jpg IMG_3004.JPG 42778481_1834948839875922_2710124917826781184_n.jpg
  14. Hotdoggin DaddyO
    Hotdoggin DaddyO
    from Hays, Ks
    Son, you have done a great job. I would be very proud. Your Brother would be proud.
  15. Black_Sheep
    Black_Sheep
    Warren and I spent an evening hanging the front fenders and getting the gaps decent. I was hoping to get the hood on but we ran out of time that night...
    42140704_1824552994248840_5769634700649824256_n.jpg 42170125_1824553004248839_6332368913568890880_n.jpg 42117766_1824553110915495_8339195092749254656_n.jpg 42132034_1824553120915494_3518311125823258624_n.jpg
  16. If you’re mentally ill like me you can turn those hose clamps around so they all face the same way and then you’ll feel normal again.
    Love the truck. Really great job that you’ve done.
    catdad49 and loudbang like this.
  17. Black_Sheep
    Black_Sheep
    I appreciate that, Chris really loved this truck and I have fallen in love with it as well.
  18. Black_Sheep
    Black_Sheep
    Thanks for pointing that out, now I'm going to have to fix it...
    catdad49, loudbang and Fordor Ron like this.
  19. Black_Sheep
    Black_Sheep
    It only took a few more evenings to fit the hood, lights, bezels, etc... I ended up reworking the bumper brackets to tighten up the bumper to splash pan gap. The end is in sight...
    42215370_1825522197485253_5001634590381572096_o.jpg 42376850_1827316793972460_6253768443661647872_n.jpg 42303393_1827682733935866_2940391665187160064_n.jpg 42403743_1827683667269106_707253321194274816_n.jpg 41294771_1812147988822674_7599257852116467712_n.jpg 33235A87-DC89-4D18-A639-7CF95D2B4A88.jpg 42432892_706699199716518_4094380765519806464_n.jpg
  20. Black_Sheep
    Black_Sheep
    I was finally able to roll it outside and look at the truck from more than a few steps away...
    42785689_707556329630805_7995371385767591936_o.jpg 42679420_707556369630801_7814008888386125824_o.jpg 42557779_707556376297467_1651711406904442880_o.jpg 42575361_707556346297470_4525591964459991040_o.jpg 42686542_707556512964120_3150200882021269504_o.jpg 42568063_707556692964102_9206492424539471872_o.jpg 42680687_707556592964112_200814490164396032_o.jpg
  21. Black_Sheep
    Black_Sheep
    A shot of the motor for good measure...
  22. Black_Sheep
    Black_Sheep
    Tomorrow I'll post a few shots from the maiden voyage v2.0
  23. Chavezk21
    Chavezk21
    You done did your brother proud! what a beautiful machine. I love these trucks anyway, but dayum!
  24. Shadow Creek
    Shadow Creek
    I really like the fact you kept the roof white.. this truck is really nice and the story behind it makes it that much better. Great job!
    catdad49, loudbang and Black_Sheep like this.
  25. Beautiful. Really well done.
    One of the cleanest builds I’ve seen on here in a long time...
  26. belair
    belair
    Very nice. Thanks for taking us to the finish line.
  27. alfin32
    alfin32
    from Essex, Ma.
    Puuuurfection, I'm in LOVE!!!
  28. Black_Sheep
    Black_Sheep
    I am humbled by all of the kind remarks, thank you...
  29. Black_Sheep
    Black_Sheep
  30. Black_Sheep
    Black_Sheep
    The gas tank was pretty low so the first stop was Quik Stop for some non-oxy gas. I drove around the back roads near home just in case there was a problem. On the way back home I stopped in the school parking lot and shot some pictures for posterity...
    IMG_3014.JPG IMG_3037.JPG 42986287_709230436130061_83569437831069696_n.jpg 42921976_709230566130048_5971772487417987072_n.jpg
