Projects 1930 Model A Progress
Discussion in 'Traditional Hot Rods' started by Paul F, Feb 4, 2018.
  1. Paul F
    Paul F
    I used 2" flex Fuel Hose...
    From Filler Neck Supply Company
    Dino 64 likes this.
  2. GordonC
    GordonC
    Cool!
    Paul F likes this.
  3. Paul F
    Paul F
    Setting in the dash...no interference behind the gauges...very happy... IMG_3353.JPG
  4. Paul F
    Paul F
    It’s been a while...working hard...but...frame is here! Wheels and tires, ragtop,...rear end...ready to go!!![​IMG]
  5. Paul F
    Paul F
    Update...well rear end is built, Rag top fitment is good, firewall off...building front end..[​IMG][​IMG][​IMG]
    walter, JOYFLEA and Jet96 like this.
  6. 3banjos
    3banjos
    from NZ
    Any plans to add a K-member, or some angular bracing.
    nunattax likes this.
  7. dirt t
    dirt t
  8. Paul F
    Paul F
    Ummm no, I had not planned on that...
  9. Paul F
    Paul F
    [​IMG] front end ***embly...here I come!
    walter likes this.
  10. Paul F
    Paul F
    Workin’ away...[​IMG][​IMG]
    louisb likes this.
  11. Paul F
    Paul F
    Update: Rolling Ch***is complete...time to drop in the Engine and Trans![​IMG][​IMG][​IMG]
  12. 3banjos
    3banjos
    from NZ
    Just planning a little ahead, have you drilled and tapped some holes for clipping your headlight harness and battery cable etc. PITA once that donk's in the way. Also wouldn't hurt to have a couple more clips on the brake line.
    Of note, how close does that panhard get when the weight goes on.
    -Brent- likes this.
  13. Mike Colemire
    Mike Colemire
    I don't know if he drilled any holes but I'm glad you reminded me. Nice build and fab work, going to make a cool hot rod. Now to add that to my list.
  14. Paul F
    Paul F
    Panhard clears...thanks for the feedback!
  15. Paul F
    Paul F
    [​IMG]working on fitment...
  16. Paul F
    Paul F
    Well I’ve been super busy and My Rod is on the road...some minor tweaks, interior and re- paint are left...runs great, steers well...can’t complain...[​IMG]
  17. keywestjack
    keywestjack
    from Pittsburgh
