Projects How hard could it possibly be to drill a hole in a bucket,,,,
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Jan 24, 2019.
  1. And install a 1/2" valve?
    I've been all over town and can't find a decent tank fitting or bulkhead fitting Oh there's plenty if you're in Europe. And there's plent if you want to spend $200 or so on it with a 3" hole.
    How about a metal bucket that I can weld something too? 31 ga galvanized buckets slightly thicker than a beer can.
    Damn,all I want to do is drill a 3/4 hole in the side of bucket, install a 1/2" valve that doesn't leak at the sidewall (it can not leak) and meter how fast the liquid comes out of the bucket. How hard should that be?
  2. Paul
    Paul
    Editor
    thrift store or garage sale stainless stock pot and weld a steel bung where you screw in your tap
  3. Dick Stevens
    Dick Stevens
    Can it come out of the bottom of the hucket where it is flat and use an elbow and valve? That should make it a lot easier.
  4. 41rodderz
    41rodderz
    from Oregon
    Ahh the simple things in life . :D Murphy'slaw and all that. Does McMaster Carr have plastic valves in their catalog? State deicer tanks used a plastic valve.
  5. NashRodMan
    NashRodMan
    Tractor Supply? Or McMaster Carr?
  6. 41rodderz
    41rodderz
    from Oregon
    How about a shut off valve like would be on your outside water spigot on the house ? Lowes , Home Depot have them.
    squirrel likes this.
  7. kidcampbell71
    kidcampbell71
    Try a restaurant supply Steve. Whether plastic for tea dispenser type or bronze/br***/stainless/galvanized for grease flow dumping. They should have a reasonable bulkhead valve for you.
    Hell, Grainger's is another .... from commercial to farm supply ... they have everything to outfit a Guatemalan Army .... but that's a story, for another day. Try Grainger's though. Huge place.
  8. 41rodderz
    41rodderz
    from Oregon
    water spigot on a ****** and braze it to the can ?
  9. Bear40
    Bear40
    from Minnesota
    I did it once just to prove I'm smarter than a bucket, but it was a pain in the ***. I'm a stubborn machinist, so I made a couple of heavy washers, one flat on one side, concave on the other, and the other washer flat on one side, convex on the other. Made a couple round rubber gaskets and bolted the whole sandwich together tight through the hole in the bucket using the valve to draw it together. Took about half a day to get what I wanted, but I showed that bucket who's boss!
    gas pumper, Hombre, egads and 3 others like this.
  10. Nostrebor
    Nostrebor
    They make special gaskets for this that Grainger sells, but for the life of me I can't remember...
    BRB!
  11. Nostrebor
    Nostrebor
  12. Hnstray
    Hnstray
    from Quincy, IL
    Catch pans/basins for water heaters typically have a plastic ****** fitted to them for drain hose ...check your nearest big box store......
  13. noboD
    noboD
    When I was a kid we had a bucket with a *** out the side to feed calves. I would think you could find one at Tractor Supply or Agway.
  14. DDDenny
    You had me at "with a *** out the side", hell, I'd buy two of them!
  15. Home Depot
    Tractor supply
    Rual king
    My local plumbing house
    All Three of my Auto supply guys
    Grainger.
    Nothing-
    Closest thing is the Hot water tank drain pan fitting but it's plastic and course thread. I used one and it leaks or if you really tighten the thing up it smushes the gasket and then pours out.
    The fitting needs to come off the side.
    I'm going to hit the s**** yard and see if I can find a small tank to make a bucket out of. Then I can weld a pipe coupling to it.
  16. squirrel
    less than a minute of googling found a couple :)
  17. Gregg Pellicer
    Gregg Pellicer
    Just find a br*** valve drill a hole and SOLDER it in. No washers no gaskets clean and simple
    alanp561 and chryslerfan55 like this.
  18. kidcampbell71
    kidcampbell71
    Seriously ?? These won't work ? Bulkhead dump valves or bulkhead grease valves. Threaded for hose barb. Guess I misunderstand, maybe.
    Screenshot_20190124-133110_Google.jpg Screenshot_20190124-133150_Google.jpg Screenshot_20190124-133253_Google.jpg Screenshot_20190124-133318_Google.jpg
    tb33anda3rd and rockable like this.
  19. Phillips
    Phillips
    Tractor supply co., a**** others. EDIT I see I was about the fourth person to suggest this!
    juan motime and olscrounger like this.
  20. Blue One
    Blue One
    from Alberta
  21. 1946caddy
    1946caddy
    from washington
    If you weld on the bucket, use a respirator.
    From OSHA;
    The typical effect of breathing zinc fumes is metal fume fever. One or two hours or more after welding-without proper personal protection-you may experience severe thirst, pain in the legs, shivering, congestion in the head, dryness and tickling of the throat, and a cough. In very bad cases, you may feel severe shivering, a high fever, buzzing in the ears, nausea, vomiting, and even hallucinations and convulsions. Your symptoms will usually last 24 hours.
  22. oldolds
    oldolds
    Go to the oldest plumber in town. He will have what you need in his truck. He will even know what it is called to order another one
    clem and 31Vicky with a hemi like this.
  23. If I were in Australia, India Asia or Europe I'd do down to the local supply and ask for a "tank fitting" , I'd get one of these and I'd be happy- never bothering you guys because I'd be building my little bucket.
    Hnstray likes this.
  24. Casey Riley
    Casey Riley
    from Minnesota
    What you nee is a homebrewing bucket with spigot.
    alanp561 likes this.
  25. K13
    K13
  26. trollst
    trollst
    Smushes......is that some kind of highly technical term I don't understand? Geesh, you think with all the old car talk here I wouldn't get left behind......
    Texas Webb likes this.
  27. Happydaze
    Happydaze
    I hear ya, but in the UK you'll get some strange looks when asking about fasteners in anything other than metric **** in the local supply joint. Swings and roundabouts!
    Chris
  28. Interchangeable with smoosh
  29. Rickybop
    Rickybop
    Hey...31...
    When you went to Home Depot, did you check in the pool, pond and fountain supplies? Simple, inexpensive, plastic bulkheads. You can easily add a valve and other plumbing to it.
    Hnstray likes this.
  30. noboD
    noboD
    I can still smell the horribleness of the dried milk. No wonder they got the ****s.
    Phillips, juan motime and olscrounger like this.
