Projects How hard could it possibly be to drill a hole in a bucket,,,,
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Jan 24, 2019.
  1. I did,
    Might be stuff online but not in store.
    I snagged a tank from the s**** yard.
    Problem Should be solved here shortly.
  2. rusty valley
    rusty valley
    s**** yards are the best place to shop. sadly, many now days wont let you buy anything. gotta get out of the city for that
  3. Rickybop
    Rickybop
    I know you can do it. :D
    Btw...what's the flow experiment all about?
    You building an ancient-style clock?
  4. BJR
    BJR
    Is this a traditional bucket, or one made after 1965?:p:D
  5. pirate
    pirate
    from Alabama
  6. It sounds like you could use a simple hose faucet. The 1/4 turn, ball valves open quickly to a straight through flow. They might be slightly smaller than 3/4", however. A plumbing supply would have something bigger. My guess is they will empty a bucket as fast as a NASCAR fuel can.
    Since this is all for a one time test just use a combination of pipe flange nuts and silicone caulk.
    Edit to add: How about a hole with a simple cork?
  7. mohead1
    mohead1
    Come on now.....google bulkhead fitting and you can get just about any style, size, thread, etc
    Sent from my SM-G900V using Tapatalk
  8. DDDenny
    I know what you're building.
    Did you try Stills R Us?
  9. Ok I did this a bunch of times at the transmission shop I worked at years ago.
    We would get the 15 gallon drums and install just a regular br*** solderable hose bib on to it.
    How I did it is I drilled a hole as close to the bottom as I could
    Got a short length of 3/4” copper pipe and put a very exaggerated flare on one end and put the pipe into the hole I just made with the flare to the inside of the drum.
    The with a hammer tap the flared end of the pipe and the drum so both areas met up with minimal gaps.
    Then brazed the pipe to the drum on the inside and outside of the drum.
    Once that was done I brazed on the hose bib ( it was one of those spring loaded snap closed deals.
    Worked great I made 5 about 20 years ago and they are still there.
    Owner likes to keep “ good” used transmission fluid. Good guy but a bit weird.
    Anyways there ya go
  10. rockable
    rockable
    Go to your nearest ParkerStore. Buy a br*** npt bulkhead fitting, I think it's a 207ACBH-8. You will have to apply some rtv around it but it will seal up. Then, put whatever fitting or valve you need in the 1/2" female npt port. Easy.
  11. Blue One
    Blue One
    from Alberta
    If it’s a plastic bucket or even a fibregl*** bucket it surely isn’t traditional ;) :D
  12. Hnstray
    Hnstray
    from Quincy, IL
    and...it will hurt the resale vale too! :D
    BJR and VANDENPLAS like this.
  13. Nothing but steel
    Hnstray and BJR like this.
  14. woodiewagon46
    woodiewagon46
    from New York
    McMaster-Carr has about a dozen different varieties of bulkhead fittings. Order today and you get it next day.
  15. tb33anda3rd
    tb33anda3rd
    weld a bung to a 4"x4" square of 16 gage and drill holes in the four corners, make a couple gaskets and a "twin" for the inside of the bucket, silicone and bolt together.
  16. Blue One
    Blue One
    from Alberta
    And then stand back and watch it leak ;):D
  17. Rickybop
    Rickybop
    Together, the Hamb can do ANYTHING!!! :D
    Hnstray and 31Vicky with a hemi like this.
  18. And that's what you need todo to get the job done
    That's how hard it is !
    because a simple fitting out of br*** is just not available in the USA. Plastics fittings sure, a hundred or two hundred dollars and up for some sure. I don't want and can't use plastic and I'm not excited about $100 n up for it.
  19. thorpe31
    thorpe31
    from nor-cal
    Tire valve stem ***embly for a piece of equipment, used should cost you a beer or a Gatorade. Or a bulkhead fitting for a glad hand but it’s heavier.
    tb33anda3rd likes this.
  20. 6sally6
    6sally6
    NO problem with the dreaded "peronies disease(the curve)" on this dude!:cool:
    6sally6
  21. DDDenny
    Peyronies
    Go ahead, Google it, I dare you.
    Oh yeh, don't forget to click "images".:eek:
    VANDENPLAS likes this.
  22. bchctybob
    bchctybob
    Get a good top and side curtains for that bucket so you don't have to drain it all the time.....
  23. grimmfalcon138
    grimmfalcon138
    from az
    What in the actual **** man ?!?
    kidcampbell71 likes this.
  25. noboD
    noboD
    Monica would know about that.
  26. Last edited: Jan 24, 2019
    tb33anda3rd and VANDENPLAS like this.
  27. kidcampbell71
    kidcampbell71
    ... power of the HAMB
    LOL
  28. blowby
    blowby
    from Nicasio Ca
    Turn a 20lb. Propane tank over and cut the bottom off.
  29. Peter Berghs
    Peter Berghs
    That flow rate depends on the valve type size and the liquid height in the bucket. There is an easy calculation given on the PDF here:
    nibco.com/WorkArea/Download***et.aspx?id=21474836699
    or search google for
    Flow Data Cv Values for Valves - Nibco
    the P in the flow equation can be calculated using the height of water or fluid in the bucket using this equation:
    p = 0.433 h SG (1)
    where
    p = pressure (psi)
    h = head (ft)
    SG = specific gravity of the fluid (1.0 for water less for gasoline )
    hope this comes through but I can help if I have more info on the valve type and liquid height.
    this will be fairly accurate as long as the liquid level is above the valve and no vortex is forming in the bucket.
  30. thorpe31
    thorpe31
    from nor-cal
    The big ones are 2 piece the bulkhead part and stem.
