1948 Ford Superior short school bus.
Discussion in 'The Antiquated' started by Kustomkid, Jan 8, 2019.
  1. Kustomkid
    Kustomkid
    from Montana
    Here is my 1948 Superior school bus I saved from the wrecking yard 10 years ago. Had most of the aluminum interior stripped out of it. But it’s pretty solid.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. Kustomkid
    Kustomkid
    from Montana
    Was able to get what was left of the interior sheet metal, front clip and some of misc parts that was missing on mine off this bus before it was crushed. [​IMG][​IMG][​IMG][​IMG][​IMG]
  3. Kustomkid
    Kustomkid
    from Montana
    Got to get the front and rearend out of our old dump truck. [​IMG][​IMG][​IMG][​IMG]
  4. Kustomkid
    Kustomkid
    from Montana
    Test fitted some of the sheet metal. Wasn’t sure how it would fit. [​IMG][​IMG]
    And how it has been sitting. [​IMG][​IMG]
    It hasn’t been off the ground in 30 plus years.
    [​IMG][​IMG]
  5. Casey Riley
    Casey Riley
    from Minnesota
    Holy **** that looks like a task. I like it. Congratulations.
    Kustomkid likes this.
  6. King ford
    King ford
    from 08302
    It's a project but QUITE DOABLE!..will be a COOL ride when done...why does the rear axle look uncentered in the fender openings?
  7. Kustomkid
    Kustomkid
    from Montana
    The driver side is missing the drum, so it’s just sitting on the axle.
    King ford and biggeorge like this.
  8. woodbutcher
    woodbutcher
    :D This looks like a whole lot of fun.I`ll saddle up and go along for the ride.
    Good luck.Have fun.Be safe.
    Leo
    Big AL Neenyo likes this.
  9. Fabber McGee
    Fabber McGee
    What a pain in the *** to find. This must be where the step van thread wound up too. Apparently nobody can find it anymore, because it was very active and now I get one or two notices a year that someone has replied.
    Anyway, cool bus. It really is a short one. Small as it is, you shouldn't need very heavy springs and axles. I'm on the watch list now, so hopefully I won't lose it.
  10. rudestude
    rudestude
    I had a 1950 Chevy short bus for years took it every where....lots of miles of fun , plus 3 different engines 216 235 even had a 270 Jimmy in for awhile with the low gears and the Jimmy stop light to stop light surprised a few want to be hot rodders..... IMG_20190110_025049_1~2.jpeg IMG_20190110_025109_1~2.jpeg
    Sent from my QTASUN1 using The H.A.M.B. mobile app
  11. rusty1
    rusty1
    ...here's one I sketched up...
  12. Kustomkid
    Kustomkid
    from Montana
  13. Kustomkid
    Kustomkid
    from Montana
    You had a cool bus! Was it a Superior body?
    VANDENPLAS likes this.
  14. Kustomkid
    Kustomkid
    from Montana
    Got the a few more pieces dug out for it. Was happy I found the fuse cover and the mirror. Got to find the bar for behind the drivers seat. [​IMG]
    There a junkyard an hour west of me that has a long 46 Chevy Superior bus that I’m hoping I can get the heater and some more of the inner sheet metal out of for the roof. Need to find the lower door hinge for the closer so I can get both doors working.
    Okie Pete likes this.
  15. rudestude
    rudestude
    You know I'm not sure if it was or not I never found a plate on it but it seemed to be like the superior body's exception being the two stainless strips down the side of the body it's the only one that I have seen like that most are like yours with the three bump rails on the side.....you got to stay on that thing your going to have so much fun when it done.... I went everywhere with mine every weekend camping , parting I and a group of friends took it to a Andrew Dice Clay show one night pulled right up front of the big concert hall in line with limo's when we got to the door the valet was afraid to try parking it so I had to park it myself...but he did tell us to see a guy in back when we parked and he would help us out ... He got us in a back door that by p***ed the crowd ...cool... I've posted a couple of shots of the bus showing what fun you can have...... IMG_20190117_212811_1~2.jpeg IMG_20190117_213008_1~3.jpeg IMG_20190117_212859_1~2.jpeg IMG_20190117_212950_1~3.jpeg IMG_20190117_212934_1~2.jpeg IMG_20190117_213027_1~3.jpeg
  16. charleyw
    charleyw
    Subscribed, love seeing all that F-series sheet metal.
  17. Kustomkid
    Kustomkid
    from Montana
    Found the signal lights for the roof. Might make good extra brake lights. [​IMG][​IMG][​IMG]
  18. Kustomkid
    Kustomkid
    from Montana
    Got the front end sheet dug out and partially installed. [​IMG][​IMG][​IMG][​IMG]
  19. atch
    atch
    If you don't have the headlight buckets let me know; I've got some extras you can have.
    And someone who is chopping an F-series truck needs that roof section that's laying there.
    Peanut 1959 likes this.
  20. scotts52
    scotts52
    Or turning a shoebox into a ranchero. :D
  21. atch
    atch
    Odd you should mention that. When I was getting ready to chop Clarence I seriously considered getting the back half of a pickup cab and making a Ranchero out of the panel truck. This was before Photoshop and I cut-n-pasted several times to see if it would look "right". In the long run I chose not to do it. I think I made the right choice.
    Now back to this cool bus...
  22. Kustomkid
    Kustomkid
    from Montana
    Alittle snow...[​IMG]
  23. Kustomkid
    Kustomkid
    from Montana
    I do have the head light buckets. I don’t have the headlight rings for it.
  24. atch
    atch
    I'll look around; I think I might have a couple of those too.
    VANDENPLAS and Peanut 1959 like this.
  25. Kustomkid
    Kustomkid
    from Montana
    Went and looked at this bus today. Lots of parts...[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  26. Chrisbcritter
    Chrisbcritter
    Really loving this project! Do you have any history on what school district used it?
  27. Kustomkid
    Kustomkid
    from Montana
    I’m not sure. Would have to guess school district 2 in billings. But there are some smaller districts in billings along with an old school on the outskirts of town. The bus was moved from the original wrecking yard from the 60’s.
  28. Kustomkid
    Kustomkid
    from Montana
    Got some nos signal stat lenses for the original rear taillights. Found some reflectors and screws so those are in. [​IMG]
    Got tomorrow off so I’m going to hit the wrecking yard again and see if more of the panels will come out.
    Okie Pete, Big AL Neenyo and scotts52 like this.
  29. rudestude
    rudestude
  30. rudestude
    rudestude
