Technical It just takes Balls or No Brains
Discussion in 'The Hokey Ass Message Board' started by ct1932ford, Jan 27, 2019.
  1. ct1932ford
    ct1932ford
    Anytime you drill, saw into a finished paint job you are asking for trouble. I remember chopping my Model A back in the 70's. It was a finished car that I became bored with and wanted to chop it. The first cut was like cutting into my arm.:eek:
    Well I had that same feeling yesterday drilling into the sides of my roadster. I wanted to ad side curtain body sockets. Drilling that first of eight holes was a hold your breath moment. I probably made more of it than I should. Here are the results. Thanks to Eric Justus for supplying the measurements off his original beautiful Deuce Roadster.:cool: Got to love the HAMB.:) IMG_4346.JPG IMG_4348.JPG IMG_4352.JPG IMG_4350.JPG IMG_4356.JPG IMG_4358.JPG IMG_4362.JPG IMG_4368.JPG
  2. da34guy
    da34guy
    Dun good.
    Deuces and lothiandon1940 like this.
  3. Stogy
    Stogy
    Measure twice drill once or is measure 3 times...:confused:...sometimes no matter what...you get that feeling...and then there's the Other Side and don't forget its mirrored...
    So did they just pop in, screw in I can't imagine there was a hammer involved?
    They look great @ct1932ford
    Deuces, clem and chryslerfan55 like this.
  4. treb11
    treb11
    No guts, no glory !
    Deuces likes this.
  5. Rickybop
    Rickybop
    Ooooh...you're a brave man...lol. Good job.
    I wanna see it with the top on.
    Deuces, clem and Stogy like this.
  6. Rickybop
    Rickybop
    I would'a been tempted to tape the whole damn thing off...twice.
    Don't feel alone in your apprehension. My mind always goes to possible tragedy. Like imagining running the drill across the whole body like Steve Martin did with the buffer in The Jerk. :eek:
    But you didn't do that...lol.
  7. flynbrian48
    flynbrian48
    I'd have drilled just one in the wrong spot by a couple of mm no matter how carefully I laid them out... Nice work, and you're a brave man.
    ct1932ford and Deuces like this.
  8. belair
    belair
    Not many things I like better with the top on... but good job on the roadster.
  9. olscrounger
    olscrounger
    Nice job-always scary to drill on a finished car. Have done it a few times and get very nervous!!
  10. Stogy
    Stogy
    Then there's peelin' the tape off...:eek:
    blowby, The37Kid, Deuces and 4 others like this.
  11. olscrounger
    olscrounger
    ^^^ yep! Gotta drill on a 39 woody pretty soon-on the body metal and the woodgrain dash as well-makes me very nervous.
    ct1932ford, Deuces and Stogy like this.
  12. HOTRODPRIMER
    HOTRODPRIMER
    You hot rod hoodlum, you just gotta drill holes in pristine 87 year old sheet metal! :D
    It appears you succeeded without so much as a chip in the paint. HRP
    warhorseracing, ct1932ford and Deuces like this.
  13. oldiron 440
    oldiron 440
    There's always more paint.....
  14. GordonC
    GordonC
    Nice job! Are those little pop in caps for when you aren't using the side curtains? I have the holes for side curtains in the doors of my 31 and wondered if there was something I could put in there? That looks like the ticket! Where did you get them if I may ask?
    ct1932ford, chryslerfan55 and Stogy like this.
  15. Hot Rods Ta Hell
    Hot Rods Ta Hell
    High pucker factor for sure. Nice job!
  16. jimmy six
    jimmy six
    My 56 came with a radio but no antenna. The gentleman who built the car was going to put in on the rear fender which was an option. He didn't use the original front fenders so there was no hole on the right near the windshield. I bought a replacement front antenna, marked the hole, got out the saw. then said screw it and mounted it under the right door on the frame on a bracket I made.....Couldn't drill the hole and it makes it easier to put on the cover in the garage....no guts...
    ct1932ford, Stogy and chryslerfan55 like this.
  17. Shamus
    Shamus
    from NC
    I have used hidden/under dash antenna on a couple of vehicles with good results.
  18. Shamus
    Shamus
    from NC
    Meant to say I have been reluctant to drill my doors for the side curtains but got side tracked. Guess they'll last longer in the box. Really haven't needed them (yet!).
    ct1932ford and Stogy like this.
  19. pumpman
    pumpman
    Nice job, one that would make my hands shake so much that would have to sit down and rethink the whole deal. No pun intended.
  20. nochop
    nochop
    from norcal
    I cut it twice and it’s still too Damn short
  21. HOTRODPRIMER
    HOTRODPRIMER
    Side curtains? We don't need no stinkin' side curtains! :D HRP
    scott27, wraymen, nochop and 4 others like this.
  22. jimgoetz
    jimgoetz
    For your sake I hope the side curtains were made right.
  23. ct1932ford
    ct1932ford
    Yes, there is a hammer involved but not much force, just a light touch with the punch.
    nochop, chryslerfan55 and Stogy like this.
  24. ct1932ford
    ct1932ford
    I figured tape may be an issue pulling off paint around holes, so I laid the tape out on a table first and did all the measuring there. The tape was not that sticky that way.
    Stogy, chryslerfan55 and olscrounger like this.
  25. olscrounger
    olscrounger
    Nice job--I run the tape across my pants leg a few times to take the sticky away somewhat too
    The37Kid, Stogy and ct1932ford like this.
  26. ct1932ford
    ct1932ford
    Joe's Antique Auto. Page 100 in his online catalog. Let me know if you need more info!
  27. ct1932ford
    ct1932ford
    The side curtains will be made to fit. That is if I ever get them made.o_O The top on my roadster is always down, sometimes even in the rain.:oops: I just wanted the car to look right.:cool:
  28. GordonC
    GordonC
    Thanks ct1932ford! I just checked out the online catalog and found them. I appreciate it!
  29. edcodesign
    edcodesign
    Nice job you still got it !
    ct1932ford likes this.
  30. ct1932ford
    ct1932ford
    You will like dealing with Joe's! Good people. Tell them Mark from Connecticut sent you!
    GordonC likes this.
