Projects 1930 Sportster, shortened cockpit, tilted post cowl, door caps.
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Dec 16, 2017.
  1. sloppy jalopies
    sloppy jalopies
    hee-ya ! ... guess that is sposta be yee-ha !
  2. sloppy jalopies
    sloppy jalopies
    The chrome vynal comes in a 12" wide roll, 60" long... $8.79, shipped ... '40 dash needed 11" x 4.5" strip...
    adhesive backing, stuck on...
    partially trimmed...
    back side...
    trimmed...
    propped up...
    tb33anda3rd and brEad like this.
  3. sloppy jalopies
    sloppy jalopies
    the duke of durham dropped off a stack of wooden model A upholstery backing panels... now I have to finish a place for them...
  4. vtwhead
    vtwhead
    Smitty, you will have lots of room after you send me my wood kit:):):):)
  5. sloppy jalopies
    sloppy jalopies
    you have not seen my garage... bought a brand new carb cause I can't find the one I bought last year... in a white box mind you...
    nunattax and wheeldog57 like this.
  6. sloppy jalopies
    sloppy jalopies
    Lil'Alb, tb33anda3rd, ABONES and 3 others like this.
  7. dumprat
    dumprat
    from b.c.
    That looks pretty!
  8. sloppy jalopies
    sloppy jalopies
  9. shadetreerodder
    shadetreerodder
  10. sloppy jalopies
    sloppy jalopies
    not running the '40 dash... jumped over to a narrowed '51 truck... DSCN3836.JPG
    brEad, Dyce, wheeldog57 and 2 others like this.
  11. sloppy jalopies
    sloppy jalopies
    picked up a '30 cabriolet cowl for $100...
    gonna cut off the top couple inches of the posts and header and splice it onto my coupester cowl for the
    tb33anda3rd, Stogy and Dyce like this.
  12. sloppy jalopies
    sloppy jalopies
    Thinking of reducing the '30 sportie's ****pit size,
    its tulip is 5" long, '30 roadster is 10", ['28 is 11.375"].
    cutting and sliding the upper quarters forward 5", then fill the new trunk quarter "gap", [gotta add 5" to the upper quarter at the tulip]…
    I cut it at the arrow, as the smaller beltline bead is straight further forward...any further back and the smaller bead arches downward...
    The bead along the bottom of the '30 - '31 coupe's lower panel is about 1" wide,
    the trunk bead is about 3/16" wider and tapers...
    both have a similar arch... '30 roadster has an extra ripple in the ****pit bead...
    '30 sportie and '28 roadster do not...
    '30 - '31 lower panels are about $100... much cheaper than quarters...
    .... roadster tulip … extra ripple.
    Any chance one of you guys with computer skills could photo shop the tulip panel, in the pic below, move it ahead 5", the section with the 5, is 5" for reference... DSCN3859.JPG
  13. vtwhead
    vtwhead
    So, why are we thinking of doing this? I am not clear on why and what is gained. I am certain you have it all in your head but I can't seem to find it in mine:rolleyes:. Won't you be giving up five inches of valuable leg room?
    Stogy and F&J like this.
  14. Atwater Mike
    Atwater Mike
    Aww, 'can the comfort'...Gotta get that Long bustle Roadster look!
    Study the Sport Coupe's 'abrupt' dropoff at rear, then recall the flowing rear of a roadster... (roadsters were drawn this way to resemble an expensive 'boat-tail' from side view) Edsel approved, and the Model A quickly climbed out of the 'style-less pit' so deeply dug by the Model T!
    But, yep... It's gonna get short in there, I'll give ya that!
    Too many 'A' roadsters for these legs' memory!
  15. sloppy jalopies
    sloppy jalopies
    it makes the sportie ****pit much closer to the roadster's in size... the large sportie ****pit looks a little like a coupe with the roof cut off...
    the bodies will be the same length, just longer doors and shorter quarters...
    plus so many coupsters have the roof cut off and not many other customizing touches...
    there is a thread here about making a roadster out of a sportie… can't be done but could make a fun rod along the way...
    this is kind of a how to in case another rodder wanted to cut loose...
  16. The37Kid
    The37Kid
    Sketch in a Top so you can see how much better it will look with a shorter blind quarter. Bob
    Stogy likes this.
  17. sloppy jalopies
    sloppy jalopies
    bingo...
    but I can't sketch on here...
    but that is why I asked if someone can photo shop to the shorter bodied version... maybe with a top on it ?
    Stogy likes this.
  18. Stogy
    Stogy
    I'd give a whirl but I'm beat tonight...I'm a little confused with the blueprint too...it' making my eyes go funny...:D
    Is that curved section coming forward 5"?
  19. sloppy jalopies
    sloppy jalopies
    yes that's it... thanks stogy...
    Stogy likes this.
  20. sloppy jalopies
    sloppy jalopies
    It makes the w/s posts too wide for the windshield - 1"... trogger bought the cowl to make his own duval style...
    got a non ford w/s frame in a trade, 1" wider than an A... got a few '30 cowls, may try next summer.
    have a decent pair of '28-'29 stantions, gonna try them on a '30 closed car cowl for size...
    Stogy and D-Russ like this.
  21. Stogy
    Stogy
    Here's some inspiration Sloppy not that you really need any...;)...as you have it built into your creative mind...I did add a mod to the front of the door as well to blend into the dash...
  22. sloppy jalopies
    sloppy jalopies
    thank you stogy...
    seeing it seems much better than thinking it...
    as for the doors I have THOUGHT about having them curl up to the cowl...
    thanks again
    Stogy likes this.
  23. Stogy
    Stogy
    Your welcome...
    Sloppy at the fwd end of the door what I tried to illustrate was the top of the door remains as it was, it is just extended over and flows around the curvature of the dash and gently flows back into the door...a couple of crude sketches to illustrate...keep in mind of course you are the one who decides...I'm just thinking out loud...;)
    tb33anda3rd and 46international like this.
  24. sloppy jalopies
    sloppy jalopies
    Thanks bud... emailed your photo shoppage to a buddy... loves it !
    Another buddy has been bugging me to bend up [4] *90s - 3/4" x 3/4" x 4" long of 18 ga. …
    bring them over so we can shrink - stretch them, so they resemble the '28's configuration but curl up just before the cowl post... because of the jaw width i'll have to weld 2 together to make the door CAP...
    haven't decided on weather I will add them or not...
    HOLD the PRESSES... corn fed bailed me out with some quarter s****s...
    thanks!
    brEad and Stogy like this.
  25. Great idea on the front of the doors.
    Stogy likes this.
  26. Stogy
    Stogy
    Thanks...the idea was being tossed around already and I just threw in my take.
    It's common to do some kind of mods on these Coupe conversions around the dash area including numerous others involved in the creation process.
    Again this truly is walking in a world of vintage design thats for sure...cut, chop, bend, add, subtract...that's where the name The Tadd 5 came from take a 5" tad and add a 5"tadd here and there and voila...Jalopy Hotrod...:D
    If you look at the quarter where I cut and spliced it appears to look like Tadd 5
    46international likes this.
  27. Stogy
    Stogy
    There are alot of Hambers here like Sloppy who take discarded or lesser desired models and create sharp looking functional Hotrods/Customs...its quite the sight to witness.
    UNSHINED 2, vtwhead and nunattax like this.
  28. sloppy jalopies
    sloppy jalopies
    I was originally thinking of curling the leading edge of the door up AND in, like '30 to '36 roadsters...
    didn't see how without cutting up a pair of roadster doors and a dashrail...
    Stogy and slv63 like this.
  29. nunattax
    nunattax
    how about finishing the ****pit with a nice piece of hardwood. you might not get it right first time but would look great imho.
  30. sloppy jalopies
    sloppy jalopies
    I can weld razor blades... but can't drive a nail !
    RICH B, triumph 1 and Stogy like this.
