Projects 65 Ranchero Southeast Gasser build
Discussion in 'Traditional Hot Rods' started by colbyw, Dec 28, 2017.
  1. Gammz
    Gammz
    from Lincoln Ne
    A box [emoji403] sorry couldn’t resist [emoji23]
  2. colbyw
    colbyw
    Axles came in. My bad[emoji23]
    Thor1, enloe, saltflats and 2 others like this.
  3. colbyw
    colbyw
    [​IMG] [​IMG][​IMG][​IMG]
    Mounted the fuel cell, floor supports, and the steering dampener. And now we’re finishing the welding on the frame and getting it closer too paint.
    Thor1, catdad49, Dog_Patch and 8 others like this.
  4. Hang'emHigh
    Hang'emHigh
    Not enough attaboys in this thread. Great job guys! Can't wait to see this one in person!
    Thor1, enloe, loudbang and 1 other person like this.
  5. Gammz
    Gammz
    from Lincoln Ne
    Thor1, loudbang and colbyw like this.
  6. 6sally6
    6sally6
    How old did you say you were , kid?
    Nice weld beads AND fabrication. Keep up the good work. I check in everytime you post new stuff!
    6sally6
    Thor1, brEad and loudbang like this.
  7. colbyw
    colbyw
    I just turned 16 last week. My dad does most of the welding and fabricating with me so that’s why it looks so good.
    Thor1, Dog_Patch, OahuEli and 3 others like this.
  8. 6sally6
    6sally6
    Yep! Dads are like that sometimes.
    6sally6
    Thor1, OahuEli, enloe and 1 other person like this.
  9. rocketsled59
    rocketsled59
    Impressive work! I dig it
  10. rawcjw19
    rawcjw19
    Don’t let the kid fool you. He has welded quite a bit of it. A lot of his welds look better than mine. We both have some ugly ones. He is a very talented intelligent kid. Not much he can’t do. I am proud of him.
    Chucky, 34 5W Paul, Thor1 and 15 others like this.
  11. southcross2631
    southcross2631
    Looking really good. Keep plugging away at it. I am getting little things done on mine.
    Thor1, enloe, rawcjw19 and 1 other person like this.
  12. colbyw
    colbyw
    Good deal, it’ll all come quick.
    Thor1, enloe and loudbang like this.
  13. Doctorterry
    Doctorterry
    Impressive work, and time frame. I hope to hang out at the track and see you guys race this year!
  14. colbyw
    colbyw
    [​IMG][​IMG]
    Ran the brake lines. Gonna get the frame painted this weekend.
    Thor1, rally1, catdad49 and 8 others like this.
  15. DILLIGASDAVE
    DILLIGASDAVE
    I like it, more Ranchero G***ers the better IMO.
    Since it has a fairly short rear panhard bar length you're probably going run into some amount of side loading/binding pull toward the driver side during rear suspension travel. If the side loading pull distance isn't too bad then it's probably nothing to worry about. If you feel it's a little on the excessive side you can preload it toward the p***enger side (a little) at ride height to offset some of the pull distance toward the driver side during rear suspension travel.
    The good thing is if you did decide you need to use a longer panhard bar length in the future (to reduce the side loading/binding as much as possible) you look to have plenty of room for a longer bar the way you designed the ch***is.
    Thor1, Doctorterry and loudbang like this.
  16. colbyw
    colbyw
    [​IMG]https://www.jalopyjournal.com/mobile-gallery/ffc10337bfb57e52bfc9808944adc0ce.jpg[/IMG
    The frame is painted.
    Chucky, Thor1, catdad49 and 10 others like this.
  17. saltflats
    saltflats
    from Missouri
    Looks nice.
    Question, can you get away without having down bars to the rear, or you welding them in after the body is on?
  18. rawcjw19
    rawcjw19
    We have to weld them in when we set the body down. We will have a little touch up paint to do. I have a lot of respect for body shops. Painting the cage was awful. I am to fat and my arms are too short [emoji3]
    Thor1, Dog_Patch, loudbang and 2 others like this.
  19. colbyw
    colbyw
    More paint done
    Thor1, catdad49, Dog_Patch and 6 others like this.
  20. colbyw
    colbyw
    [​IMG][​IMG]
    Sprayed the door and window jams the body color so that we can do the headliner and get the body put on the frame.
    Thor1, Dog_Patch, enloe and 6 others like this.
  21. DILLIGASDAVE
    DILLIGASDAVE
    Maybe it's an optical illusion but it kinda looks like the brake line might either be resting on the panhard bar mount/bracket, or might end up resting on the panhard bar's rod-end or the rod-end's jam nut.
    If either is the case you might think about moving the brake line up a little just to keep the tech inspectors happy. Some inspectors get kinda cranky when it comes to brake lines and fuel lines that are run close to suspension components.
  22. colbyw
    colbyw
    [​IMG][​IMG][​IMG][​IMG]
    Put the body on the frame, installed the headliner, and welded on the rear bars for the cage.
    Thor1, catdad49, mkebaird and 9 others like this.
  23. 6sally6
    6sally6
    I sorta like the paint scheme the way it is now!!! Purple trim around with primer gray...very old skool cool!
    No kidd'in!
    6sally6
    Thor1, loudbang, colbyw and 1 other person like this.
  24. Gammz
    Gammz
    from Lincoln Ne
    Yeah man!!!!!!! Keep at it
  25. loudbang
    Purple Chevy EATER. :)
    Thor1, 1947knuck, catdad49 and 2 others like this.
  26. colbyw
    colbyw
    I’ve got a certain Chevy powered model A at the top of the list.
    Thor1, sonic03bluegt, OahuEli and 6 others like this.
  27. rawcjw19
    rawcjw19
    Kids. Keep dreaming. I will make sure the front of your Pink car looks extra special. Because that is all I will see in my mirror [emoji23]
  28. colbyw
    colbyw
    Started final ***embling some of the front end.
    Thor1, catdad49, Dog_Patch and 4 others like this.
  29. Doctorterry
    Doctorterry
    Man you sure get stuff done.. you make me feel lazy [emoji28]
    Thor1 and loudbang like this.
  30. rawcjw19
    rawcjw19
    All these school snow days. We hope to have it going by April with the street engine so we can get it certified and him some seat time. Shooting for an SEG event in May
    Thor1, Dog_Patch, enloe and 3 others like this.
