Technical glass fuel bowl mystery?
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Jan 27, 2019.
  1. tb33anda3rd
    tb33anda3rd
    was given this yesterday, it is brand new. the plastic plate on the inside tells me what it is for, but the question is why and how was it needed? IMG_4454.JPG IMG_4455.JPG IMG_4456.JPG IMG_4457.JPG
  2. tb33anda3rd
    tb33anda3rd
    the only thing I can think of would be a marine application?
  3. Hollywood-East
    Hollywood-East
  4. mgtstumpy
    mgtstumpy
    egads, loudbang, kadillackid and 4 others like this.
  5. Truck64
    Truck64
    from Ioway
    Or inline with vacuum wipers?
  6. tb33anda3rd
    tb33anda3rd
    ahhh thanks.
    I guess it still vents into the engine? the bowl would catch a leak and allow you time to get back to shore, without a dangerous leak.
    kinda cool, what d I do with it?
  7. upspirate
    upspirate
    E-bay if you have no use for it
    tb33anda3rd likes this.
  8. That's what I was thinking, but I've never seen it used in any application.
  9. jimmy six
    jimmy six
    image.jpeg When mines full of fuel.....everything is OK..
    mgtstumpy, loudbang, Geri and 3 others like this.
  10. bigdog
    bigdog
    dual diaphragm pump, that goes on the vacuum pump side. If you see gas in there there's a bad diaphragm in the pump.
  11. Mike Miller
    Mike Miller
    The engine in my boat had one, the color says Mercruser.
    mgtstumpy and loudbang like this.
  12. 302GMC
    302GMC
    from Idaho
    What d I do with it?[/QUOTE]
    Get a GF 124 AC filter, take out the discharge plug, & use as a fuel filter
    LOST ANGEL and tb33anda3rd like this.
  13. Rocky
    Rocky
    Classified Editor
    It can be used as a simple sediment bowl or slap a filter in it and use it as a filter.
  14. tb33anda3rd
    tb33anda3rd
    I was hoping it could be turned into a filter. it makes sense that they would make it out of "old" already available castings.
  15. Geri
    Geri
    these were very popular in the 40'/50's/60's came as standard equipment on many cars and many trucks.,tractors etc, they give you a first hand clue as to dirt etc in your fuel system. part of a tune up included removing the bowl and clean out the crud.
  16. 24riverview
    24riverview
    Marine application, mechanical fuel pumps in boats don't have the vent hole on the top side of the diaphragm. Any leakage through the diaphragm is caught in this housing on this type, the other type has a fitting and tubing which routes any leakage to the carburetor (shown). Gas fumes in an enclosed boat engine compartment are a bad deal.
    tb33anda3rd, Truck64 and egads like this.
