Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. D-Russ
    D-Russ
    Here's a little video from last August that Matt Hurley @Hurley50 just discovered in his stash. Enjoy!
  2. john mullen
    john mullen
    Thanks oj...
    loudbang, D-Russ and chryslerfan55 like this.
  3. john mullen
    john mullen
    0201191636.jpg I finished the head today and have the high tack sealer on the gasket ready for the head tomorrow .
  4. john mullen
    john mullen
  5. john mullen
    john mullen
  6. loudbang and Stogy like this.
  7. john mullen
    john mullen
    Someone asked me today if the revamped engine made so much power that I had to chain down the Valve cover. Lol I wish!
    See photo above..Lol
  8. john mullen
    john mullen
    Of finally found time to install the ****** to the engine.turbo 350 w/lockup 0222191448.jpg 0222191449b.jpg
    Just Gary, loudbang, Stogy and 2 others like this.
  9. AmishMike
    AmishMike
    Did u consider one of the overdrive trans? Why not use? Is there enough room to use & get up to speed?
    loudbang, Stogy and chryslerfan55 like this.
  10. jimmy six
    jimmy six
    3 miles at times is not enough and this cl***/engine combo will probably never qualify for the 5 mile.
    In my humble opinion of running Bonneville since 1975, overdrives need a lot of engine to work; their split is just too much and they cost HP.
    I do use an OD made from a Tex 101A 4 speed with the 3 gear being an OD. You just turn the 3/4 level upside down. Back when NASCAR allowed OD's these were called Pocanos. My OD is only .96 and I can buy the gears to make less or more.
    The change to a 3 speed is definatly going to help in Johns attempt for a record in the cl***.
    I know this sounds as improbable as impossible but the Ford/GM 10 speed automatic has 7th as 1 to 1 and it would be great to use 6 lower gears getting to it keeping the engine right where you want it. It not known to me the HP to run something like it and its size is gigantic to the older transmission... But who knows what the future will hold.
  11. john mullen
    john mullen
    Its official !!
    The Virginia H.A.M.B. Special will attend the April 24 25 26 2020 ECTA EVENT IN Arkansas. This event is a standing start 1 mile course. For info on this event go to ECTA home page at www.ECTA.net home page or pm me and I will answer your questions
    John mullen/Team owner
    XO/PP 640
  12. D-Russ
    D-Russ
    Can't wait!!!!!
    loudbang, chryslerfan55 and Stogy like this.
  13. For those about to rock, we salute you.
    Stogy, D-Russ, loudbang and 1 other person like this.
  14. greybeard360
    greybeard360
  15. john mullen
    john mullen
    The crew work day getting the Virginia H.A.M.B. Special ready for the Arkansas mile in April.
    Thanks Dave, Dan, Lee, and Sam.
    Sorry Dan wasn't in the photos as he spent the day readying the hauler. Every thing reorganizinged and labeled. Thanks guys you are so appreciated. 0125201527a.jpg 0125201526_Burst04.jpg 0125201526b.jpg 0125201526d.jpg
    saltflats, catdad49, loudbang and 3 others like this.
  16. john mullen
    john mullen
    Update
    Added 3 more springs to the rear, new rear shocks going on, removing 600 lbs of weights from over the rear ( used at Bonneville )
    Not needed on the asphalt at ECTA Arkansas mile.
    More to come as the crew prepairs the Virginia H.A.M.B. Special for the asphalt
    Stogy, Just Gary, D-Russ and 3 others like this.
  17. catdad49
    catdad49
    Why is that young man smiling with the powertool?!
    Stogy and loudbang like this.
  18. saltflats
    saltflats
    from Missouri
    Good luck.
  19. john mullen
    john mullen
    I think it's from the lack of twenkies...
  20. trollst
    trollst
    Made my hitch for my 36 yesterday, today is hookup the teardrop, feel everything out, next is fitting an awning so some shade will be available, can't wait, see you there. LeRoy.
    Stogy, RMR&C, loudbang and 1 other person like this.
  21. john mullen
    john mullen
    Hear are a couple photos of the modifications done to free up the sway bar as the rear end moves up or down. It's now free from binding up the rear sway bar. The Virginia H.A.M.B. Special will handle much better with this modification to the rear new shocks will be added in a couple days
    Stogy, catdad49, loudbang and 3 others like this.
  22. john mullen
    john mullen
    I'm building a blown small block Chevy to be sold to fund the XO/PP 640 project.
    This is a high end build with forged pistons, h beam rods, steel crank, sevier duty Stainless Steel valves, roller rockers, Erson camshaft designed for blower applications, port matched heads, .030 over MSD billet dizy,
    This engine will be run in and turned. I'll have a video of the break in to follow in a few weeks. Hear are some pics as it is coming together 20200228_142029.jpg 20200228_141848.jpg 20200228_141750.jpg 20200228_141718.jpg 20200228_141710.jpg
  23. john mullen
    john mullen
    This engine will be very steertable and reliable every part that moves is new. And will be turn key ready. PM me if interested.
    lothiandon1940, D-Russ, Stogy and 2 others like this.
  24. john mullen
    john mullen
    Some updates on the XO/PP 640 parachute anchor, reworked tailgate and paint relocated the shifter for driver 20200321_122507.jpg 20200323_172401.jpg 20200323_172056.jpg 20200327_134241.jpg 20200330_122429.jpg
    D-Russ, catdad49, loudbang and 5 others like this.
  25. Nailhead Jason
    Nailhead Jason
    Any chance you have another one of those blowers laying around John?
  26. john mullen
    john mullen
    More mods, new shocks and freed up the sway bar parachute mounted 20200219_095059.jpg 20200226_085210.jpg 20200323_172056.jpg 20200323_172401.jpg 20200321_105449.jpg
    Just Gary, D-Russ, catdad49 and 4 others like this.
  27. john mullen
    john mullen
    Sorry Jason only the one
  28. catdad49
    catdad49
    Love the upper shock mounts! And everything else.
    lothiandon1940 and loudbang like this.
  29. D-Russ
    D-Russ
    Awesome John – the tailgate, shifter, parachute, everything looks good! The pandemic isn't keeping you down.
    Need help?
  30. Ya know John, I’m beginning to think you feel the need, the need, for speed.
