  1. jeepsterhemi
    jeepsterhemi
  2. jeepsterhemi
    jeepsterhemi
  3. jeepsterhemi
    jeepsterhemi
  4. jeepsterhemi
    jeepsterhemi
  5. jeepsterhemi
    jeepsterhemi
  6. jeepsterhemi
    jeepsterhemi
  7. jeepsterhemi
    jeepsterhemi
  8. jeepsterhemi
    jeepsterhemi
  9. Deuce Daddy Don
    Deuce Daddy Don
    chryslerfan55, Dave Mc and Bleach like this.
  10. Deuce Daddy Don
    Deuce Daddy Don
  11. Deuce Daddy Don
    Deuce Daddy Don
    WHERE?
    chryslerfan55 and Bleach like this.
  12. dana barlow
    dana barlow
    from Miami Fla.
    It's about timing;If this is in the 50s or 60s,then the cars on the road with this hotrod would have drum brakes=lite hotrod with only big drums on rearend ,but no front brakes can stop as good as the other cars for the most part. Today to run no front brakes on any hot rod,with most cars around it having four wheel disk= high danger of crash. Death Wish
  13. jimmy six
    jimmy six
  14. Marty Strode
    Marty Strode
    I should have worded my response differently. You are correct the integral cab option ran 61-63, however, the 64 cabs appeared the same as 65-66. The the difference was in the floor, that was lowered, and didn't have the step well in the door opening. Ford used the 64 cabs on the 4 wheel drives in 65-66 because of the raised floor. BTW, I sold a 64, and bought a 65 that I have been driving since 73.
  15. jeepsterhemi
    jeepsterhemi
    Don't know when this car was built, it was in the first Street Rod Pictorial of 1969. Truman Jensen was/is the owner.
    dana barlow and Bleach like this.
  16. sliceddeuce
    sliceddeuce
  17. jeepsterhemi
    jeepsterhemi
  18. jeepsterhemi
    jeepsterhemi
  19. jeepsterhemi
    jeepsterhemi
  20. sliceddeuce
    sliceddeuce
  21. jeepsterhemi
    jeepsterhemi
  22. jeepsterhemi
    jeepsterhemi
  23. jeepsterhemi
    jeepsterhemi
  24. sliceddeuce
    sliceddeuce
  25. Bleach
    Bleach
    I had a 63 and I used to scavenge 61-66's for parts inside and out. I knew fairly well what worked and didn't between the years. I never really noticed the missing stepwells in the newer truck cabs.I thought the only "big" difference was the dash.
  26. blowby
    blowby
    from Nicasio Ca
  27. dan c
    dan c
  28. dan c
    dan c
    loudbang, Samj, chryslerfan55 and 2 others like this.
  29. dan c
    dan c
