Customs found this Chadly Johnson article and after the fact build thread on my bubbletop Futurian
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Jan 29, 2019.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    Words & Photos: Chadly Johnson
    Ed Roth built some of the wildest and most influential show cars in history. Ed's creations have inspired countless builders over the years, but few as strongly as Minnesota's own Mark Moriarity. Mark's passion for Ed's show cars led him to purchase Ed's “Rotar” bubble top show car. After owning the Rotar, Mark had to have another, so he located and purchased the “Road Agent” and lovingly restored the show piece to equal its early glory years. This led to owning several more of Roth's creations. While being surrounded by, restoring, and showing Ed's cars Mark was inspired to tackle his own one-off creation... plus, he couldn't locate or afford any more of Roth cars. Mark figured if Ed could do it, so could he. Mark stated one of Ed's mottos was “Big mess, big success,” and Mark was really good at making a mess... so the “Futurian” build was on.
    Mark had the Road Agent at his home at the time he began the Futurian so he was able to reference its chassis. A similarly styled frame was built out of 2” round mild steel tubing. A raw 62 Buick aluminum 215ci engine was set in the chassis, and it was made a roller with a set of Radir wheels. With the engine and wheels giving a crude template for body dimensions, Mark started throwing the body together. The basis for the body's shape was a mixture of 60% vermiculite and 40% plaster soaked newspaper. Once a big enough blob was made, Mark would shave the mixture down with a cheese grater for a general shape, then repeat over and over again. Mark states that when his buddies would stop by during this phase of construction they would tell him “get ride of it, and don't show anybody!” To keep things symmetrical Mark would use cardboard templates to match one side to the other. Mark had never done anything like this before, but he referenced Roth's “how to” books on working with plaster to build bodies.
    After an itchy mess that would have driven many people to give it up as a bad job, Mark emerged with a satisfactory body shape. When I asked Mark if he had a drawing to refer to when constructing the body he stated that he can't draw anything, so most everything happened by accident. Mark simply sculpted as he went, then stood back and did a lot of staring. Once satisfied, he laid fiberglass over the carved plaster, allowed it to harden, then knocked the plaster out of the fiberglass to reveal a body. During the long battle with forming the one-off body, photos of the project were published by Jerry Weisner in Custom Rodder magazine. Mark stated that difficult and messy as the process was, people now knew about the project as it was printed in a magazine, so he knew he had to keep going.
    Now that Mark had a body on a rolling chassis he had many questions, like what to use for taillights, grille, steering wheel, etc. Then it struck Mark that since he had literally just built a one-off body, it would not seem right to use a bunch of components from pre-existing cars... he would have to build the rest of the components as well. So Mark got busy hand fabricating nearly all the miscellaneous pieces for the Futurian, resulting in components that are pieces of art, unique in design.
    When it came it to building one of the most visually critical components, the bubble top, Mark turned to Masterglass out of Lakeville, MN. Masterglass had****isted Mark when he crafted a new bubble top to replace the cracked one on the Road Agent. Compressed air was pumped into a plywood mold built by Mark to a heated sheet of 1/4” thick G.E. Acrylite acrylic. For three attempts the top would almost be fully formed only to deflate due to a sharp point in the mold. Mark would sand the mold smoother and smoother until the fourth attempt proved successful. 57 Chevy convertible top hydraulics scored at a swap meet open and close the bubble top.
    Another massive undertaking was due to the fact that the Futurian is dripping in chrome. Mark performed all the polishing on the steel components prior to chrome plating himself... mostly, Mark said, because he's cheap. If you have ever prepped a piece of metal for chrome plating before you know that the metal has to be so perfect that it already appears chrome plated before you send it off to be chrome plated. Now imagine polishing all the components on the Futurian! The aluminum components such as the Crager-driven blower were sent off for chroming.
    When it came to painting the body, Mark handled the paint gun himself right in his own garage, except for laying out the panels. That was handled by friend Dennis McPhail, and the pinstriping was laid down by Mike Iverson. The interior was also handled in-house, excluding the seats and door panels which were stitched by Bob's Upholstery.
    When Mark first began the Futurian build he took some advice from Ed Roth, which was to build a small car as they require less material, thus less cost, and they are easier to move around. Comparatively speaking the Futurian is a small car, but I can testify that its*****pit is very comfortable as I had the privilege of sitting inside it. Mark is always very generous when it comes to allowing people to enjoy his creations and restorations.
    Shortly after its completion the Futurian was loaned out to be displayed at Darryl Starbird's Museum. Once it was home again Mark put the Road Agent up for sale, and when Ralph Whitworth came to purchase it for America's Car Museum, he fell in love with the Futurian and ended up purchasing it as well. Mark was able to see the Futurian while it was out on tour promoting the construction of the museum and suffered from abandonment and sellers remorse, so a deal was struck allowing Mark to purchase back his hand-built masterpiece. The Futurian has been on display inside Mark's living room ever since. Yes, you read correctly: inside his living room, except for 2 years when it was displayed at the Gilmore Museum.
    Mark is an amazing guy, and a gifted builder, fabricator, restorer, and preserver of early show cars. Every time I get the privilege of stopping by Mark's home, he has a new project that he is resurrecting, but as far as the Futurian is concerned... Mark is happy to have it home, where it was built and belongs.
  2. Baumi
    Baumi
    A great read, thanks for sharing. I can only imagine what amount of head scratching and elbow grease it takes to build something like your Futurian from nothing, at home, by yourself.
    Awesome job, my hat´s off to you.
    Stogy, lothiandon1940 and Moriarity like this.
  3. continentaljohn
    continentaljohn
    A amazing car and even more amazing is the craftsmanship and talent of Mr Mark
    Stogy and Moriarity like this.
  4. LOST ANGEL
    LOST ANGEL
    You could say he has got it made!!:D:p
    John B, Stogy and Moriarity like this.
  5. BJR
    BJR
    All I can says WOW!! Nice write up. Nice car. One question though, does it run and drive, or is it like Roth's cars that it is a work of art that does not move under it's own power?
    chryslerfan55 and Moriarity like this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    It has everything it needs to be a car that runs, but I have never fired it. It lives inside my house and I don't want gasoline smells and oil spots on the carpeting... besides, it has no****le so I can't register it to drive on the street. When I owned the Road Agent I did drive it several times, so that is a roth car that drives
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    01BD3637-60AE-4086-A8F6-38B8A56479C7.jpeg It would have been pretty easy to quit at the point of the plaster and vermiculite stage. A few of my buddies told me to get rid of it before too many people see it...
    Tman, 54delray, David Gersic and 19 others like this.
  8. Texas Webb
    Texas Webb
    Is that where a"diamond in the rough" starts?:cool:
    Stogy likes this.
  9. oliver westlund
    oliver westlund
    wow! very inspirational, beautiful car and great article mark
  10. Max Gearhead
    Max Gearhead
    from Wisconsin
  11. olscrounger
    olscrounger
    Wow-amazing job!!
    lothiandon1940 likes this.
  12. dana barlow
    dana barlow
    from Miami Fla.
    COOL ......................
  13. ken bogren
    ken bogren
    That cool little car burned itself into my brain when I saw it at the 2002 GSTA show in St. Paul. Nice to read more about how it came to be and was built.
  14. Bandit Billy
    Bandit Billy
    Any pictures of it front of the diner? :cool:
    David Gersic, Stogy, drdave and 2 others like this.
  15. kidcampbell71
    kidcampbell71
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    Here is a pic in rough glass, with my daughter and myself posing for a Christmas card picture. Lots of itchy grinding. Most of which was done outside in hopes the wind would carry away the itching powder. This pic would be from 1998[​IMG]
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    haha no, but I do have pics of most of my cars there....
    54delray, Stogy, drdave and 3 others like this.
  18. DDDenny
    Hey Mark
    With all this extra time are you gonna take some cooking lessons and finally put your kitchen into service.o_O
    kidcampbell71, Stogy, drdave and 2 others like this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    no, It is like a contest now, to see how long I can go without using my Kitchen.....15 years so far
    Tman, 54delray, hrm2k and 8 others like this.
  20. K13
    K13
    Cool article. How long did it take you to build?
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    3 1/2 years
    54delray, Stogy and dana barlow like this.
  22. K13
    K13
    Wow that's quick for all the work involved.
  23. BrerHair
    BrerHair
    Too cool, most impressive. Beautiful little car!
    Moriarity likes this.
  24. GordonC
    GordonC
    Very cool!
  25. Bandit Billy
    Bandit Billy
    Courtesy of @themoose Now you do!
  26. Moriarity
    Moriarity
    SUPER MODERATOR
  27. Sky Six
    Sky Six
    from Arizona
    What a great story and what a great job. I am in awe of the workmanship and creativity used in this creation.
    And, you have a car in the living room... I had a panhead in the living room once but the wife was not amused.
    chryslerfan55, Stogy and Moriarity like this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    demmel, R A Wrench, John B and 14 others like this.
  29. stanlow69
    stanlow69
    kidcampbell71, Tman, catdad49 and 6 others like this.
  30. slowmotion
    slowmotion
    Geez, and all I ever did was keep a Sportster in the rec-room...small potatoes.
    Thanks for the read Mark, and I'll say it again, you're Batman!
