Projects '22 T BOBTAIL Distraction
Discussion in 'Traditional Hot Rods' started by The37Kid, May 22, 2016.
  1. The37Kid
    The37Kid
    For as long as I can remember I've had a T ch***is project, bit by bit I'd collect the bits and for some reason part with it as soon as it became a roller. Last weekend I collected the last missing link for a Bob Tail project, a pair of 26-27 rear axles. This isn't a build thread, just a parts collection, something to do when I'm not making progress on the Roadster or Steelback. Once the Chevy kickups get cut to shape and attached to the frame it will become another build, and take up more room. Bob
    Carter, ct1932ford, 29EHV8 and 3 others like this.
  2. The37Kid
    The37Kid
    Well, the '39 Ford pickup project was sold, and I'm moving stuff around in the ba*****t, the Bob Tail frame was sort of in the way, and I found the firewall under some stuff. Simple goal, install the rear kickups, add a set back front crossmember, and drill the holes to set the firewall back. Having a finished frame in primer hanging on the wall or ceiling would be a good thing.
    ct1932ford, brEad, loudbang and 2 others like this.
  3. The37Kid
    The37Kid
    That's what I'm after, bare bones 1920's T Dirt Track car. I've got all the bits except for wire wheels & hubs.
  4. Mr48chev
    Ok my friend you done drug me in. I have a feeling that this one is going to get interesting if we can keep you somewhat on task.
    sko_ford, brEad, loudbang and 3 others like this.
  5. The37Kid
    The37Kid
    I've got two pieces from another firewall that will be used to fix the one on the ch***is. I needed to scribe a line to guide the saw cut and rummaged through the top draw of my tool box looking for a 5/8 wide piece of stock. Found my Dad's name tag from when he was a cop in town back in the early 1960's. Nice to know he is still helping even though he's been gone for 35 years. Bob DSCF9781.JPG DSCF9779.JPG
  6. milo1303s
    milo1303s
    So many cool projects You need to finish something !!! lol
    sko_ford, slv63, loudbang and 3 others like this.
  7. The37Kid
    The37Kid
    Great day today, pulled out the front end parts. So glad the see the Chevy spindles, I thought I'd sold them.
    ct1932ford, Stogy, brEad and 2 others like this.
  8. Mr48chev
    From the Inland Emperors East/West flathead reliability run in 2013
    Outback, ct1932ford, BigO and 9 others like this.
  9. noboD
    noboD
    I hope you noticed what's in the backround. Like the Brothers said, some day all those Ford owners will want to drive a real car.
    Outback, The37Kid and Greg Stokes like this.
  10. rusty rocket
    rusty rocket
    I like it! I'm doing the same thing but a late 40s version.
    HunterYJ, Stogy and loudbang like this.
  11. The37Kid
    The37Kid
    That is why my 1912 Ford is so special, DB made most of the parts.;) The bronze underslung brackets need a perch bolt hole drilled in them. Something a retired guy with a Bridgeport could do. :rolleyes: Bob
  12. The37Kid
    The37Kid
    DSCF9829.JPG DSCF9830.JPG DSCF9831.JPG The Chevy kickups will get cut to match the T frame width If anyone has a good front crossmember I need to upgrade the one I have. Nice straight no rust pits id what I'm looking for. Bob
    Stogy, brEad and loudbang like this.
  13. The37Kid
    The37Kid
    sprint car 2 - 16 - 17 006.jpg If I'm going to copy, might as well have the best to copy from. :) Bob
    Outback, ct1932ford, duncan and 6 others like this.
  14. Commodoreswab
    Commodoreswab
    from West TN
    I see you are using Laurel style brackets. Have you found a source for bolts to replace the Ford perches? I am oing something similar and have not found a source yet. Without checking my notes I believe the bolt size to be 11/16 which is not available. Have you sourced a radiator yet? If so what?
  15. The37Kid
    The37Kid
    The front underslung brackets are ones I had cast 35+ years ago using original ROOF brackets. If I can't find bolts off the shelf I'll turn down a larger size and rethread them.
    Bob
  16. Commodoreswab
    Commodoreswab
    from West TN
    It would be interesting to see if there is a difference between Laurel and Roof brackets as I always thought that Laurel worked more on the ch***is and Roof on the engines. I do have a Roof head (8V) that in time I hope to actually reproduce.
  17. loudbang
    I just posted a Roof Cyclone head (not V-8) in the unusual Engines thread. Post 917
    1947knuck likes this.
  18. Corn Fed
    Corn Fed
    Chevy spindles? Do tell. I have the bare remains of a 40's era T based midget that I was wondering what to use for the front brakes.
  19. Yup, early Chevy ('27 and earlier) spindles fit the T axle (with a little reaming, if I'm correct?) and give you an extra 1/2" drop over '26/'27 T spindles :D
  20. The37Kid
    The37Kid
    Thanks! I've often wondered what year the Chevy spindles were. I think I'll replace the worn ball on the steering arm with a Ford ball that has a taper and nut to secure it in place.
    wood remover, Stogy and loudbang like this.
  21. Bob, I don't know if the 490 spindles will work, but '24-27 certainly will- 1928 was the first year for front brakes for Chevrolet.
  22. The37Kid
    The37Kid
    Thanks Mac, Just found these photos while looking for something else, sort of a good omen, it is the engine I'll put in the Bob Tail once it is gone through. It powered an ice cutting rig, found it in Westport Ct. in a garage one house behind one on the coast of Long Island Sound, back in 1997. It got flooded, note the high water line on the flywheel.
    ct1932ford, sko_ford, Stogy and 6 others like this.
  23. Atwater Mike
    Atwater Mike
    Bob...The Dayton Wheels (et al, truly 'vintage') have intrigued me for years.
    There was an elderly man down the side street from my Grandmother's that had an early dirt car, 'bobtail' type. Wheels were 3" wide at rims, and tall: 18"-20", multi-spoked, small hubs. (looked like the 40 spoke motor wheels mid-to-late '20s, non Ford)
    He told me the name of the mfr., can't remember...but it wasn't anything 'common'...
    I have a nice old mid-'20s DB I beam, and some 'T' stuff. Been threatening to throw it together, but wheels are a challenge. (have V8 wire wheels, but want something earlier)
  24. noboD
    noboD
    Are you sure it's not Bob Tale?
    bondojunkie and loudbang like this.
  25. The37Kid
    The37Kid
    Could be, and you can become part of it, I'm gathering up a small pile of future machine work. ;)
    Bob
    brEad, slv63 and loudbang like this.
  26. tb33anda3rd
    tb33anda3rd
    Bob, you have the coolest stuff.
  27. The37Kid
    The37Kid
    Thanks and if I keep wires away from it the chance of fires is fairly slim.:cool:
  28. The37Kid
    The37Kid
    Nothing major, just stripping the paint off the kickups, I like working with clean bare metal. Still a lot of **** in the ba*****t so a folding ironing table makes for a good work bench. It is a good one all metal Made in Italy.
    Bob
    ct1932ford, Stogy and kidcampbell71 like this.
  29. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Bob;
    Waiting patiently for the detailed how-to on Wiring-a-BobTail... :D .
    Lets, see: all mech gauges, magneto for the mill, hand-crank starting, acetylene headlights n taillights. Yup, about 3 wires, & 4 plug wires. :D . Go Cat, GO!.
    Marcus...
    Outback, The37Kid and brEad like this.
  30. The37Kid
    The37Kid
    I really don't want to think about that ****, it will kill any motivation . Static display in the goal, but 4 plug wires and a kill switch wire should do it if someone down the road wants to fire it up. I'll leave the ring gear on if someone wants a self starting fire. Bob
    Stogy likes this.
