Customs found this Chadly Johnson article and after the fact build thread on my bubbletop Futurian
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Jan 29, 2019.
  1. chevy57dude
    chevy57dude
    Extra points for the '57 Chevy 'vert motors.
    Moriarity and lothiandon1940 like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    57 chevy rear end too....
  3. Kan Kustom
    Kan Kustom
    The part that blows me away is that you can't draw. I can put anything I want in front of me if I have the materials and time but I can see it before and draw it. To make something . Most guys that aren't artists end up with something that looks all wrong. You are an exception ! WELL DONE !
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    thanks man, yeah I can't draw at all and I have tried, both my Mom and my brother are tremendous artists. Even when it came time to do the paint layout. I had painted the car white, pearled it and mini flaked it with silver and gold mini flake (looks amazing in the sun) cleared it and sanded it with 600 grit. then I proceeded to use up at least 10 rolls of fine line tape trying to lay out a pattern that I liked and could not do it... I gave up and called my pal Dennis McPhail and he came up and nailed it!!![​IMG]
    Tman, 54delray, Stock Racer and 10 others like this.
  5. rd martin
    rd martin
    from indiana
    the whole car is beautiful! quite the feat to pull that off! great detail.
    Moriarity likes this.
  6. Kan Kustom
    Kan Kustom
    You are being too modest Mark. The striping and panels are nice but they can't fix a body with a bad shape . I have painted many custom cars and bikes and several hundred airplanes and striped all of them. If the plane has an odd shape, the best artwork a guy can do can not make it look nice. There are several panel and striping scheme,s that would have made your car look great but you nailed a nice body.
    chryslerfan55, drdave and Moriarity like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    I thought I would ad some more pics and make this sort of an after the fact build thread. I thought I had a shot of the bare frame but I couldn’t find it. It is made from 2” round tube, ladder style. I used a 57 Chev rear on coil springs and hair pins. The front axle is 37 Ford v8-60 with horizontally mounted coils. I covered the frame with sheet poly and started laying on plaster and vermiculite newspaper spit wads. These first pics are not for the faint of heart. I gotta tell ya that after a few nights of this it would have been real easy to quit. Looks horrible [​IMG][​IMG]
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    The next step is to use a cheese grater file and whatever else works out to shape it[​IMG][​IMG]
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    I screwed around too long trying to get the sides symmetrical ( I had cardboard templates all over the place) that the whole p***enger side dried out, cracked and fell to pieces on the floor.....
    54delray and chryslerfan55 like this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    After I finally got the plaster in shape, it was time to start laying up gl***. I used polyester resin and the first couple layers were done in cloth. I had never done any gl*** work prior to this and I was told the cloth was important for strength. The cloth was followed up with 1.5 oz mat which was far easier to with with.[​IMG][​IMG]
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    After the gl*** cured, I spent what seemed like forever getting the plaster out of the body, it had glommed on around the frame tubes and was a ***** getting the body off and cleaned up. I had a giant pile of plaster to get rid of. I s****ed the garage floor and it was about 6 inches thick all over... big mess, big success... flopped the body back on the frame and man was it tougher than a night in jail on the outside......[​IMG][​IMG]
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    The next step is lots of grinding, most of which I tried to do outside to keep the itching powder to a minimum.[​IMG][​IMG]
    54delray, Stock Racer, brEad and 7 others like this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    I don’t have any pics of the bubble top mold. I made it from plywood as instructed by Ed Roth. It took 4 tries to get a decent one that wasn’t lopsided. One thing Roth said when I sent him pics of this car in primer was “I don’t know why anyone would want to build a car that looks like I built it in the ‘60’s, you should be building something futuristic “ that was actually a compliment in my eyes because I wanted it to look Roth inspired.
    Next I built some of the “fun stuff” like the tail lights. Because you can’t just put production car parts on a custom built car[​IMG][​IMG]
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    Next it got blown apart, I rebuilt the engine which is a 215 aluminum Buick. I built my own blower manifold for the 4-71. A weiand plate holds 6 stromberg 97’s. Bored .030 over. Mallory dual point distributor, offy valve covers that I machined off the name and inserted a plexigl*** futurian name plate. The engine is painted House of color candy purple[​IMG][​IMG]
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    I did all my own pre chroming polishing. That is some of the hardest and dirtiest work a person can do... pained the frame gloss black and ***embled all the suspension parts and installed the engine and trans[​IMG][​IMG][​IMG][​IMG][​IMG]
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    The next step was a ton of priming and blocking until I thought it was straight enough and then painted in ppg white with hok silver pearl and covered with silver and gold mini flake. Metal flake over white is almost invisible except for in the sun light but boy does it sparkle in the sun!! Like I said before I have no artistic ability whatsoever and try as I might I couldn’t come up with a layout. My pal Dennis McPhail came up and did an amazing job.....[​IMG][​IMG][​IMG][​IMG]
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    Once the candy fogs were painted, cleared, sanded and rubbed I got a bunch of guys over to put the body back on for the last time. This time we had to be careful not to scratch anything.... here is a pic after ***embly and before upholstery. The interior was done by Bob Holland. Bob was a friend of @Tuck and he saw the car at bobs shop. That was before I knew tuck and before I joined the H.A.M.B. [​IMG]
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    54delray, hrm2k, catdad49 and 6 others like this.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    As soon as it was completed it was loaned to Starbirds hall of fame museum. When I unloaded it there Darryl took one look and said “ that looks more like a Roth car than a Roth car”.....[​IMG]
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    Here is a pic a few years later in front of the museum shooting a Christmas card pic with Darryl....[​IMG]
  22. Moriarity
    Moriarity
    SUPER MODERATOR
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    It was at this point some of my buddies said "get rid of this **** before too many people see it" LOL
  24. echo ed
    echo ed
    from fla.
    It's a beautiful creation, you should be very proud, not many people would have seen it through to the end. I enjoyed the construction photos, thanks.
    brEad, Ron Funkhouser and Moriarity like this.
  25. big fun to read, Mark, and hats off to you to start AND finish such an ambitious built.
    always like your stuff, dude.
    Carsten
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    Found another pic that should have been included. Painted body[​IMG]
  27. Stogy
    Stogy
    Amazing and Wild Machine...I hope it's okay to call it a Custom Hotrod...truly a masterpiece. Thanks for sharing the story and the visual journey @Moriarity...
    Question for you...Has vermiculite been replaced in this type of mold construction as it has been given a bad name due to health issues it could create, not that so many other things involved in the construction phase carry similar warnings...so I guess we just have to be careful
  28. chevy57dude
    chevy57dude
    Fifteen years and the kitchen is still new? Thought I was the "Anticook''.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    hard to say. I haven't used any in a long tome. when I did my trike body I used foam insulation skimmed with a thin layer of plaster just to keep the resin from eating the foam. It was way less messy[​IMG]
    kidcampbell71, 54delray, GuyW and 5 others like this.
  30. stanlow69
    stanlow69
    You need to do more build threads.
