Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That HAL powered roadster is a beaut.
    Deuces and loudbang like this.
  2. sliceddeuce
    sliceddeuce
  3. loudbang
    Tucker
    Scripps
    catdad49, Stebo27, mgtstumpy and 7 others like this.
  4. sliceddeuce
    sliceddeuce
  5. Fordors
    Fordors
    That is a Model T based engine conversion. At first I was thinking the Macaulay Foundry in Berkeley, CA poured the castings for those, but no, they did Harry Miller's castings. It was the Hanford Foundry located in the same general area that cast them and a local machine shop did the finish work on a kit that used the Model T crank with some other T components on a custom crankcase, intake and ignition. The kit sold for $175. 260313.jpg .
    catdad49, Stebo27, mgtstumpy and 6 others like this.
  6. Apparently the Oakland and Pontiac versions of the engine differed in that the synchroniser changed side when used in the Pontiac.
    https://forums.aaca.org/topic/321174-v-8-with-horizontal-valves/?tab=comments#comment-1833271
    mgtstumpy and loudbang like this.
  7. The idea of the rockers operating on the underside the valve covers is a similar idea to that used by the Stephens Salient Six engine.
    http://wokr.org/gallery/Step_02.htm
    Stebo27, mgtstumpy, Deuces and 2 others like this.
  8. loudbang likes this.
  9. bobbytnm
    bobbytnm
    loudbang and XXL__ like this.
  10. seb fontana
    seb fontana
    from ct
    I did not know that there was a "kit"!!..I had read I think at Ford Barn that a Taxi cab company had the v8 made for their taxi cabs..40 hp was better than 20! Henry Ford got wind of it and more or less was not amused and production stopped..Don't know if patents were involved..Tried to find the article and pics a couple weeks ago but had no luck..
  11. Fordors
    Fordors
    Seb, I had seen that engine before but couldn’t recall what website it was on. Thinking the castings were by Macaulay I Googled “Macaulay, Model T V8” and that’s when I got the lead on Hanford Foundry. Google it, there is some good info about the project.
  12. seb fontana
    seb fontana
    from ct
    Thanks I will check it out..
  13. loudbang
    Roof Cyclone
    Pegaso Supercharged
    Stebo27, mgtstumpy, 1947knuck and 6 others like this.
  14. 30dodge
    30dodge
    from Pahrump nv
    Stebo27, mgtstumpy, 1947knuck and 4 others like this.
  15. loudbang
    All Ford Experimental engines 1965
    1929 Hispano-Suiza V-12 2,000 CID 650 HP @ 2000 RPM.
    Stebo27, mgtstumpy, 1947knuck and 7 others like this.
  16. loudbang
    1929 650 HP V-12 Hispano-Suiza Model 12a
    1929 650 HP V-12 Hispano-Suiza Model 12 a
    Stebo27, mgtstumpy, 1947knuck and 5 others like this.
  17. RichFox
    RichFox
    Possibly a V8
  18. There actually was a flathead powered Camaro that ran on the salt way back when. That may not be it but it did happen.
    I don't have anything really bizarre but I have this old 394 that is a little different for a little while longer.
    Stebo27, mgtstumpy, 1947knuck and 3 others like this.
  19. sliceddeuce
    sliceddeuce
  20. Jalopy Joker
    Jalopy Joker
  21. 28dreyer
    28dreyer
    from Minnesota
    Definitely a V8, commonly used in dirt track racing big cars with one bank removed.
  22. Pn'B- what's up with those heads/valve covers on the 394? I still need pick mine up, but I know my covers are different :)
  23. 28dreyer
    28dreyer
    from Minnesota
    This Indianapolis 500 driver and engine builder Frankie Brisko engine was running in a midget race car pre-war. It was 5 main bearings and constructed like an DOHC Offy mono bloc with hemispherical chambers but had no camshafts. Valves were operated by individual hydraulic actuators operated by a hydraulic pump. This could be considered the fore runner of today's variable valve timing, and in fact Frank patented this in the '60's but of course the development went a different direction.
  24. BigO
    BigO
    I'd buy it .
  25. loudbang
  26. mgtstumpy
    mgtstumpy
    Stebo27, JUNK ROD, 1947knuck and 3 others like this.
  27. loudbang
    Gurney-Eagle Ford V-8 Indy Car Dan Gurney and Carroll Shelby teamed up in 1962 to form “All American Racers”.
    Stebo27, Oldioron, 1947knuck and 6 others like this.
  28. loudbang
    1929 Buick o.h.v 309.6 c.i. six-cylinder engine.
    Stebo27, Oldioron, 1947knuck and 7 others like this.
  29. loudbang
    Engine of Frank Lockhart’s Stutz Black Hawk that attempted the land speed record in 1928. Two 91 ci inline 8 cylinder engines on a common crankcase. Engine uses 2 cranks in one common crank case.
  30. loudbang
    Offenhauser 159cu in fitted with a Roots type blower. This image clearly shows the internal splines to take the special multi-plate racing clutch, with timing marks around the whole cir***ference.
    Same
    1965 supercharged Offy , which developed 525 bhp.
    1engine9a Pictured above is a 1965 supercharged Offy , which developed 525 bhp..JPG
    Stebo27, Oldioron, 1947knuck and 8 others like this.
