Projects Olds in a 39 Ford
Discussion in 'Traditional Hot Rods' started by indianapolisracer, Jan 26, 2019.
  1. indianapolisracer
    indianapolisracer
  2. Dago 88
    Dago 88
  3. Dago 88
    Dago 88
    '303 & column shifted 3 speed 17841763_10210067393655312_1503126555_n.jpg 18342224_1285941321521748_955253408104544305_n.jpg in my '34 three window.
    rob-redm, 40FORDPU, LOU WELLS and 4 others like this.
  4. indianapolisracer
    indianapolisracer
    Dago 88 likes this.
  5. rd martin
    rd martin
    from indiana
    wanting to do an olds in my 40 also! you guys got me thinking again!:cool:
  6. WB69
    WB69
    from Kansas
    I put a 324 Rocket in a Ford F1 pickup. Adaptor plated to the original 3 speed. Easy setup. Way more than the old truck needs.
  7. Six Ball
    Six Ball
    from Nevada
    In '62 I had a 303 in my '38 Ford coupe. '39 box stock rear end. I went through a few of each before I learned how to drive it. The olds was bored a little had a 3/4 cam and 3 twos.
  8. indianapolisracer
    indianapolisracer
    Any pictures of that baby ?
  9. vtx1800
    vtx1800
    My only Olds in an old Ford (a 48 two door sedan) was in about 1960, I had my cows at the fair in Corning, Ia and time to kill during the day. One of my fellow "4H'rs" brother had the aforementioned Ford. He was cruising up main street, nailed it and the throttle linkage over centered, then with youthful quick thinking he found the key and turned it off. I was 16 and thought that car was so cool:)
  10. indianapolisracer
    indianapolisracer
    My buddy's 39 was what inspired me in high school wanted that car so bad but no $ Many years later tracked it down and bought it !
    saltracer219 likes this.
  11. KCTA Chris
    KCTA Chris
    I had a similar search last year but reversed, I needed to swap in an Olds Transmission and thought there would have been a few "How-To" articles on the engine swap from back in the days but no luck. I ran a very worked over Olds with a B&M Hydro in my '34 and loved it! So when I came across a nice Hydro-Motive trans with Chevy adapter I thought it would be perfect behind my early Vette block. There's been a lot of cutting to make that happen in my '39.
  12. raven
    raven
    Chris is one of the only guys that I know that pulls the body off his car to change the transmission...
    You need any help finish that up?
    r
    KCTA Chris likes this.
  13. indianapolisracer
    indianapolisracer
    Nice work
  14. warbird1
    warbird1
    My first exposure to one of these was while taking a Boy Scout First Aid course at the local Volunteer Fire Department in Plainview, NE in '62 or '63. We got a tour of the fire equipment during a break and sitting in the back of the fire hall was the Firechief's car; a white '39 or '40 Ford 2-door sedan complete with lights and siren. And an Oldsmobile shoe-horned into the engine bay. To say I was impressed was an understatement... I've always wondered what happened to that car.
  15. warbird1
    warbird1
    What is this transmission input shaft extension of which you speak? Pilot bearing adapter perhaps?
  16. 6sally6
    6sally6
    "Call me qwazy-but....I thought a 39 grille was sorta/kinda like a 40 grille (only prettier)! This one looks (to me) more like a 34/36 grille.
    Maybe it just me?!
    Nice ride BTW!
    6sally6
  17. wojojo
    wojojo
    The 40 S
    The 40 Standard had a different grille than the 40 DeLuxe.
  18. indianapolisracer
    indianapolisracer
    Yes needed because of the increased distance to flywheel after adaptor plate attached
  19. Paul
    Paul
    Editor
    picked this one up a few years ago,
    seller said it was in a '40 Ford Coupe before it spent way to long out in the weather
    but had lots of parts worth saving
  20. indianapolisracer
    indianapolisracer
    F&J likes this.
  21. indianapolisracer
    indianapolisracer
  22. warbird1
    warbird1
    OK, still not "getting it" I guess. Does this adapter fit between the flywheel and crank to move the flywheel back or is it just a pilot bearing adapter to allow the Olds crank to accept the Ford pilot bearing?
  23. saltracer219
    saltracer219
    It would be a stepped pilot bushing, big size for the crank and a step down for the trans input shaft.
  24. warbird1
    warbird1
    OK, got it... Thanks.
