Technical The Ala Kart Suspension: What was George thinking?
Discussion in 'The Hokey Ass Message Board' started by MrPhat40, Feb 3, 2019.
  1. egads
    egads
    Packard didn't use air bags, they had torsion bars front and rear.
  2. TrailerTrashToo
    TrailerTrashToo
    There are a couple of grumpy posters that definitely need more prune juice....
    49ratfink and Rich S. like this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    how did a question about coil springs with overload bags turn into a discussion about air ride? the ala kart does not have air ride......
  4. Thank you
    And Thank you again
  5. gimpyshotrods
    gimpyshotrods
    A La Kart has what it has.
    Everyone else only has a semantic argument.
  6. thirtytwo
    thirtytwo
    I don’t think Barris had anything / much to do with the ch***is, I remember reading peters and blackie drove to LA almost every week to work on the truck at Barris shop also
  7. nugget32
    nugget32
    Dad had them on his 53 Buick.
    Sent from my VS500 using The H.A.M.B. mobile app
  8. willys36
    willys36
    Guys . . . got to realize Ala Kart, Mysterion, Sillouhette, Beatnik Bandit, etc., etc., etc., are NOT cars, they are fine art. And we are all better for their existence.
  9. LuckySumbich
    LuckySumbich
    from Mesa, AZ
    “What’s a coil spring and who the hell is George Harris?” - too much of the cl***ic car community today.
    VANDENPLAS likes this.
  10. Ned Ludd
    Ned Ludd
    Packard's interconnected torsion bars were intended as an arguably superior alternative to Cadillac etc.'s air suspension. It's brilliant even if it's clear that Bill Allison himself didn't quite understand how it was supposed to work.
  11. alchemy
    alchemy
  12. MrPhat40
    MrPhat40
    classiccarjack and VANDENPLAS like this.
  13. 49ratfink
    49ratfink
    has this car ever even moved under it's own power since being built?
  14. jimgoetz
    jimgoetz
    See poet #38.
    49ratfink likes this.
  15. birdman1
    birdman1
    air lift was used on 1957 stock cars
  16. sunbeam
    sunbeam
  17. Atwater Mike
    Atwater Mike
    Yep, 'split' wishbone. BUT! I recall first time seeing Ala Kart in the show. I was aghast at the 30* bent 'bones, wow...Super no-no.
    But the coils were nicely engineered, bracket and parallel-wise...(no visible 'bind'...)
  18. Atwater Mike
    Atwater Mike
    CL***IC EXAMPLE, Gimpy: "Who you gonna believe? ME, or your lyin' eyes?"
    gimpyshotrods likes this.
  19. Fordors
    Fordors
    If you mean since being built in the mid ‘50’s then the answer is yes. At some point the carbs were changed out for Hilborn stack injectors and one time when it was driven there was an engine fire. I don’t know who owned it at the time but it may have been AMT.
    There was pretty extensive damage, top end of engine, firewall, cowl, paint and part of upholstery.
    I agree on it being a piece of art but it did run and drive. If there had been a Ridler Award back then it would have crushed the compe***ion at that show too.
    On the other hand, since the Brizio restoration it might be a trailer queen, John Mumford has plenty of other cars to drive.
  20. Bruce Lancaster
    Bruce Lancaster
    Engine too small...I once saw a model magazine article with that statement. The writer thought the engine was a chrysler, and it was indeed too small for that, but there were THREE sizes of hemis in different external sizes and no real interchange: Dodge, DeSoto, and Chrysler, from small to large. Barris used the Dodge (or perhaps DeSoto, I'm far too lazy to lookitup!), MUCH smaller in overall size. I'd say from the AMT model they got size about right.
    BUT for AMT getting the size right was an accident...if you look at that era, AMT engines were interchangeable m***es meant to fit early Fords in 1/25 and fitting the standard AMT mounts*...if the engine had been a 392 it STILL would have fit the model!
    Suspension by bagged coil would in terms of support have been essentially the same except for the considerable anti-sway help of a properly set up cross spring. Whoever built the Ala Kart ch***is knew that and put in Panhard bars, which are hard to spot in the blinding jungle of chrome.
    That ch***is is incidentally one of the most accurate Model A setups out there in 1/25, pretty much a standard A-V8 ch***is.
    *AND...I believed that when I was 12! I once almost bought a 352 Packard as an engine for my immobile pile-of-junk 32, quite sure that with the available Ford adaptor and the imaginary Hurst mount tabs it would drop right in!
  21. K13
    K13
  22. HEMI32
    HEMI32
    Perhaps Bill (@slixauto) Ganahl will chime-in ... back in 2001, Billy was working at Roy Brizio's shop and performed most of the restoration of the Ala Kart for John Mumford.
    EVL401, Tim, Deuces and 1 other person like this.
  23. alchemy
    alchemy
    Is that drive the Ala Kart or the Howli Kart? I don't have sound, maybe it says in the audio?
  24. Paint
    Paint
    That's the Howli Kart. No hood scoop and it's an automatic trans.
    lurker mick likes this.
  25. HEMI32
    HEMI32
    There's no narration in the video ... but I'm pretty sure is was Howdy Ledbetter's "Ala Kart II" Tribute Car (aka the "Howli Kart" named after his daughter).
    EDIT: D'oh! ... @Paint beat me to it!
  26. stillrunners
    stillrunners
    from dallas
    Ma Mopar had them to in the late 50's.........
  27. rudestude
    rudestude
  28. Kan Kustom
    Kan Kustom
    The original Barris truck ran all around Wichita Kansas years ago back when it was on the show circuit .
  29. sliceddeuce
    sliceddeuce
    Quick disclaimer...I have never built anything that pretty or influential...I never will...But, Some of those build details remind me those pics of **** stars without make-up.
  30. Mr. Mac
    Mr. Mac
    I heard about that and I also heard who was driving it but don't tell Starbird:D:D:D
