Technical Chrome Plating Aluminum
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 4, 2019.
  1. Roothawg
    Roothawg
    i have a set of vintage 7 fin Cal Custom valve covers at the polishing shop. I am hoping for a “show finish “ but I am hesitant.
    Would it be better to have them chromed? Just wondering how this process holds up?
    I know very few people are chrome playing with all 3 steps these days.
    I have time. This project will take a long time to finish.
  2. lcfman
    lcfman
    from tn
    Good chrome platers like Advanced Plating others would have no problem chrome plating aluminum and I see no reason it would not hold up.
  3. Atwater Mike
    Atwater Mike
    Think they have to be anodized, then chromed.
    Don Orosco chromed some stainless and then some aluminum on his Pebble Beach '34...said chroming aluminum is 'just fine'.
  4. gnichols
    gnichols
    from Tampa, FL
    Ditto. Works great. Part must first be polished to perfection, like Advanced does, and the grand prize is that future cleaning can be done with Windex and very little elbow grease. Gary
    harpo1313 likes this.
  5. I've sanded and buffed out aluminum to a high polish before. You will want to seal it when your done though. Either use "Diamond Clear" from Eastwood or have someone powder coat clear em'. I have done both ways with good results.
  6. Jack E/NJ
    Jack E/NJ
    from NJ
    If the covers were pressed from extruded flatstock, bright dip anodizing is probably best. Jack E/NJ
  7. DDDenny
    Like any process the results will be proportunate to the quality of the prep work but with many parts cast in aluminum they can have inconsistant (pour) quality (porosity).
    My knowledge about casting also has holes in it so best to get the facts from the experts.
    Here:
    http://berntsen-foundry.com/porosity-free-aluminum-castings/
    I've seen many aluminum parts chrome plated but in all honesty I would rather have them highly polished, just doesn't look "natural" to me, just never quite liked that look.
    Not sure why, maybe it's because I know it's aluminum and I've never seen aluminum polish up with that level of lustre.
  8. I had an O/T aluminum valve cover plated years ago, came out great. Was not cheap as the cover had to be polished to perfection and then a coating on top I don’t remember if it was anodized or zinc ... something along those lines. Then got it “concourse chrome” almost like a black chrome. Looked great.
    But I would have to agree with DDDENNY I really like the look of high polished aluminum, it has a warmer glow to it then chrome. A bit more up keep, but oh well.
  9. Roothawg
    Roothawg
    I told my polisher the finish I wanted, but everyone's interpretation of "show quality" may be different. He showed me some of the stuff he had chromed for his Harley, that he was super proud of. I would have sent it all back. supposed to be done polishing them this week. We will see. I spent a couple of days prepping the fins myself.
    kidcampbell71 likes this.
  10. 41rodderz
    41rodderz
    from Oregon
    I have had a couple of chromed over aluminum intakes and like was stated prep and porosity come into play. Both were old jobs but the chrome eventually chipped in a few places and chrome over dibs and waves takes away from what can be a nice show part. I agree with DDDenny chrome doesn't look the same as it would on metal.
  11. Mr. Mac
    Mr. Mac
    Chromed aluminum is so much easer to clean than just polished aluminum. All my aluminum parts are chromed on my roadster.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    If you want show quality chromed aluminum parts they need to be polished, then plated in copper, then the porous parts can be soldered or leaded and sanded and then copper plated again. polish and copper plate until perfect. then nickel and chrome plate... It is expensive when done correctly but looks great. I use AIH custom chrome in Dubuque Iowa
  13. A Boner
    A Boner
    Polished aluminum valve covers are cool, polished aluminum and chromed valve covers are bling. IMHO
    Polished - race look
    Chrome - show look
    scotty t likes this.
  14. fourspd2quad
    fourspd2quad
    Here are two samples of my cast aluminum tail light bezels for comparison. The bezel on the primered car was chrome plated while the one on the green car is polished aluminum. Definitely a different look.
  15. A Boner
    A Boner
    ^^^^Looks more like brushed aluminum.
  16. DDDenny
    Boy, that looks good chromed, clearly proves I was all wet as far as a general statement.
    The example I used in my previous post was a pair of LT-1 (1970 style) valve covers that I saw that had been chrome plated. I had a pair of NOS valve covers, OEM polished, not show polished and I loved them (sorry Mark), should have kept them.
    The Shift Wizard likes this.
  17. I'll be the contrarian…
    I had a crusty old plater tell me many years ago that plated aluminum is like a teen-aged ******; looks great when fresh, but doesn't age well. Time has proven him right...
    Plated aluminum can look great and does eliminate any frequent polishing, but you can't let any moisture sit on it for extended periods, and that includes high humidity. If there's any chips, breaks, or thin spots in the plating (and these are all extremely difficult to totally eliminate) and corrosion gets a foothold in the aluminum, it'll start lifting the plating and the only fix is to strip and replate. If you've ever seen a Cragar SS wheel with peeling chrome around the lug nuts, that's the process. Keeping all plating spotlessly clean and waxed is the best maintenance, along with heated storage.
    Same thing goes for any 'coating' over polished aluminum; any corrosion gets under the coating and you'll be stripping and repolishing sooner or later.
  18. chopolds
    chopolds
    from howell, nj
    Can be done, but as DDenny said, ****py castings, like most finned VC's, will cost a bit more to get all the imperfections out of them. MUCH easier to clean than polished, though, and won't oxidize.
  19. HOTRODPRIMER
    HOTRODPRIMER
    Advanced Plating does a beautiful job, Steve did all the chrome work on our wagon and he does chrome plate aluminum parts, he did a friends 1952 bubble top aluminum side trim and it turned out amazing. HRP
  20. Roothawg
    Roothawg
    Thanks, this thread has some good info.
  21. 56sedandelivery
    56sedandelivery
    Does the chroming process hold as good to aluminum as with steel? My reason for asking; I had a RARE aluminum Ansen 2 piece, SBC/BBC ****tershield for sale. The lower cover had been chromed at one time, but the chrome was flaking after 45 PLUS years of use. The buyer was told this before he committed to buying it; he still "Pissed and Moaned" after getting it. Cost me $100.00 to shut him up, and it was sold through the HAMB Cl***ifieds! I think it was more buyers remorse than anything; he just did't want to pay the price for a RARE part. I should have kept that ****tershield!!! I am Butch/56sedandelivery.
  22. Bandit Billy
    Bandit Billy
    If you think about it, every chrome GM alternator is plated aluminum, holds up fine from my experience. I have had a few aluminum parts that due to the cast and material would not polish. The polished said they kept "popping" when they got them hot on the buffer wheel. Those parts got plated and turned out nice.
  23. DDDenny
    Hmmm
    I wonder how aluminium connecting rods would look chromed? Just for show of course!
    Inside joke;)
  24. Bandit Billy
    Bandit Billy
  25. alchemy
    alchemy
    As Moriarity said above, a plater can hide the flaws of whatever they are plating with copper coats and solder in the pits. Aluminum included. And as any plating job requires, whether steel, br***, pot metal, or aluminum, a good prep job and proper procedure will provide a long life.
    And sometimes plating aluminum is beyond the plater's skill level. You just need to find the experienced plater.
    Over ten years ago I had Chromeplaterjosh here on the HAMB do some of my 41 Studebaker taillights, which I normally sell as polished aluminum. That pair still looks great.
  26. Chrome plating aluminium should be no problem. My experience is that after a few years it easier
    flakes off than chromed steel. Could be my bad luck or the poor Dutch wetter, but that's my experience.
  27. badvolvo
    badvolvo
    I actually prefer polished aluminium vs chrome. Takes a bunch of work to keep that look though, and I don't do well at that kind of maintenance.
    I just got a new intake from Edelbrock, fresh casting 12-2018. It looks so good I want to clear coat it. I am afraid it will just begin flaking off and don't want to deal with that mess.
    Anyone clear coat aluminium engine parts - with long term success?
  28. Roothawg
    Roothawg
    That's me. I don't wanna spend a ton of time polishing.
  29. Chrome plated aluminum can look great, but does need a first-cl*** plating job to hold up. If you have any su****ions about the plater, walk away. A few things to remember...
    1. Chrome plating is porous. While it seals most corrosion out, it doesn't stop all of it. This porosity is why chromed pot metal pits and chromed steel parts rust. Aluminum isn't immune to this. A full triple-plate (copper/nickel/chrome) will help, but not fully eliminate this.
    2. Chrome plating doesn't always apply evenly. During the process, the plating metal will 'stick' to the first part of the item it encounters. If you have holes or recesses, the plating will be thin in those areas and if you have problems, that's usually where they'll start. Wide, shallow recesses can be adequately plated by simply allowing more metal to transfer (as long as the plater isn't too cheap), deeper stuff can be fixtured but that runs the cost up sharply. On your valve covers, it will be thin in the mounting holes and between the fins. I'd paint, or better yet powdercoat between the fins.
    3. Chromed steel will give you warning if the plating is compromised; that's where rust will first appear and if promptly polished off and then waxed, it can be maintained. Pot metal and aluminum won't give you that warning, so preventative maintenance is critical.
    4. The chrome is actually decorative. The actual corrosion-inhibiting layer is the nickel but it tarnishes easily. Failure to apply enough nickel will result in a plating job that won't hold up.
  30. quicksilverart46
    quicksilverart46
    I agree 100%. Polished aluminum looks natural and shiny enough. Clear coating looks fake and will peel in time. Chrome is great for steel but chrome aluminum again looks over done on a known aluminum part.
