Projects Another Deuce Rdstr project.
Discussion in 'Traditional Hot Rods' started by Baron, Feb 5, 2019.
  1. Baron
    Baron
    Started this project about 2 years ago. Four years ago I wound up buying a Duvall windshield frame that was listed here on the HAMB cl***ifieds. This was after looking at it for several months, as I was already building a gl*** 5W coupe. So I posted in the wanted section looking a for a Wescott Rdstr body. Within a couple of days a old friend of mine called and told me he had a Brookeville Rdstr body that he had started to build, but decided he wanted to build a truck instead. So I bought the body. The ch***is I built for a another friend of mine back in 2011. He never used it so when he came to look at my newly acquired roadster, he offered to sell me the frame at a price to good to p*** up. So, here are a couple of pictures taken a couple years ago and will eventually get caught up to date. And all this because of the Duvall windshield for sale here on the HAMB. :)
  2. big duece
    big duece
    from kansas
    Drivetrain in mind? Looks like a relief in trunk area for a quickie
    loudbang and Baron like this.
  3. krylon32
    krylon32
    from Nebraska
    Great Start
  4. brady1929
    brady1929
    Nice
  5. mgtstumpy
    mgtstumpy
    Building a car around a major component seems to be the norm, subscribed.
    chryslerfan55, loudbang and Baron like this.
  6. Baron
    Baron
    -The gentleman I bought the body from had a Model A rear cross-member in the ch***is he had. I recently replaced the stock Deuce rear member with an original A, but with a few more modification's.
  7. Baron
    Baron
    These pics of the body bolted to the ch***is for trial fit ,November, 2016. I was pleasantly surprised to find the doors opened and closed perfectly without having to install a single shim between the body and frame( a far cry from my last two Wescott bodied Rdstr builds ).
  8. Baron
    Baron
    Windshield fit the cowl excellent. Unfortunately the cowl vent will have to go, and that will lead to other modifications that will give the Rdstr a better look. 2017-02-25 12.40.03 x.jpg 2017-03-07 17.50.11.jpg
  9. Baron
    Baron
  10. Aaron D.
    Aaron D.
    Very nice!
  11. That is so slick.Any idea what color your going to paint it?
  12. Baron
    Baron
    This is the color I have picked out after months of searching for what I wanted. It's non-metallic that looks like Mandarin Maroon in the sunlight (picture 1) and looks more purple in the shade ( picture 2). And once the sun goes down, it almost looks black. My color choice is not etched in stone, but most likely I will stay with this.
  13. Baron
    Baron
    I've never been a fan of the gas tank in the stock location. Shortened up the rear frame horns and kicked them up so I could install one of Walden's curved rear spreader bars. Follows the contour of the lower rear panel perfect and tidy's up the rear end nicely . 2017-01-18 14.53.02 x.jpg 2017-01-21 12.12.49 x.jpg 2017-01-21 12.12.33.jpg 2017-01-27 13.59.58 x.jpg
    chryslerfan55, hfh, Outback and 20 others like this.
  14. loudbang
    This is going to be good :) Along for the ride.
    1947knuck, lothiandon1940 and Baron like this.
  15. Baron
    Baron
    First part of the ride is going to be quick. First time I started a build thread well after starting the project, so the progress pictures will look like I'm working on it like a madman...lol
    Outback, 1947knuck, brEad and 2 others like this.
  16. hotrodA
    hotrodA
    Wow!
    That's looking great!
    Care to share the secret color name/mix?
    Baron and loudbang like this.
  17. sloppy jalopies
    sloppy jalopies
    never done it,
    but how about a '33-'34 or a bigger '35-'36 cowlvent, cut in half and turned 180*…
    the angled edge will better match the cowltop / duval edges... my $0.01 ...
  18. oldbanger71
    oldbanger71
    will folow... going to be interesting
  19. wheeldog57
    wheeldog57
    That looks sharp Baron. Looking forward to seeing it.
  20. Baron
    Baron
    Got rid of the forging lines on the So-Cal front axle and cleaned it up before it goes out to be powder coated. Axle 1.jpg Axle 2.jpg Axle 3.jpg
  21. Baron
    Baron
    Running 56 F100 front brakes along with 56 steering box. 34 Ford wishbones with the axle ends reversed to clear the tie rod. Wasn't happy with the look of the bones mounted like this, so later in the build I moved the wishbone mounts inboard about 4 inches. Not only looks cleaner, but also moves the draglink inboard and a tighter turning radius to the left. 2017-04-01 16.32.44.jpg 2017-04-07 17.30.04 x.jpg
  22. OldBolts
    OldBolts
    We are on similar paths right now. Your’s looking good. Windshield frame is right on.
    Baron, loudbang and lothiandon1940 like this.
  23. OldBolts
    OldBolts
    Is a quick change in store? You would have a nice view of it. You may have mentioned already.
  24. Baron
    Baron
    No. Just a 9 inch Ford. About three weeks ago, I removed the stock Deuce rear cross member and replaced it with a mint stock Model A. Can always bolt in a quick change later if I decide to do that at some point.
  25. Baron
    Baron
    A trick a old timer taught me many years ago for modifying the stock pedal ***embly . A little shortening, reverse the shaft, re-***emble, drill one hole and bolts right back on the firewall. Just like Ford made it that way. Gas pedal  a.jpg Gas pedal  b.jpg Gas pedal  c.jpg Gas pedal  d.jpg
    chryslerfan55, hfh, 1947knuck and 8 others like this.
  26. Baron
    Baron
    Some 5.50 x 16 bias ply Firestone's on 40 Ford 16 x 4's wheels are just right for the front end.
    V8-m, chryslerfan55, hfh and 9 others like this.
  27. 41rodderz
    41rodderz
    from Oregon
    So that is the trick. Work some,take pics then upload them altogether and **** !!! major progress. :D Maybe that can inspire me .
    brEad, loudbang and Baron like this.
  28. kidcampbell71
    kidcampbell71
    Did you say 16" Firestones on 15" wheels ? Really ? Looks great. I love it. Just clarifying. Who knew ?
    chryslerfan55, Baron and loudbang like this.
  29. Baron
    Baron
    Just checking to see if you guys are paying attention...lol
  30. Baron
    Baron
    Set of 36 wishbones will hold the 9 inch Ford in place. In this picture, the frame is sitting right on the axle tubes. Nothing a little surgery won't take care of later in the build. Need to keep those Firestone 7.50 x 16's on 16 x 41/2" 48 Ford wheels concentric with the rear wheel well.
