Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. Wardog
    Wardog
    I've thought about it long enough....
    I have been hesitant to post a build thread because I don't want it to become another one that falls dormant in the shadows of the hamb.
    Bear with me, I have a Family and Mortgage to deal with like most so I'm not planning on breaking any records with this build.
    In saying that I have made the decision to make a start on this build and hopefully not drop the ball on it. Hopefully a bit of interest and encouragement on here will push me along with it.
    The plan is to build a early styled 32 frame to put my model A coupe onto. I will post a link to an old thread of when I found the frame and try to upload all the photos I have already and then keep it all up to date.
  2. Wardog
    Wardog
  3. Wardog
    Wardog
    This was the day I dragged it into my shed and decided to make a start.
    I had been collecting parts for a while but this is what I consider the starting point.
  4. Happydaze
    Happydaze
    Now, that's a pinched frame!
    Chris
  5. bct
    bct
    this is going to be good!
  6. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    I'm not believing someone would pick a trailer over a deuce, what a shame....hahahah. sweet score....
    Stogy likes this.
  7. abonecollector
    abonecollector
    this should be cool. Im sure when that frame was made into a "trailer" it was just some discarded junk pile. I like doing work like that (cutting old repairs, & brackets off & dumping them in the s**** bin) then cleaning up the gold that lies underneath
    Atwater Mike, 1947knuck and Stogy like this.
  8. kidcampbell71
    kidcampbell71
    I can't believe you're going to destroy that time capsule. It looks like you even washed it !!! :confused::rolleyes:o_O:D:D
    The luck here should legally be contagious. I'm dumbfounded. Fun score !
  9. junkman73
    junkman73
    Looks like you have your work cut out for you.I have salvaged a lot of 30's and 40's front axles here.It seems that they were very popular to use as trailer axles.
  10. Wardog
    Wardog
    This is my coupe at the moment. The plan is to keep it on the road as long as I can until the ch***is swap.
    Tim, ct1932ford, 1947knuck and 6 others like this.
  11. Wardog
    Wardog
    I had hoped to be able to use the rails. But then I discovered they had not been m***ively pinched but torched off and welded back on. If I really wanted I could of reclaimed them but having a big repair on both sides at the cowl didn't please me, especially considering I wanted to have an unboxed frame.
  12. Wardog
    Wardog
    So with the help of my oldest son we removed the centre and rear crossmembers and I bought some aftermarket rails as well as a new lower front crossmember.
  13. Wardog
    Wardog
    The new rails set up. And the crossmembers tacked in.
  14. bct
    bct
    that was quick!!!
    spiffy1937 and Stogy like this.
  15. tub1
    tub1
    from tasmania
    hello wardog you want to sell the discarded rails
    Stogy likes this.
  16. Wardog
    Wardog
    IMG_4571.JPG Hey tub1, for now the original rails are still very useful to take measurements from.
  17. Wardog
    Wardog
    IMG_4572.jpg Just over 12 months ago I was in America for the GNRS as well as some shop tours. I bought a front end from the early ford store. This photo was taken in my room at the Safari Inn Burbank.
    v8paul, ct1932ford, 1947knuck and 9 others like this.
  18. Wardog
    Wardog
    I washed up and had 2 sets of 40's wheels blasted then made a set of 2 4" wide and 2 4.5" wide. I painted them black enamel and added a body colour thick detail line.
  19. Wardog
    Wardog
    This is my youngest son out helping dad.
  20. bct
    bct
    What rear cross are you guys planning on?
    Stogy likes this.
  21. tub1
    tub1
    from tasmania
    oh well wardog when you have finished with them may I have first refusal
    Stogy likes this.
  22. Wardog
    Wardog
    I will keep you in mind.
  23. Wardog
    Wardog
    I've used the 32 crossmember from the original frame.
  24. Wardog
    Wardog
    IMG_4317.JPG Bare with me I'm still trying to post a few photos. This was the day I welded it. 29th of September 2018, better than watching the AFL grand final.
  25. Wardog
    Wardog
    One of my favourite shots November 18 2018
    phoenix_may, Papas32, hfh and 12 others like this.
  26. Wardog
    Wardog
    Pulling the stuck perch bolts then ***embling the front end for a mock ***embly. My oldest helping me with spindles.
  27. Wardog
    Wardog
    I used some laser cut engine mounts but (in my opinion) made them look a bit nicer.
  28. Wardog
    Wardog
    November 24 2018. If I have to explain what's going on here you are on the wrong forum.
    ralphson, Just Gary, Tim and 9 others like this.
  29. Wardog
    Wardog
    IMG_4427.JPG IMG_4428.JPG IMG_4429.JPG IMG_4431.JPG IMG_4432.JPG IMG_4433.JPG IMG_4434.JPG IMG_4441.JPG November 25 2018
  30. Top stuff, will look ace with your coupe body on top.
    Keep chipping away
    Cheers,
    Drewfus
    nunattax, Stogy and Wardog like this.
