Technical Stretching cab
Discussion in 'The Hokey Ass Message Board' started by kruzin karl, Jan 31, 2019.
  1. patmanta
    patmanta
    from Woburn, MA
    Yeah, I was gonna say 1992 called and wants its steering wheel and plastic floor caddy cup holder back too.
    I am intrigued by the roof though.
  2. ray
    ray
    from colorado
    I'll add that there are other ways to get a better fit: adjust seating height and/or seat thickness. i like 60's t bird seats in old trucks because the seat backs are very thin, allowing you to gain a few inches of leg room once you move the gas tank out of the cab. i was shocked to discover that when mocking up an 54 chevy truck that i felt was cramped, that (IIRC) it was about an inch LONGER in overall length than my 66 c-10. i have tbird seats in my c10, the 54 has stock seat and gas tank. i'll be changing the 54 arrangement.
    Frankie47 likes this.
  3. Koz
    Koz
    Not the best picture but three inches in the cab 2 in the doors. Really nice proportion. Too bad I don't have a better
  4. RidingMechanic
    RidingMechanic
    from Cincinnati
    Looks good. I wonder if the stretch would work better on a cameo bed. Stepside beds look really utilitarian behind a customized cab.
    Maybe take one inch out of the door and add it back behind the door. I don't have Pshop or I'd try it.
  5. RidingMechanic
    RidingMechanic
    from Cincinnati
    Really like the black A.
  6. tom in nh
    tom in nh
    I'd like a 35 Ford crew cab.
    What is this photoshop that you guys speak of?
    Educate me about it please.
    Thanks,
    Tom
  7. Dick Stevens
    Dick Stevens
    tom in nh likes this.
  8. David Gersic
    David Gersic
    from DeKalb, IL
    The extra length of the cab has to be made up somewhere. If you didn’t shorten the bed, which is probably the easiest place to make it up, where does it go? Stretch the frame? Shorten the hood and fenders?
  9. Bill Rinaldi
    Bill Rinaldi
    I've really paid attention to 48 to 53 Chev./GM pick ups with extended cabs. Of all the ones I've seen, the best have been 4"/5" added to the doors and chopped 2". If the seating area (minus the interior gas tank) is thought out and done well, they really get, well, ROOMY, on a 4/5 stretch. The other thing is really obvious, have a donor truck body with the build. Bill Rinaldi
  10. fiftyv8
    fiftyv8
    from CO & WA
    I liked this effort down in FL and had hoped to buy it several years back, but missed out.
    Not the best pic's but all I have now...
    1morecarIpromise! likes this.
  11. nunattax
    nunattax
    I like the proportions of 30 s pickups.the price you pay is no too much legroom.my solution is to thin out the seat back,shorten the column a tad and move the throttle pedal to the centre a bit plus I modified a s**** throttle pedal
  12. Mr48chev
    Cole Porter chopped the truck that I snagged the photo of years ago and drove it for years. Jesse James ended up with it and did a few mods and then sold it on Ebay.
    Thanks, I have all the pieces to do it and if you look close (not actually that close) you can see the seams where I cut the 4 copies of the print of the truck apart and did did the stretch and section. I've never found out how much Cole Porter actually chopped the truck but it comes out just right for what I need and with that chop I don't have to spend a couple hundred hours reworking the tops of the doors.
    I posted the photo to show the OP that Hey, take some side shots of your truck, print one or two out with several prints and cut them apart and fit them together to see how it might look. Needless to say I am not good at photo shop but can do cut and tape.
  13. nunattax
    nunattax
    also made an adjustable bracket to help find the optimum mounting position without drilling holes all over the firewall.when the position is finalised it can be trimmed down to save weight of course.[​IMG]
    XXL__, David Gersic, RMR&C and 2 others like this.
  14. You can have a lot of fun doing JUST that, especially if you add some tequila
    But you really need to do top and bottom if you're serious about trying to pull it off
    The37Kid, R A Wrench and nunattax like this.
  15. kruzin karl
    kruzin karl
    Ok, I'm in the process of cutting up pictures and taping them together. I've come to the conclusion that I'm going to need to stretch the frame also to keep the proportions appealing. I do not want to shorten the bed. Not a problem, I have all the tools and some of the ability to do this, hopefully some of my friends who do have the ability will help out.
    The only thing I don't understand, is where exactly and how, are people stretching the cowl. Please, if anyone has pics of this, post them.
    Thanks- Karl
  16. There's a whole bunch of taper in the cowl,
    aBIG bunch and curves and sections of cones in the cowl.
    So print this out 3 copies
    Imagine it's the Cowl of the truck
    Say 9 is the door jambs
    7 is the firewall
    4 is the grill
    123 is imaginary out in front
    If you were to cut amd move 7 further away from nine
    Everything between needschamges
    Hnstray and Blues4U like this.
  17. kruzin karl
    kruzin karl
    I understand the concept, just wanted to see if anyone has actually done this, and if so, pictures showing where they cut on the cowl. There are so many compound curves there, I'd like to be a little bit more educated before I start slicing and dicing.
    Thanks - Karl
  18. I doubt you'll find it
    Too much work you'll be making a new cowl
  19. kruzin karl
    kruzin karl
    Hey..... No more shrinking!
    I've already shrunk from 6' 2" to 6' 1" in my time on this planet.:)
    Hnstray likes this.
  20. rockable
    rockable
    If I were doing it, I think I would split the cab and widen the rear of it to fit the widened section. I dont think it would need to be widened much but some measurements would have to confirm that.
    For example, if you widened the doors and perhaps the area immediately behind the door jambs, the rear of the cab could be widened to accommodate that, then filled with a pie shaped strip on top and a rectangular strip on the rear. That keeps you out of the compound curve areas.
    Then, the ch***is could be lengthened just behind the cab to accommodate the extra length. Just my 2 cents. I think that cowl work is going to be trickier than this.
  21. kruzin karl
    kruzin karl
    That makes a lot of sense, that's the main problem I've been having a hard time wrapping my mind around.
    That would take care of the issue with the taper of the cab.
    rockable likes this.
  22. rockable
    rockable
    It took me a while to wrap my mind around it, too. That was the simplest approach I could come up with. Otherwise, you are going to be learning to do some serious English Wheel work!
    If you could get some overhead photo shots, you could do a cut and paste to get a better idea of how much wider you would end up.
  23. nunattax
    nunattax
    [in my experience the greatest return for the work involved was thinning out the seat back.used 3/4 ply with 2 inch foam ,I fit in ok.5ft 11 normal proportions.when I redo the seats next time ill use 2mm alumimum bead rolled to add some extra strength and 2inch foam again plus some folds on the side I should gain another 5/8 legroom here.every 5/8 counts when space is at a premium.also keep the seat high as is comfortable.my 2 cents worth
    X-cpe and 31Vicky with a hemi like this.
  24. I think that by the time you get to the back edge of the doors, the cab sides are almost perfectly parallel. Just cut the cab at that point and add some inches to both the door and cab. I've seen dozens of stretched pick-ups at shows so it can't be rocket surgery!
    One might want to climb up above the truck and take a shot from the top looking down, to see exactly where the wedge is in the cab.
  25. Blues4U
    Blues4U
    from So Cal
    It looks good from that angle!
    Koz likes this.
  26. gene-koning
    gene-koning
    My newest project is a 39-47 Dodge pickup. I'm 6'1" and 270 lbs. I lowered the mini van bucket seat brackets until I could get the top of the seat under the rear window (there is no in cab tank on this era Dodge). When the seat top is under the rear window, I have plenty of steering wheel clearance and plenty of leg room. It take a bit of foot shuffling to get my feet inside the cab, but once in, its a very comfortable sit. I have only driven the truck a couple miles with the seat like this, so long rides may prove to be different, but I feel a lot better about the seating then I did before I lowered the set to fit under the rear window. Gene
  27. Mr48chev
    I'm stretching the doors on mine to get the 9-1/4 inches I need but widening the cab at the back makes a lot of sense rather than fighting with getting the roof lines all tweaked to get it right. I've got the donor piece on a cab that is bashed in the right rear corner and is donating parts to the build anyhow.
    On his 36 I'd still stretch the doors the needed amount and shorten the box that looks a tad long from the factory anyhow as I showed in my cut and tape rendition. I don't like the looks of them lengthened behind the doors with he added material there.
  28. rusty1
    rusty1
    ...I agree with this,..shortening the bed usually makes the cab look too big/bulky...if a guy can extend a cab he ought to be able to lengthen a frame.
  29. I'm really liking this, @Mr48chev
    There's a bunch done on this thing I'd like to see more of this truck so where should I look.
