Technical Any tips for removing back window with REALLY old/hard rubber? (1941 Buick)
Discussion in 'The Hokey Ass Message Board' started by Curt Six, Feb 9, 2019.
  1. Curt Six
    Curt Six
    I'm removing all the gl*** from my '41 Buick because we're getting ready to chop it. I cracked the windshield trying to separate it from the very original and very hard rubber gasket. No biggie because it's flat gl***, but I don't want to do the same with the backlite. Any tips?
    Thanks.
    Curt
  2. 32v
    32v
    from v.i.
    maybe some brake fluid , it destroys some rubber
  3. BJR
    BJR
    Use a box cutter and cut the lip off of the rubber to expose the edge of the gl***. You will need to buy new rubber anyway so just cut the gl*** out.
  4. s55mercury66
    s55mercury66
    from SW Wyoming
    ^^^ Break out the knife, save yourself a lot of grief.
    egads likes this.
  5. RMONTY
    RMONTY
    I cut the gl*** out of my 51 Chevy a few weeks ago. I just cut the old rubber down to the pinch weld and the gl*** all but fell out. The rubber moulding was hard and brittle but it did cut ok.
    john worden likes this.
  6. Squirt some penetrating oil or any oil on it and let it soak before cutting.
    3340 likes this.
  7. choptop40
    choptop40
    Utility knife, cut around perimeter on out side , sometimes the gl*** will still stick to the inside face , score that area with said knife and ...viola..now...putting it back in is another technique by itself consisting of rope , soap and ***istance of a dope....ha ha
    scrap metal 48 likes this.
  8. fastcar1953
    fastcar1953
    i use a knife but tv shows use hammers. lol
    Irish Mike likes this.
  9. tb33anda3rd
    tb33anda3rd
    when we would swop windows out of parts cars, to use the gl*** in the vehicle we would be saving. we would, break the gl*** to save the rubber on the project. cut the rubber on the donor to save the gl*** out of the parts vehicle.
    bobss396, low budget and Hnstray like this.
  10. tombstone
    tombstone
    from sk.canada
    I have removed a windshield from a 53 chev that had sat for years outside , I liberally loaded it with WD 40 and let it sit for just a few hours , damn thing slid out with very little effort .
    3340 and Truck64 like this.
  11. rusty1
    rusty1
    ...mite warm up the rubber with a butane torch very carefully, mite cut a lil easier
    samurai mike likes this.
  12. 1946caddy
    1946caddy
    from washington
    Or a heat gun. :)
  13. samurai mike
    samurai mike
    heat gun and a knife is the way to go.
    john worden and blowby like this.
  14. junkman8888
    junkman8888
    If the rubber is in any way pliable I use the box knife and a fresh blade, you want to swap out the blades often as the easiest way to get cut is to try to cut with a dull blade. If the rubber is really brittle I use a long-handed gasket s****er and a rubber mallet. You want to hit away from the center of the gl***, not towards the center of the gl***.
  15. Curt Six
    Curt Six
    Thanks fellas. Worked like a charm. Took a while with two of us but the gl*** came out intact.
  16. lothiandon1940
    lothiandon1940
    Great news there.:)
  17. jetnow1
    jetnow1
    from CT
    so which method did you use?
  18. HOTRODPRIMER
    HOTRODPRIMER
    The box cutter is the only way to remove the gl***, the petrified rubber isn't reusable anyway. HRP
  19. Curt Six
    Curt Six
    The Buick gl*** is installed from the inside, so there's a rubber molding that captures the trim and the pinch-welded seam on the outside and the gl*** on the inside. I sprayed PB blaster around the rubber the day before, then @Cody Walls and I cut the rubber (outside of the perimeter of the gl***) all the way around on the inside, then we slid a blade along the gl*** (running parallel to the gl***) on the outside to break the bond with the rubber. It released pretty easily after that. Then we cut the top off the car. chop curt and cody.jpg
    jazz1, ottoman, tb33anda3rd and 4 others like this.
  20. BJR
    BJR
    That was pretty drastic punishment for the car for not letting go of the rear gl***.
  21. Curt Six
    Curt Six
    We don't take **** off anyone.
  22. jazz1
    jazz1
    Make sure the gl*** can't fall inside and break when removing the rubber. I was not expecting that to happen.
