Hot Rods 302’s in Model A’s pics please
Discussion in 'The Hokey Ass Message Board' started by Fiftee3, Feb 10, 2019.
  1. Yes I am still new here. Reading and learning as much as I can. I know some here say Ford in Ford, while others sat SBC. I know the dollar and power differences already. Gathering parts for my 29 Tudor build.
    I am 6’ tall. Really don’t want to extend frame or indent firewall, although I woul move firewall if I can still fit. Never had a ford motor. Looking for a change.
    So please, any descriptions and with a lot of pics would be great.i will be doing automatic with Winters rear (not the quick change) for traditional look. Doing full fender rod.
    I was going to resurrect this thread MODEL A'S W/302 FORD? However it was started in 2012 and ended in 2014. Some good info but not enough. Thank you all that respond in advance...
  2. Wizzy
    Wizzy
    Here is mine in my 28. 289 with aod trans. It fits fine but when I channel the car I’ll have to recess the firewall a bit. I’m all about keeping a Ford in a Ford but dang sbc parts are cheap...
  3. Blues4U
    Blues4U
    from So Cal
    While I'm not a fan of the SBF in a Model A, others are, so to each their own. I've got a few pics I'll try to find and post them here.
  4. Dave Mc
    Dave Mc
    My 29 Pickup has one , I Like it. Also have one in my 33 ( avatar )
  5. Blues4U
    Blues4U
    from So Cal
  6. Blues4U
    Blues4U
    from So Cal
    IMG_3410.JPG IMG_3412.JPG IMG_3413.JPG Here's another one:
  7. 27 Tall T
    27 Tall T
    from Butler Pa.
    sidevalve8ba, JeffB2, legion and 6 others like this.
  8. 27 Tall T
    27 Tall T
    from Butler Pa.
    Many SBF cubic inch options to choose from
  9. Hey Wizzy,
    I too am thinking the AOD trans. Did you have to recess firewall? Short water pump? How is the hump for the trans? I am not going to channel...
  10. Blues4U
    Blues4U
    from So Cal
    I don't think the frame is lengthened, but the radiator & grill shell are set in front of the crossmember.
    On the blue coupe it looks to me like the frame could be stretched a couple 3 inches or so.
  11. Wizzy
    Wizzy
    As it is now it fits with the stock firewall, electric fan, short water pump and small trans hump up front. I'm also using sbc motor mounts with sbf adaptor plates.
    Sent from my SM-G920V using The H.A.M.B. mobile app
  12. woodhawg
    woodhawg
    Here is my 28 roadster. 32 frame, stock firewall, radiator moved forward about 2" and new hood with 32 shell. C4 Ford ****** and 9" third member At Hot Rod Reunion a few years back in Bowling Green. SBC is cheaper but not what I wanted. HO 5.0 roller cam engine bored to 306.
  13. LOU WELLS
    LOU WELLS
    from IDAHO
    A Friends Coupe With A 302/ Auto And The Fire Wall Does Need Worked Upon... 1401192_749166861776821_739210442_o.jpg
    lothiandon1940, JeffB2 and Dave Mc like this.
  14. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Kinda ****py shot, but you get the idea.[​IMG]
    sidevalve8ba, JeffB2 and Dave Mc like this.
  15. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Neatest way ive seen is to flip the firewall around. Takes a good bit of looking to realize what's been done that way
  16. fitznstartz
    fitznstartz
    from mesa az
  17. Also, on the 302’s I have seen the oil pan is split into two sumps. Will the front one interfere with 29 steering configuration? Or does it clear?
  18. fitznstartz
    fitznstartz
    from mesa az
    I moved the rad forward 1 1/2". I lengthened the frame around 4" .Can't remember the exact amount, gettin old. And I used the short water pump. Didn't want to cut into the firewall, not much room in the truck to start with. Also no problem with oilpan with traditional steering.
  19. woodhawg
    woodhawg
    I have a front sump and it clears cross steering with vega box. However I am using a 32 frame which is 3" longer than Model A.
  20. Wheeliedave
    Wheeliedave
    Just curious why you chose 302's only. SBF 221's, 260's and 289's are all based on the same basic design and all pre date the 302. I have a slightly warmed up 289 in my 29 Model A and it has been there since 1999 !
  21. Going to do everything myself except build an engine. Just want to purchase a brand new crate motor, trans and winters rear end. I've seen 260, 289's on Ebay, but not really sure of build quality or longevity.
  22. MY "29 A
    sidevalve8ba and Gammz like this.
  23. missysdad1
    missysdad1
    Lots of people trying to be helpful here but there's only one way to get a SBF in a full-fendered Model A and that's to modify the firewall. How much modification is required will depend upon how much junk you can remove from the front of the motor. Not much else to talk about.
    Gammz likes this.
  24. Dirk35
    Dirk35
    Its worth mentioning that of the 10 pictures posted so far, 5 of them have electric fans, 2 have mechanical fans, and 3 you cannot determine the fan choice from the pictures posted.
    Using an electric fan does make it easier to set the engine lower to require less firewall/floorboard intrusion.
  25. woodhawg
    woodhawg
    Mine is mechanical.
  26. 27 Tall T
    27 Tall T
    from Butler Pa.
    Mine is mechanical in the 29 pickup
  27. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Make that 6, 2 & 2.
