Projects Christine Plymouth build
Discussion in 'The Hokey Ass Message Board' started by 56ratbug, Feb 11, 2019.
  1. 56ratbug
    56ratbug
    from indiana
    My own version of Christine that I plan on having a mild kustom touch. A dream car since I was little I’m trying to make a reality! IMG_1244.JPG
  2. 56ratbug
    56ratbug
    from indiana
    harpo1313, Latigo and chryslerfan55 like this.
  3. 283john
    283john
    What part of indiana you in?
    Clay Belt likes this.
  4. philo426
    philo426
    Yes what is up with the Taxi Cab trim on the door?Cool never saw that before!382 Hemi and Torqueflite?
  5. 56ratbug
    56ratbug
    from indiana
    Southeast near Lawrenceburg
    chryslerfan55 and 283john like this.
  6. 56ratbug
    56ratbug
    from indiana
    It’s an interesting pattern, right now a poly 318 but most likely gonna find a 440
  7. Squablow
    Squablow
    Beautiful cars. Looks to be a 57. I've got some decent used bumpers for one of those if you need some that haven't been painted over.
    56ratbug and kidcampbell71 like this.
  8. 56ratbug
    56ratbug
    from indiana
  9. 56ratbug
    56ratbug
    from indiana
  10. 56ratbug
    56ratbug
    from indiana
    [​IMG][​IMG][​IMG]
    Discovered that most of the car was loaded with filler over shoddy body work
    Ron Funkhouser and tb33anda3rd like this.
  11. 56ratbug
    56ratbug
    from indiana
  12. Bandit Billy
    Bandit Billy
    I'm not sure how to pull it off but this needs to be on the radio every time you start it
  13. 56ratbug
    56ratbug
    from indiana
    Considering many of the cars I’ve seen, you’re right. There are several more areas but I’ve seen much worse
  14. henry29
    henry29
    Where was it built?
  15. 56ratbug
    56ratbug
    from indiana
    Not sure where it was built, judging from old paint I’ve found in crevices it looks to be an original red/white Belvedere
  16. 56ratbug
    56ratbug
    from indiana
  17. 56ratbug
    56ratbug
    from indiana
  18. Kiwi 4d
    Kiwi 4d
    Kudos to you man . Lots of guys when they see that much hidden filler would run and run fast away.
    You look unafraid to tackle this behemoth and its hidden uglies.
    56ratbug likes this.
  19. warhorseracing
    warhorseracing
    from cameron wv
    I found that in my '51 Ford shoe box that is really good underneath all of it. Either someone that doesn't know or in a big hurry to make a fast buck and either is sad. Take good care of the "project supervisor".;) She looks as if she will keep you honest an doing it correct.:D
  20. blue 49
    blue 49
    from Iowa
  21. 56ratbug
    56ratbug
    from indiana
  22. warhorseracing
    warhorseracing
    from cameron wv
    It will take time but when you are done it will be solid metal. Make sure to repair structure as wall as the visible outer body. Then it will be a solid "new car" or at least feel as good as a '50's cl***ic can. Looking good so far, don't get overwhelmed and persevere.
  23. 56ratbug
    56ratbug
    from indiana
    Thanks! I most definitely am going to be replacing anything rotten in my path, including what you can’t see
    warhorseracing likes this.
  24. gene-koning
    gene-koning
    But I thought Christine was suppose to fix herself....
    Your doing a good job. Those mid -late 50s Mopars had some great lines, but horrible body construction practices, and even worse metal protection. Gene
  25. 56ratbug
    56ratbug
    from indiana
    You’re right, quality control wasn’t the best and these things began to rot at a young age. I wish she fixed herself, my wallet would be in better shape!
  26. Perry Hvegholm
    Perry Hvegholm
    It was common practice, even into the early 1980's, to pull out and "waffleboard" a collapsed panel, then simply apply ****loads of filler, then sculpt & sand to shape.
  27. 56ratbug
    56ratbug
    from indiana
    There was a gentleman that bought a 58 only to discover Brillo pads stuffed in holes with filler on top. I’ve also heard of cigarette packs being found buried under filler!
  28. warhorseracing
    warhorseracing
    from cameron wv
    106_0070.JPG This is what was in the rear quarters of my '51 Ford two door under 1/2 - 3/4" of body putty. It has all been replaced like this.
    106_0067.JPG Cut out the rot and weld back in new metal.
    chryslerfan55 and 56ratbug like this.
