Technical Gloss Black Single Stage Urethane
Discussion in 'The Hokey Ass Message Board' started by blowby, Feb 12, 2019.
  1. blowby
    blowby
    from Nicasio Ca
    My local paint supplier just quoted me $439 for a gallon of N***on gloss black with hardener and reducer! Two years ago I painted my Blazer white with their less expensive fleet urethane, it went on and has held up well. It is made branded Rival and they do have gloss black for $200 with hardener (does not use reducer but you can use acetone iirc). I see Summit has unbranded gloss black for around $100, as well as some others (Speedokote...) online. I got ripped off a few years ago buying some off brand online, it was a smokey black and after a month was still too soft to buff.
    Anyone used or seen the Rival black?
    Any other recommendations?
    pete2c likes this.
  2. da34guy
    da34guy
    LIMCO a Basf product
    Squablow likes this.
  3. evintho
    evintho
    I know Kirker supplies all of Summit's paint. Just did the roadster frame in their metallic silver and the body in Hot Rod Black. Pretty nice product.
  4. Stooge
    Stooge
  5. blowby
    blowby
    from Nicasio Ca
    Thanks guys. My shop teacher mentioned the TCP, it's about $150 to my door. I need to see if there's anything around the college (where I am doing the work) painted with it. Also plan to go to the local paint shop and have a look at the Rival black. And check out the other recommendations.
    I suppose I am spoiled, the last time I painted a car black I used PPG Concept triple black, a really dark blue black. I can only imagine what that stuff costs these days. I wouldn't mind the cost if I was a better painter and didn't end up spilling it or having do overs. :(
    VANDENPLAS likes this.
  6. Shopline ppg is ok
    If ya want it slick, use a product that you can mix the paint with a clear
    They would have to use the same hardner
    Cover it with straight single stage black Then a couple coats of “ ****tailed “ single stage mixed with clear
  7. Gman0046
    Gman0046
    The last time I used Limco lll a BASF product base coat it was $17.95 a quart.
    da34guy likes this.
  8. jimgoetz
    jimgoetz
    Why?
  9. deuce1932
    deuce1932
    from Australia
  10. Looks great
    That’s how this one is sprayed
  11. deuce1932
    deuce1932
    from Australia
  12. da34guy
    da34guy
    It's gone up since 1980 Gary LOL
    -Brent-, BigO, Zookeeper and 2 others like this.
  13. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Tamco! Great quality, not the price of the famous names. Even has a special line of single stage blacks so you can have a super black black.
    blowby, Stooge and Frankie47 like this.
  14. Stooge
    Stooge
    I havent used tamco yet, but i follow the owner on IG and along with a handful of painters that use her stuff, it looks like a great product, and i think they just updated their website to make buying it a little easier
  15. Frankie47
    Frankie47
    from omaha ne.
    In 1980 I was getting free Imron from Uncle Sam...but it only came in black
    white
    orange
    red
    blue.....lol
  16. Ppg del fleet is some really tough paint and easy to shoot. Pretty forgiving and if you use the clear reduction method you can cut and buff to perfect if you want it. Tough on a level with old imron
    It's not the cheapest stuff but it's certainly not expensive relative to other stuff out there.
    Frankie47 likes this.
  17. jimgoetz
    jimgoetz
    This ones single stage with hardener sprayed in my 2 car garage and cut and buffed. No clear, I just don't like the plastic look I think clear gives. DSCN1235.JPG
  18. southpaw-customs
    southpaw-customs
    I would suggest Southern Polyurethane. But I see you are in California and you can't shoot it there.
  19. Absolutely looks great
    The ****tail clear/single stage doesn’t look plastic either
    That’s why we do it. Looks very deep in black
    Not a big fan of newer high solids clears
    jimgoetz likes this.
  20. blowby
    blowby
    from Nicasio Ca
    Thanks. Yeah I'm going to take a drive up there today and show them this. The guy I spoke to on the phone sounded like a rookie. So Nason is Dupont and good stuff? Buying local has the advantage of going to get more of anything you run out of. However, I am in the California clean air zone or whatever you call it. Used to be people drove north about 80 miles to buy better paint, I don't know if that is the case anymore or if it's all the same now.
  21. slug
    slug
    I agree with jimgoetz above about the look of most clears. They usually make the colors look too fake or plastic.
    BigO and a boner like this.
  22. blowby
    blowby
    from Nicasio Ca
    I doubt I will be mixing in clear for simplicity reasons. My heap is a driver, I run errands in it and foresee repairing dents and scratches. Not after show quality. I was thinking lacquer at first but the durability of urethane can't be beat, and afaik a single stage black can be blended and buffed as easily as lacquer, correct me if I'm wrong.
  23. I've used Rival many times. It's fine. Use it.
    blowby likes this.
  24. Nothing is blended, buffed or spotted as easy as lacquer
    The ****tail with clear is how we blended single stage
    Contact a guy here called paint guru if ya want lacquer, he can hook ya up
    jimgoetz and blowby like this.
  25. 40FORDPU
    40FORDPU
    Another vote for TCP Global restoration shop.
    I've painted several cars using their acrylic urethane, I've only used their black on misc. small items.
    These pics are of my '39 dash I painted with it.
    Reasonably cheap, compared to other brands.
    cvstl, reagen, blowby and 3 others like this.
  26. K13
    K13
    The two things they will tell you right off the bat from looking at the picture is one the activator is not Nason it's their own generic brand so zero warranty if the paint fails and two if they are using the same Nason part numbers (which they appear to be and IMO is a slimeball move) for their generic activator it is not VOC compliant so not legal in California.
    blowby and Bondo Slinger like this.
  27. missysdad1
    missysdad1
    This is exactly the reason I use single stage urethane on my hot rods. Modern paints just look too good to be appropriate on vintage-style hot rods and customs.
  28. jimgoetz
    jimgoetz
    Never tried it. How is it to match for touch up?
    blowby likes this.
  29. A Boner
    A Boner
    Would be interested to know if the not VOC compliant, "not legal in California" has something to do with the cost differential?
    blowby likes this.
  30. No different in my experience
