Technical Sealing a steel head gasket
Discussion in 'The Hokey Ass Message Board' started by tin_indians, Feb 13, 2019.
  1. tin_indians
    tin_indians
    Tried a search but nothing came up for steel...Replacing the steel head gaskets in my rod, is there a sealant/spray to use?
    I've never torn an engine down this far and never heard of a .015" gasket being used.
    Thnx.
  2. squirrel
    copper coat spray, or permatex aviation sealer brushed on around the water jacket holes, should do the job.
    dana barlow and Truckdoctor Andy like this.
  3. Paul
    Paul
    Editor
    I've had pretty good luck with Coppercoat spray too,
    Go a little heavy and install wet
  4. Deuce Lover
    Deuce Lover
    Hylomar blue works great.I used it on my copper head gaskets on my flatty and it works great.Always stays sticky.
  5. Heavy Old Steel
    Heavy Old Steel
    I have used Indian Head Gasket Shellac on copper head gaskets with success
  6. jaw22w
    jaw22w
    from Indiana
    Just did one with a .015 steel shim gasket. Used Permatex Copper Spray-A-Gasket 80697. No problems.
    Truckdoctor Andy likes this.
  7. onetrickpony
    onetrickpony
    from Texas
    In the past when I was in a bind I have used silver spray paint. It is slow drying and gives plenty of time to get the head torqued. No leaks later.
    But K&W Copper Coat is my preferred sealant for steel shim head gaskets.
    Algoma56, vtx1800, egads and 2 others like this.
  8. jimmy six
    jimmy six
    ^^^ That's what I did back when I used them.^^^^
    egads likes this.
  9. Mike VV
    Mike VV
    from SoCal
    Again...Copper Coat. Spray or brush on.
    Spray is best for a head gasket.
    Best stuff out there. It stays mostly semi fluid for years. Remove a head five years down the road, the stuff is still a bit sticky. The copper fills most voids.
    Mike
  10. oldiron 440
    oldiron 440
    Copper coat here also but I have used silver paint also, probably before I new about copper coat. o_O
  11. bobss396
    bobss396
    The copper spray was all we used on boats. May have been a Permatex marine product, but it worked.
  12. sunbeam
    sunbeam
    I've used a liberal coat of high temp aluminum paint use while the paint was still wet. Iron heads only.
  13. tin_indians
    tin_indians
    Cool guys, thanks a bunch. Looks like its the copper spray.
    And you spray both sides of the gasket right?
  14. JOECOOL
    JOECOOL
    yes both sides and another user of aluminum paint here
