Projects 65 Ranchero Southeast Gasser build
Discussion in 'Traditional Hot Rods' started by colbyw, Dec 28, 2017.
  1. Atwater Mike
    Atwater Mike
    GREAT Ford thread, Colby...I see a Giant Killer in the making.
    With the roll cage struts going thru the 'backlight' (rear gl***) space, will that backlight be plexigl*** with holes cut for the struts?
    Excellent construction. Just excellent!
    Thor1, loudbang and colbyw like this.
  2. colbyw
    colbyw
    Yeah it’ll be plexigl***, the bars go down right at the top so It’ll be two slots.
    Thor1, enloe, loudbang and 1 other person like this.
  3. Scott Mize
    Scott Mize
    Will you be attending the 6/8 SEGA event south of Nashville?
    Thor1, loudbang and enloe like this.
  4. colbyw
    colbyw
    Maybe, that is one of the closest ones. Nothing is set in stone yet.
    Thor1, Dog_Patch and loudbang like this.
  5. brEad
    brEad
    Looking good! I’m digging the black n white ch***is color scheme. Going to contrast nicely with the body color!
  6. Scott Mize
    Scott Mize
    Hope to see you. Quain allows us to make some exhibition p***es between rounds with our original g***er. Also. We will also have the original King Kong Anglia at the event. Here’s a photo from an appearance of both cars at an event in August. Will be looking for you. [​IMG]
    Thor1, enloe, catdad49 and 6 others like this.
  7. Dog_Patch
    Dog_Patch
    Dang how did I miss this thread? Very cool!
    Thor1, enloe, Doctorterry and 2 others like this.
  8. DILLIGASDAVE
    DILLIGASDAVE
    Question, when some guys building these g***ers say they are going to use "Plexigl***" for the windows are they really using the much safer Lexan/Margard material, but just using the term "Plexigl***" instead because it sounds more period correct?
    Or are guys actually using the less safe/more crack-snap-shatter prone Plexigl*** material?
    Thor1 and loudbang like this.
  9. Doctorterry
    Doctorterry
    Pretty sure they use lexan. Someone else can say for sure
  10. Great build! How do you find time to eat, sleep, and study? You guys do top notch work!
    Thor1, colbyw, rawcjw19 and 1 other person like this.
  11. rawcjw19
    rawcjw19
    Thanks. He has had a lot of snow days, that has certainly helped on this build. Mother Nature must like g***ers[emoji3]
    Thor1, OahuEli, loudbang and 2 others like this.
  12. colbyw
    colbyw
    Finished putting the front end together.
    Thor1, saltflats, brEad and 8 others like this.
  13. Doctorterry
    Doctorterry
  14. colbyw
    colbyw
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    The car is a roller! Also ran across a good deal on a used Jerico and a ram clutch. Finished the wheel tubs and we’re going to do the floors this weekend.
  15. rawcjw19
    rawcjw19
    I had a little time at lunch so I designed his tunnel.[​IMG]
  16. Doctorterry
    Doctorterry
    You two crack me up [emoji23]
    Thor1, OahuEli, enloe and 3 others like this.
  17. Hang'emHigh
    Hang'emHigh
    Damn system keeps dumping my thread subscriptions. Glad to see it's rolling now. Must've felt great rolling her out in the sun for the first time!
    Thor1, loudbang, enloe and 1 other person like this.
  18. colbyw
    colbyw
    Yeah it’s gonna be even better too hear it start for the first time
    Thor1, Gammz, loudbang and 1 other person like this.
  19. colbyw
    colbyw
    [​IMG][​IMG][​IMG]
    Spent the weekend at my dads work doing sheet metal work. It’s not completely done and fastened down yet but all the pieces are made.
    Thor1, OahuEli, enloe and 7 others like this.
  20. wrenchbender
    wrenchbender
    Looking good man hope to see it run this year that sheet metal work can be real time consuming I’ve been doin the same thing on my afx dodge I don’t think I’m ever gonna get it done lol. Keep up the good work
    Thor1, enloe, Dog_Patch and 1 other person like this.
  21. colbyw
    colbyw
    Thanks it definitely took a whole lot longer than I thought it would but I’m really happy with how it turned out.
    Thor1, enloe and loudbang like this.
  22. colbyw
    colbyw
    Doors are on.
    Thor1, Fiddle Picker, OahuEli and 6 others like this.
  23. colbyw
    colbyw
    Started on the flip front got the sliding and hing mechanism working but ran out of material too mount the pins.
    Thor1, Fiddle Picker, ottoman and 9 others like this.
  24. pumpman
    pumpman
    Look'n good and moving right along.
    Thor1, colbyw and loudbang like this.
  25. colbyw
    colbyw
    [​IMG][​IMG]
    Some more of the Tin work done
  26. colbyw
    colbyw
    Making a lot of forward progress on the ranchero.
  27. saltflats
    saltflats
    from Missouri
    Looking real good.
  28. 4 pedals
    4 pedals
    from Nor Cal
    Saw your thread when it was new, lost it since, good work since! Re-sub'd!
  29. loudbang
    Your fathers is getting nervous now. Not long until judgement day. :)
    Thor1, 1947knuck, Doctorterry and 3 others like this.
  30. saltflats
    saltflats
    from Missouri
    That little Ford better eat it's Wheaties. ;)
    Thor1, Gammz, rawcjw19 and 3 others like this.
