Hot Rods Hot rod powerplants, hot or stock
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 14, 2019.
What kind of engine do you prefer?
Poll closed Feb 21, 2019.
  1. Bone stock- nice smooth idle
    16 vote(s)
    12.7%
  2. Stock with a lumpy cam for that potato potato potato sound
    85 vote(s)
    67.5%
  3. Full on ridiculous, gotta run race fuel, kick it up in neutral at stoplights
    25 vote(s)
    19.8%
  1. Roothawg
    Roothawg
    I always start out wanting to just build a driver, but eventually the performance starts creeping in and before you know it, it has a big lumpy cam and no street manners. I can't help it, no matter how hard I try.
    So are you a guy that is ok with a junkyard motor, a stock crate engine or a lumpy cam guy?
    VANDENPLAS, Hombre and chryslerfan55 like this.
  2. bdynpnt
    bdynpnt
    I buy a donor car then sell the leftovers
    Sent from my SM-G965U using The H.A.M.B. mobile app
  3. Guess which one I am.
    The 261 in my 53 Chevrolet-
    My next 261-
    upload_2019-2-14_18-37-15.png upload_2019-2-14_18-37-33.png upload_2019-2-14_18-37-56.png upload_2019-2-14_18-39-18.png upload_2019-2-14_18-40-8.png upload_2019-2-14_18-40-28.png upload_2019-2-14_18-41-32.png upload_2019-2-14_18-41-51.png upload_2019-2-14_18-42-14.png upload_2019-2-14_18-43-14.png upload_2019-2-14_18-43-33.png upload_2019-2-14_18-44-13.png upload_2019-2-14_18-44-55.png
  4. rockable
    rockable
    In drive mine on the street and on trips. I want a well behaved engine that pulls an A.C. compressor at idle without problems and has enough power to smoke the tires just once and a while. I've slowed down a little in my old age.
    modified and trollst like this.
  5. Taboo56Chevy
    Taboo56Chevy
    I always lean to more performance oriented engines, though I prefer to stick to factory based stuff. So 2.02 camel humps, Z/28 or L79 intakes, 097, 30/30, L79 cams. Though do like playing around with different intake carb setups. Run alot of dual quads, tri-powers and 6x2's
    loudbang, trollst and mad mikey like this.
  6. paul philliup
    paul philliup
    from ohio
    I know what your saying but performance is a big thing. I only plan on pulling a alternator, water pump, and A/C . IMG_20190126_113751654.jpg
    Repman, loudbang and mgtstumpy like this.
  7. flamedabone
    flamedabone
    Stock ****s. If you do it right, you can make lots of power and still be within a reasonable definition of traditional.
    -Abone.
  8. 6sally6
    6sally6
    When I built my SBF for the old hotrod I researched the net and decided to have a custom ground roller cam.(I just love how that kinda rolls-of-the-tongue...roller cam)
    Anyway I talked to the guy and said...."I have waited for nearly 50 years to build a hot rod and I durn sure want it to sound like a hot rod." He laughed and said 75% of the cams they grind are for guys who want the same thing!
    You CAN have a snotty cam and still enjoy it in traffic. Sounds (and runs) like the old 375HP 327 in a 60's vet.
    I luv it!!!!
    6sally6
    My wife's Altima is available when I want a smoooooooth sounding engine.
    modified, loudbang and mad mikey like this.
  9. radarsonwheels
    radarsonwheels
    from Philly
    I am trying to grow up and run milder valvetrains. The motor I just built is a reasonable .507” lift and a little lumpy in the 240°s @ .050” for a flat tappet but it’s in a 512 CID mill so that should give good manners and tame some rumpetyness. It won’t p*** a gas station or come close to the cl*** of a 60s style multi carb setup
  10. Atwater Mike
    Atwater Mike
    I'm trying to get more 'conservative' with engine 'tuning' lately...but have you ever had a nice-mannered cam about to go into a planned out engine with everything new, but that nice tame cam just WON'T plug into the #1 cam bearing???? -Like 2 similar magnets...Just won't start in there! Something's 'repelling' it...:rolleyes:
    Repman and mad mikey like this.
  11. mad mikey
    mad mikey
    Most of you guys know what I am into and do. 406 CID, 471 pro built blower, 650 lift roller, heavy mods on the heads, light weight forged crank, etc,etc. And yes I drive on the street. WIN_20170423_12_34_39_Pro.jpg
    mkebaird, jnaki, exterminator and 7 others like this.
  12. blowby
    blowby
    from Nicasio Ca
    Once you've been blown,
    Nothing's left alone.
  13. DDDenny
    Hot
    Just trying to stay one step ahead of the traditional police!
    mgtstumpy and Montana1 like this.
  14. mohead1
    mohead1
    Big roller cam, aluminum heads, single plane, 850 dbl pumper, 11:1....yeah id say ive got the hot side bug.... cant help it
    Sent from my SM-G900V using Tapatalk
    [​IMG][​IMG]
    quick85, Repman, loudbang and 2 others like this.
  15. WB69
    WB69
    from Kansas
    Have had both. Like both. More to the milder side lately however. Lumpy sound is a must!
    modified likes this.
  16. Black_Sheep
    Black_Sheep
    51165986_2004356086268529_5527216150779265024_n.jpg For a nice cruiser I prefer a mildly built big block for the torque, drivability and low maintenance.
    quick85, mkebaird and Frankie47 like this.
  17. lumpy 63
    lumpy 63
    I like blowers....
  18. 327Eric
    327Eric
    My finances dictate a milder build, my instincts dream of more. What is stock anyways, after you add aftermarket intake, exhaust, and headers. Roller rockers, head work, there are still ways to squeeze more power out of a stock, or mildly cammed engine.
  19. squirrel
    totally depends on the car. The blown hemi, and the blown 427, are a bit snotty. still streetable.
    mostly the other ones get pretty mild cams, maybe 235 degrees at 050 or less.
    winduptoy and olscrounger like this.
  20. primed34
    primed34
    Put me down for a lumpy cam with a side of compression.
    loudbang and Budget36 like this.
  21. Rocky
    Rocky
    Classified Editor
    Mine has a manual transmission and a quick change rear so I can run it on the street without too much trouble. The big cam, pop up pistons might be unpleasant with an automatic trans. It's tame enough I can run 91-93 octane So I'm kinda in the middle between stock with a cam and "wild and crazy"
  22. Jalopy Joker
    Jalopy Joker
    do not like the 3 options listed above - small block will provide plenty of performance, without need for a lumpy cam. just need to make sure that whoever does machining cleans heads/valves up real good, complete cam kit with matching springs/rockers, etc -good intake/carb/ignition - good flowing exhaust system - type of transmission and rear gears important to figure out what type of power at the rear that you will end up with - just don't go too cheap with whatever you do - or go all in with a 1,000 HP big block
  23. oldiron 440
    oldiron 440
    Who wants a stockrod, I see no fun in that! I need to rattle the windows as I drive up the street. I really like setting off car alarm's!
    E 85 no need for race gas on my 12.5 motor.
    quick85, mkebaird, loudbang and 2 others like this.
  24. Roothawg
    Roothawg
    Glad to see that I am not the only one....
    mkebaird and loudbang like this.
  25. Bandit Billy
    Bandit Billy
    Your choices in the opinion poll leave a lot of area unexplored. I don't go the full race method but I don't build stock or cammed up stock either. I love "hot rod" engines, the use of the word "hot" though should signify more than a rake or painted flames or some louvers, it had better f'n scoot!
    This is the roadster
    This is going in the 41 truck
  26. flatheadpete
    flatheadpete
    from Burton, MI
    Billy has some of the coolest stuff....
    loudbang and Bandit Billy like this.
  27. Mine would be an around-towner. I want to be the first one to hit 45mph away from the light. Give me a baby cam salad with torque dressing on the side.
    winduptoy likes this.
  28. Sactownog
    Sactownog
    from SAN DIEGO
    I have always been a hot rod type of person, I love the sound of a loopy motor, a cam that makes the motor sound like its giving off the (tim the tool man) uff uff uff....
    I now have the 230 flathead 6 that I want to hot rod but leave the car stock, and really I can wait to hear the L-6 sounding like a bad mofo. old school hot rod originality.
  29. Roothawg
    Roothawg
    Well, it is a scientific poll.... ;)
  30. Hombre
    Hombre
    I always tell myself, I want reliable and dependable, something I can cruise in and have no worries. I am one of those guys that actually drive my car to a lot of places. I want it to look cool at the same time. Trouble with that is I never seem to do that. I get to building a motor and that 17 year old kid inside of me takes over. So far I have been pretty lucky I guess in that all of my engines make the trips and even though they are far from stock they are serving me well.
    As an example for my Model A I always wanted a early Hemi, finally found a builder and was keeping it pretty simple in the beginning but as always it just got out of hand. IMG_3019 (Medium).JPG
