Projects 3rd Hand Scrap.
Discussion in 'Traditional Hot Rods' started by Internet, Jan 29, 2017.
  1. embyman68
    embyman68
    It means to get rid of...
  2. Desmodromic
    Desmodromic
    That's what I was afraid of.
  3. colineunson
    colineunson
    from Victoria
    It has radius rods tied to the center trans mount plus an additional bar from the rear end to the cross member
  4. Atwater Mike
    Atwater Mike
    Is it the camera lens or are the front tires toed out??? Please measure from the centers of tire treads (or the edges of tires, left-to-right, fronts of front tires vs. rears of front tires. Should be 1/8 of an American inch 'toe-in'.
    "Toein' IN, Son..."
  5. Desmodromic
    Desmodromic
    I believe I saw the "radius rods" in the early pictures. Not sure what your describing as "additional bar", but if it's like a Panhard rod (running transversely), my comments are still applicable. If it's a fore-and-aft link from the top of the diff housing to the ch***is (preferably near the transmission crossmember), I would no longer have a comment, except to say you should have something to preclude lateral movement of the rear (e.g., Panhard bar).
  6. dumprat
    dumprat
    from b.c.
    Ya don't need a panhard if you have enough triangulation.
  7. Desmodromic
    Desmodromic
    I'll concede a Panhard may not be necessary, but if there is no additional fore-and-aft link, besides the two that are clear from the pictures, then this suspension is like a 4 parallel-link design, with the top links left out. This also results in a high bending stress level where the perch is welded to the axle housing, if there are no gussets on the perch plate.
  8. colineunson
    colineunson
    from Victoria
    It has one, exaclty as you describe it. il snap a pic next time im in the shop:)
    Until then, dug deeper and found rediculous slop in the timing chain..
    So new set of gears and chain on.
    Clutch going in and should have it back on the road weds with NO leaks!
    Stay tuned
  9. colineunson
    colineunson
    from Victoria
    To clarify it does not have a panhard bar but as mentioned it is widely triangulated so no need.
  10. dumprat
    dumprat
    from b.c.
    Need some real headers for that? I have a set of 289 long tubes.
  11. colineunson
    colineunson
    from Victoria
    Thanks for the offer! Next season i think il do a lake style header that wraps down beside the framerail
    The flexpipe will get header wrap and stay for now...
  12. dumprat
    dumprat
    from b.c.
    Fair enough! Keep at er. It's come a long way since I saw it in the ba*****t.
    Could cut up the stripper pole and build pipes with that! Lol
  13. colineunson
    colineunson
    from Victoria
    Tim likes this.
  14. colineunson
    colineunson
    from Victoria
    No leaks!!!
    Header wrap tomorrow, and will be able to take it out for a spin, then off to get the top done properly,
    That should be the next update
    bct and Tim like this.
  15. Tim
    Tim
    from KCMO
    Looks good!
  16. colineunson
    colineunson
    from Victoria
    Tim likes this.
  17. colineunson
    colineunson
    from Victoria
    D3ECF61E-56B0-48A8-AE1C-17B0BCB790B4.jpeg After...
    Before...
    sloppy jalopies likes this.
  18. colineunson
    colineunson
    from Victoria
    52E6224B-7D24-444E-B3A4-45BBFAD46CD5.png Next up. Top is getting done!
    Tim likes this.
  19. colineunson
    colineunson
    from Victoria
    BE9FA994-F552-4A56-A222-BDF25CDA99EF.jpeg 5B2273EA-D6C7-4688-BB77-CFCB4AC66D43.jpeg Well this turned out great! Thanks lg kustoms for the louvers!
    Nailhead A-V8 likes this.
  20. rusty rocket
    rusty rocket
  21. colineunson
    colineunson
    from Victoria
    Cool speedster!
  22. colineunson
    colineunson
    from Victoria
    DFB99CF5-7273-4BB7-AFF3-E477CAF62328.jpeg Got the top painted up and finally getting it covered tomorrow-ish
    Should be back on the road for the weekend
    Then i just need to put the new tires on in the rear and il be done for now besides small stuff
  23. Fortunateson
    Fortunateson
  24. colineunson
    colineunson
    from Victoria
    Your right, its gotta go next oil change for sure.
