Projects putting a roof on my sport coupe
Discussion in 'Traditional Hot Rods' started by marcshall, Feb 17, 2019.
  1. marcshall
    marcshall
    making a 3 window coupe. I will bolt it all together then when satisfied I will weld her up
    IMG_0868.jpeg IMG_0869.jpeg IMG_0870.jpeg IMG_0872.jpeg IMG_0874.jpeg IMG_0876.jpeg IMG_0868.jpeg
  2. Limey Kid
    Limey Kid
    Looks great so far.
    Cheers,
    Stewart.
  3. sloppy jalopies
    sloppy jalopies
    looking good, gonna be cool...
    If you don't have the **** pit combing strip [hens teeth]... try the cowl band from a '30-'31 AA truck,
    steel not stainless, radius is very close to that of your **** pit... will need 2... forward, leading edge of the band "on the truck" will mount upwards...
    I laid one down on the pictured body, seems to match pretty well... go marc go...
  4. chev34ute
    chev34ute
    Is this a respliced Tudor roof or did you shape it with a power hammer ?
  5. Tim
    Tim
    from KCMO
    Proportions look pretty dead on. Curious to see how you dial it in!
  6. marcshall
    marcshall
    my guess is it's from 28 to 31 Tudor or four door roof. got pieces from different swap meets .p***enger side pretty good fit drivers side not so good .
  7. marcshall
    marcshall
    started with a plate below back window used original holes and worked my way up IMG_0875.jpeg IMG_0871.jpeg Screen Shot 2019-02-17 at 7.41.04 PM.png
    catdad49 likes this.
  8. NashRodMan
    NashRodMan
    You did a nice job fitting it all up. And...you really like stop signs! lol
    slv63 likes this.
  9. bubba55
    bubba55
    Wow - that's slicker than snott on a door knob
    Nice job - keep that brain cell - it did good!
  10. so that's where all the street signs went!
    Joking aside, nice job.
  11. GordonC
    GordonC
    Nice job! Proportion look great.
  12. Binger
    Binger
    from wyoming
    This looks great. What are your plans for above the doors and header? going to build it like a standard coupe with drip rails and so on? Filled roof? Visor?
  13. marcshall
    marcshall
    ya drip rails and a visor. and fill in the roof I want it to look like factory made with a Canadian beaver on the rad .the drivers side top piece is way more work then the p***enger side
    catdad49, Stogy and rudestude like this.
  14. rudestude
    rudestude
    Beaver ...a..Canadian Beaver even.....well I don't think my radiator cap has had any Canadian Beaver.... 20190218_235044.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
    Jet96 and catdad49 like this.
  15. bangerbob
    bangerbob
    Jet96, catdad49 and Stogy like this.
  16. 63Compact
    63Compact
    That's looking really good keep going.
  17. junkman8888
    junkman8888
    Before you start welding you might want to search "Model A three window" here on the HAMB, I believe your car would look better with longer doors.
    BigChief likes this.
  18. sloppy jalopies
    sloppy jalopies
    '30-'31 coupe doors are 27.5" F to R...
    the '30-'31 tudor / trucks are 29.25" … and are 1" taller from the top hinge upward.
    the hinge placement is the same for all 3 of the hinges ...
    BigChief and Dannerr like this.
  19. marcshall
    marcshall
    will both my 29 sport coupes the doors are 29 1/4''wide my 30 Tudor sedan is 29 1/4''wide I do like longer doors
  20. 61gasser
    61gasser
    Any progress?
  21. deathrowdave
    deathrowdave
    from NKy
    Damn that top is fine as frog hair split two ways !
  22. LKR
    LKR
    from Australia
    Nice work - I too have a sports coupe and am contemplating a removable hard top like this. Good to see one done well!
  23. coupe33
    coupe33
    I was always very curious about how it would look. The funny thing is I have seen a lot of sports coupes go fairly cheap and if this gets out they will bring higher prices!
