Hot Rods Holley 660's on sale, DISCONTINUING
Discussion in 'The Hokey Ass Message Board' started by swade41, Feb 20, 2019.
  1. swade41
    swade41
    from Buffalo,NY
    wraymen, Deuces, loudbang and 3 others like this.
  2. Mike Colemire
    Mike Colemire
    Man that is a heck of a mark down. I've seen used ones that they were asking $300 to $350 for.
    swade41, Deuces and loudbang like this.
  3. 24riverview
    24riverview
    My son just ordered 2, maybe I'll get mine back, :D.
    Clay Belt, Deuces, VANDENPLAS and 2 others like this.
  4. DDDenny
    I don't even need them and I think I should get a couple.
    Hmmm, that sure would soften the blow on a new tunnel ram!
    swade41 likes this.
  5. swade41
    swade41
    from Buffalo,NY
    Sold out, no backorder, DISCONTINUED
  6. lumpy 63
    lumpy 63
    Got a confirmation from Holley , sent order in 2 hours ago, hope they get here!:DBuilding a 377 ...Thanks Swade:cool:
    dan31, Deuces, swade41 and 1 other person like this.
  7. Squablow
    Squablow
    Sounds like they're all sold out, but thanks Swade41 for sharing, this is the kind of stuff that it pays to know about.
  8. vintagehotrods
    vintagehotrods
    Still showing that they are in stock when I checked right now. Be aware it's a no choke mechanical secondary set up for two four in-line tunnel ram applications.
    Larger Image
    660 CFM Center Squirter Carburetor
    No Choke Mechanical Secondaries-4160
    CFM
    660
    PART# 0-4224
    Be the first to write a review
    $817.95 Suggested Retail
    $205.92 Your Price
    Free Shipping
    In Stock [​IMG]
    Qty:
    Overview
    The Holley 660 CFM Center Squirter carburetor is just as much at home on a compe***ion vehicle as it is on a show vehicle parading around the fairgrounds. Designed for 2 x 4 in-line tunnel ram applications, the 0-4224 carburetor features a compe***ion fuel curve to provide safe and reliable horsepower, no choke for improved airflow, 1 to 1 mechanical secondaries for tire turning power and a unique center accelerator pump discharge nozzle for the perfect amount of initial fuel.
    Features:
    • Gold Dichromate finish for corrosion resistance and cl***ic Holley looks
    • Calibrated for use with a 2x4 intake set-up
    • No choke for unobstructed airflow
    • 1:1 mechanical linkage for awesome tire turning performance
    • 50cc center discharge pump for the right amount of fuel in all four bores under initial acceleration
    • Single feed fuel inlet for easy installation
    • 100% wet-flow tested by Holley technicians to ***ure it arrives ready to run!
    Specs
    Barrels 4
    Booster Straight
    Brand Holley
    CFM 660
    Choke None
    Emission Code 3
    Finish Gold Dichromate
    Fuel Gasoline
    Fuel Inlet Single
    Material Zinc
    Model 4160
    Primary Main Jet 76
    Primary Pump Nozzle Size 25
    Product Type 4160 Model Carburetor
    Secondaries Mechanical
    Secondary Pump Nozzle Size 25
    Supercharged Application No
    Throttle Bore 1.688 inch
    Vacuum Ports 1 timed (spark) port, 1 full, and 1 PCV port
    Part Number 0-4224
    *Free Shipping & Handling only offered to the contiguous US on orders over $100.
  9. oliver westlund
    oliver westlund
    says theyre in stock still! they could still be run by themselves youd just have to add a choke or run without a choke
  10. I just got a pair...……… so there still in stock
    some small changes to make for my blower application. Cheaper than a pair of used ones that will still need changes !
    Clay Belt and oliver westlund like this.
  11. swade41
    swade41
    from Buffalo,NY
    It's saying not available on line for me
  12. Deuces
    Deuces
    I have an 850 CS carb list-4223 in my stash.... Don't have nothing to put it on at the moment.... Guess I'll let it collect dust for a little while longer... ;)
  13. lumpy 63
    lumpy 63
    Woo Hoo! got shipping confirmation this morning:D
    Deuces and swade41 like this.
  14. 660s work good on the track. They can work good on the street to. I modified the slot that controls the secondaries. But grinding some material away the primaries are able to open some before all eight barrels are flowing. I use a caliper between the base and primaries to get them opening the same amounts. I would grind the about half way up the slot then make a gradual ramp to start opening the secondaries. It's easy to wash the cylinders down with that much gas flowing. This modification really helps for the street. I wonder if they also have the various metering plates on sale to really dial them in.
    lumpy 63 and Tickety Boo like this.
  15. Racingsnake
    Racingsnake
    from So Cal
    Do you have a picture showing the modified slot?
  16. swade41
    swade41
    from Buffalo,NY
    Me too !
    lumpy 63 and Deuces like this.
  17. Deuces
    Deuces
    The metering plates can be machined for screw in air bleeds of different diameters..... Got a picture here somewhere.... I'll post it later this evening... ;)
    lumpy 63 and egads like this.
  18. Deuces
    Deuces
    You could use a secondary metering block from a 3310 carb......
  19. I dont have a pic. If you look at the pic posted above it should help. The secondaries are controlled by the slot in the linkage. The inside of the slot gets removed with a air file or dremel tool. Grind enough so the follower wont open the secondaries until you want them to. These carbs run all four ****erflies all the time. Street driven cars dont need a tunnel ram and eight barrels flowing. The accelerator pump is also pumping out of eight nozzles each time the linkage moves. The modification makes the carb act as a double pumper. The secondaries wont open until you want them to. Start with a little material removed and work your way up to get it the way you want.
    Deuces likes this.
  20. lumpy 63
    lumpy 63
    The only problem with that is they will no longer fit inline on a tunnel ram.....
    Deuces likes this.
  21. tubman
    tubman
    I think I'm going to make that Holley site a regular stop on my morning Internet rounds. With carburetors going the way of the Dodo bird, this may be the start of something good.
    swade41 likes this.
  22. Fordors
    Fordors
    True, you can control when the secondaries open but the center squirter will give the rear barrels a pump shot immediately off idle, not when they finally open. That was why the double pumpers were introduced with their staged secondary control and individual pump cam.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
  24. flatheadpete
    flatheadpete
    from Burton, MI
    I ran a Demon on my straight 6 in my bucket. Ran like it was runnin from the cops! A friend runs a Demon on a 383 SBC in a monster truck K5 and it runs like crazy, too.
    Deuces likes this.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Hate to say it. This means carbs are being phased out. :(
    belair and lumpy 63 like this.
  26. Fordors that is true. The modification is a bandaid fix for street driving. I ran these carbs on a few cars over the years and the modification worked well.
    Deuces likes this.
  27. Chris
    Chris
    Deuces likes this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    I honestly know nothing about them. maybe someone else will chime in....they look a little too modern for me but a drop base air cleaner would probably hide it. the sale units do not have chokes. seems like they are geared towards racing?
    Deuces likes this.
  29. saltflats
    saltflats
    from Missouri
    These are 4223 s , but the same linkage as the 660s.
    The one on the left has been modified.
    Racingsnake, lumpy 63 and Deuces like this.
  30. Deuces
    Deuces
    Unless you mount those sideways.... Then you'll need carb spacers...
    lumpy 63 likes this.
