THE oldsmobile rocket 303 324 371 394 post to end all other posts, (lasalle related )
Discussion in 'The Hokey Ass Message Board' started by RocketDaemon, Dec 19, 2006.
  1. jebbesen
    jebbesen
    from Winona, MN
    Functionally I don't think it matters. There might be a difference in factory curve specs but either could be setup to work. Do you want the 303's old time looks or a window style distributors ease of tuning? @Paul can probably speak to this, but I think there are a couple different small distributor caps used. Might be 303 vs early 324? 56 on up look like the one I just posted pics of. They share most parts with a SBC. Window cap design makes tuning/advance changes way easier since the mechanical advance is on top vs under points plate.
  2. jebbesen
    jebbesen
    from Winona, MN
    If you want adjustable vac advance that might be harder to find for the early style.
    You might also be more limited as far as cap quality options.
  3. hotrodscott2003
    hotrodscott2003
    Just went to Ross Racing Engines website in search of pricing for a timing chain, starter, ect., for my 324. It looks like they have the stuff I'll need, but no pricing. What's the best way you guys have got in touch with them?
  4. vtwhead
    vtwhead
    I normally pm him and follow up with a phone call
    jebbesen likes this.
  5. Arkas
    Arkas
    from Germany
    I'm about to bring my 303 block to the machine shop. Was thinking of going. 125 over for 324 pistons. I know I'll have to get 324 head gaskets. Do I need to enlarge the chamber on my Stock 303 heads to match the gasket?
    Sent from my SM-G930F using The H.A.M.B. mobile app
  6. Paul
    Paul
    Editor
    Short answer is no
    Longer answer might suggest taking the sharp edge off at the chamber edge,
    But more important might be asking what do you expect out of the engine?
    What year are the heads?
  7. Arkas
    Arkas
    from Germany
    Dont expect too much, honestly. I was just going to change my cam to a custom one from Ross. I tore the Engine apart and almost every bearing is worn aswell as the crank.
    Since everything is going to the machine shop (and this kind of work is much more expensive here in Germany) I'd might aswell go bigger for the same price.
    The stock heads will choke the Engine for sure, but I'll probably change them later anyway.
    The heads are stock 1950 303.
  8. Arkas
    Arkas
    from Germany
    Quick question for the machine shop: piston to wall clearance on the 303 is how much?
  9. mgtstumpy
    mgtstumpy
    Here's a rare pre-production, 1 of only 36 287ci GM high compression test engine and the only one purportedly installed in a car. I didn't know it existed until I stumbled onto by accident. All I was aware of was the Kettering experimental OHV V8.
    An original manual from GM Research accompanies the car along with additional factory manuals, brochures and other items, all of which are detailed in the photo gallery.
    I've previously come across this R&D test mule engine however I can't recall if it was 287ci or 303ci?
    F&J likes this.
  10. hotrodscott2003
    hotrodscott2003
    Wanted to say thanks for all who gave me input into my distributor issues. Got it back together, the car runs better than it ever has. Going to do the heads next, and replace the timing chain. Two Model A's, a '63 Impala Wagon, and my '52 Chevy PU are all fighting for attention right now, so the T is on a slight hold...
  11. don colaps
    don colaps
    Hi guys. This may seem to be a dumb question maybe, but I’m rather new to rockets and I bought this 303 ”semi completed” from a fellow. So, this spring clad pin in my hand, I’m guessing it’s some kind of thrust thingie for the camshaft? Can’t find any pictures of were it should be located. In the front of the camshaft??
    Thanks a lot [emoji1]
  12. vtwhead
    vtwhead
    goes in the front of the cam after the fuel pump eccentric is installed if I recall correctly. Been a few years now since I have had one all apart. The Olds gurus will surely be chiming in....
    don colaps likes this.
  13. Paul
    Paul
    Editor
    Yes that is correct
  14. don colaps
    don colaps
  15. car doctor
    car doctor
    Anyone make headers for a 324 going in a 32 ford? I can't make any contact with noxious customs, he must have quit making them.
  16. engine138
    engine138
    from Commack NY
    I beleive he has taken a back seat on headers I've heard
    Maybe contact Tony at Ross racing
    Phone 330.544.4466
    330.720.1282
    Address 1763 North Main Street
    Niles, Ohio 44446
    car doctor likes this.
  17. jjjmm56
    jjjmm56
    from FL.
    You can buy a kit from hells gate hot rods and weld it yourself. Or maybe they can make it.
    saltracer219 likes this.
  18. Tbucketg
    Tbucketg
    I can make you a set. I thought I replied to your email. Let me know what you need.
    nochop likes this.
  19. Paul
    Paul
    Editor
    I'm posting this in an attempt to ***ist with answering questions about dis***embly of the '37 LaSalle top shift transmissions..
    cover.jpg page 117.jpg page 118.jpg page 119.jpg page 120.jpg page 121.jpg page 122.jpg page 123.jpg page 124.jpg page 125.jpg page 126.jpg page 127.jpg page 128.jpg page 129.jpg page 130.jpg page 131.jpg page 132.jpg
    Al M. and Speedy Canuck like this.
  20. Paul
    Paul
    Editor
    8518.jpeg Picture of version of tool J-806 as shown in figure 21 on page 128 above, made from whatever was on hand at that time.
    The tapered pin has a 1/4" 28 threaded end, screw the tool onto the pin and draw it out through the plugged hole on the side of the case.
  21. curt vesely
    curt vesely
  22. curt vesely
    curt vesely
    Been hanging around here a few years and here is my first question. Any of you Oldsmobile guys have any experience putting Oldsmobile engines in shoebox Fords? How about the dropped center link, anybody still making these? Thanks Curt...
  23. jebbesen
    jebbesen
    from Winona, MN
  24. senginc
    senginc
    from B'ham, AL
    Olds 303 7-30-19 (3).jpg Does anyone know how to distinguish a 49 from a 50 Olds 303, heads and intake and exhaust manifolds, water pump, timing cover, crank balancer/ pulley, flywheel.
    It was a complete engine with back draft carburetor. Has 49/50 stuff on a Rogers Remanufactured Engines cyl .040, mains .020, rods .010 but the Engine Block Serial number R422249 says the block is a 53. I wonder if the flywheel and lower bolt bellhousing and starter is for a 49/ 50 or a 53 ?
    My casting numbers do not agree with the records I have found so far. My numbers are all numerically lower.
  25. Paul
    Paul
    Editor
    fwiw, my Olds parts catalog shows the same number for '49 and '50 heads
    I have read conflicting versions of decifering date codes.. but that seems like the logical path
  26. ROADSTER1927
    ROADSTER1927
    49 has a different dip stick and tube and the distributor hold down is also different.
  27. Paul
    Paul
    Editor
    also, the plug wire looms were aluminum in '49 and steel in '50
    the four barrel carburetor wasn't available in '49 but both 2 and 4 barrels were available in '50
    manual transmissions were not available in '49
  28. senginc
    senginc
    from B'ham, AL
    My 2 bbl intake has 555693 casting #, the list I have found says 556714, 557709 for 49/50 and 560676 for 51-53.
    Maybe I have the early experimental manifold :)
  29. Didn't that two bolt distributor hold down carry through till 51?
  30. 36 ROKIT
    36 ROKIT
    One other visual, incidental detail, fwiw, the valve cover plug wire loom(?) was silver in '49, and gold in '50.
