Technical Mice In Model A Gas Tank
Discussion in 'The Hokey Ass Message Board' started by Time Bandit, Feb 21, 2019.
  1. Time Bandit
    Time Bandit
    I have a 1929 fuel tank that's in really good condition but it is filled with mice bedding.... like from bottom to top. Any ideas on what to do? Cut the tank? Thanks for your help
  2. Redrodguy
    Redrodguy
  3. rusty valley
    rusty valley
    vacuum, then evaporust with some bb's dumped in to knock the crud loose, shake-rattle and roll, rinse, dry, install
    dana barlow likes this.
  4. Time Bandit
    Time Bandit
    I vacuumed and flushed it with water. Nothing worked
  5. Time Bandit
    Time Bandit
    The mice bedding has sticks woven all through it
  6. Redrodguy
    Redrodguy
    Use a coat hanger with a hook bent on the end to drag out the bigger stuff (branches, twigs) and whatever else you can get out, then try the vacuum. Don't think you should cut the tank - would be the last thing I'd try if all else fails.
  7. woodiewagon46
    woodiewagon46
    from New York
    Vacuum sounds like a good idea, but the issue I see is that there are two baffles that run front to back. Perhaps if you put air into the fuel outlet on the p***enger side, to stir the stuff up. Unless you get it all out it will be a problem. Be careful of all the mouse **** it can be a health hazard wear a respirator!
    town sedan and czuch like this.
  8. woodiewagon46
    woodiewagon46
    from New York
    I should have asked in my first post, did you remove the spark arrestor from the fill hole?
  9. redo32
    redo32
    Mouse piss is corrosive, if they were in there long there are probably some bad rust pits.
  10. town sedan
    town sedan
    What they said! The tank might look good from the outside, but decades of mouse urine will have done a number on the inside.
    Use some sort of respirator also. What you want to be afraid of is Hantavirus, breathing dust from the nesting material & droppings is big time no go.
    -Dave
    belair, Danny Brown and Tim like this.
  11. ENUF 41
    ENUF 41
    Way back when took mind to radiator shop and had it vatted, probably want happen in todays time
  12. lucas doolin
    lucas doolin
    Since very competent advice has already been posted, I would ad - in today's politically sensitive environment - in order not to run afoul of current regulations, be sure to call the SPCA, have them send out a Mouse representative and post an Eviction order in a con****uous location.
  13. rusty valley
    rusty valley
    WTF ?????????
    flatford39 likes this.
  14. goldmountain
    goldmountain
    Those Model A gas tanks have baffles all over the place inside. Hide another gas tank somewhere else.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    town sedan likes this.
  15. town sedan
    town sedan
    Few years ago while taking a Y-Block apart I found an oil soaked mouse carc*** in the pan. I didn't call the federales. Please don't tell on me!
    -Dave
    Just Gary, Deuces and oliver westlund like this.
  16. alanp561
    alanp561
    Be sure to call a local Haz-Mat spe******t and have them dispose of the toxic mouse turds;)
    Deuces and town sedan like this.
  17. BJR
    BJR
    Mice in the gas tank only work if you are running a mouse motor. Problems for all other engines.:eek:
    alanp561 likes this.
  18. Deuces
    Deuces
  19. Russ B
    Russ B
    If you are building a hot rod you probably only need the top and firewall portions. Rat pee has probably given the tank dozens of pin holes which will be seen once the tank is stripped of paint, unless the mice/rats are only very recent occupants. The area under the tank cover is usually filled with wiring and instruments. In the sixties it often had swing pedals with a firewall mounted master cylinder. If you are not doing a restoration you might want a larger tank.
    Bam.inc likes this.
  20. Ebbsspeed
    Ebbsspeed
    Burn it out, then vacuum out the ashes.
    Bechtel 56, Tim, clem and 2 others like this.
  21. HOTRODPRIMER
    HOTRODPRIMER
    I totally agree, probably in pretty bad shape. HRP
  22. woodiewagon46
    woodiewagon46
    from New York
    You don't mention if the tank is in the cowl or off the car. If you have someone capable of TIG welding the tank can be cut. This is what I did. There are two baffles as I originally stated, both front to back. Under the tank you can see the spot welds that hold the baffles in. I cut a 3"x12" access hole just forward of the closest to the firewall spot weld using a thin zip cut wheel, across the front edge of the tank where it curves up. This will give you clear access to the interior of the tank. Have the insides of the tank media blasted and have the access holes TIG welded up. Then I used Bill Hirsch gas tank sealer, it's compatible with todays gasoline. If someone can walk a computer illiterate person, (me) how to post pictures I can show you what I did.
  23. dwollam
    dwollam
    The mouse turds will act as stop leak, right?
    Dave
  24. Time Bandit
    Time Bandit
    The tank is off the car. I'm just wondering if I should go through the trouble of cutting and welding or just put a new tank. I really like how easy the gravity system works in the model A and I'm not sure how to run any other kind of gas tank
  25. Stogy
    Stogy
    :rolleyes:...Maybe this will work...:D
    This hobby is not without its challenges...
    I suppose it's a good candidate for the acid or boiling method used to clean engine blocks and things...
    or the one they use to strip car bodies of rust and things...actually gas tank repair companies may have specialty tanks for clearing tanks for repair...of course like everything there is a cost...;)
    This actually cleared up 2 problems the Rodents and the seizing in the block...
    https://www.jalopyjournal.com/forum/threads/1940-desoto-coupe-project.1130573/
  26. woodiewagon46
    woodiewagon46
    from New York
    I understand your wanting a new tank, but the reason I repaired my tank is that after looking at about 6 or 8 tanks at Hershey all had interior rust issues. I had an inspection mirror and flashlight and all were ****, some you could actually hear stuff rolling around inside. I know what I have now.
  27. 51504bat
    51504bat
    No longer have a Model A but never was a fan of the gas tank up front in my lap and having to always make sure the gas valve was shot off when it was parked. It's your car, your decision.
  28. john worden
    john worden
    from iowa
    After this pour in a mix of whatever liquid you choose including a hand full of deck screws then shake, shake,shake.
    Repeat if necessary.
    After emptying and drying inspect for pin holes. Weld holes closed or replace.
  29. clem
    clem
    Before any cutting and welding, please research the correct procedures in relation to welding on used gas tanks.
  30. woodiewagon46
    woodiewagon46
    from New York
    This is the repair of the tank in my '29 that second shot is a handful of about a gallon of **** that I scooped out. I know it's a lot of work but there aren't too many good '29 tanks out there. After I TIG welded it and coated it it perfectly clean and worry free.
