Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. tfeverfred
    tfeverfred
    I'm still around, Rich. I spent the last 2 months in the hospital. I'm fine now. If you need the details, send me a PM.
    kidcampbell71, brEad, t-rod and 3 others like this.
  2. Dick Stevens
    Dick Stevens
    Glad to hear you are doing better and hope that continues, we certainly don't need the details, but I am curious and I'm sure others are as well!
  3. tfeverfred
    tfeverfred
    Thanks. But I don't want to hi-jack Blues build thread. So...
    Blue One and Dick Stevens like this.
  4. bobbytnm
    bobbytnm
    Awesome stuff!
    Its amazing how many hot rod parts can be found in out of the way places; hardware store, house wares aisles, pet supplies, farm & ranch stores, etc.
    Bobby
    loudbang, brad2v, Stogy and 1 other person like this.
  5. Six Ball
    Six Ball
    from Nevada
    The design here just gets better. Now not only will he have a great fan shroud but he will be able to bake cookies as he drives.
    brEad, loudbang, Stogy and 1 other person like this.
  6. Blue One
    Blue One
    from Alberta
    As it turns out due to space limitations I was only able to utilize a very small amount of material from those pretty cookie sheets.
    About a 1/2” or so in depth of the formed corners that along with the extra space I gained with the bent tie rod allowed the shroud to be spaced that small amount back from the radiator core and allow the needed air flow.
    The cookie sheets were about $7 each on sale and as nice as they are they were very challenging to weld with super low amperage Tig due to being thinner than I would have liked.
    In the end it will pay off.
    :D As long as they’re the best cookies (Peanut ****er ) I’m in :cool::D
    loudbang and Stogy like this.
  7. Blue One
    Blue One
    from Alberta
    So here it is all no stick coated and wavy from welding and bolted in place.
    3DE7137A-0011-4297-8C6A-28B567D11B16.jpeg 3CFFCD9B-D39C-4D8B-AE81-787D568DF2F2.jpeg
    After that I spent the better part of today blasting it and then metal working it with my shrinking disc and getting it nicely smoothed out so that I can drop it off tomorrow at the powder coating shop.
    RICH B, Tim_with_a_T, brEad and 12 others like this.
  8. brad2v
    brad2v
    Nice job Larry. As expected at this point :D
    brEad, t-rod, loudbang and 1 other person like this.
  9. bobbytnm
    bobbytnm
    I take it that is some sort of nut-sert on the flange where the two halves split? Good thinking
    Bobby
    loudbang and Blue One like this.
  10. 57 Fargo
    57 Fargo
    As always it looks fantastic! Nice job!
  11. Six Ball
    Six Ball
    from Nevada
    Very nice!
  12. The 39 guy
    The 39 guy
    Great design and excellent execution as usual Blue One
  13. Stogy
    Stogy
    Holy Betty Crockers got no Cookie Pans Batman...Stellar Wind Collector...@Blue One
    That steering link looks pretty awesome too...;)
    brEad, loudbang and Blue One like this.
  14. Blue One
    Blue One
    from Alberta
    Thanks guys.
    Yes it’s a rivnut threaded insert. I’ve got them all over the car in all different sizes from 10-32” to 3/8”.
    The best ones are splined so they really bite well when you install them.
    The shroud mounts to the rad with 4 - 5/16” bolts into brackets with rivnuts I welded to the rad and the middle ones are 1/4”.
    I built the shroud in 2 pieces so it would be really easy to install and remove. :cool:
    That after experiencing the need to remove the radiator (or get out the cutting tools, which I ended up doing) to be able to remove the first shroud/electric fan mount :eek::oops:
    Stogy, brad2v, OFT and 4 others like this.
  15. bobbytnm
    bobbytnm
    Excellent, thanks for the info.
    That really makes for a clean, serviceable installation.
    Bobby
    Blue One, loudbang and Stogy like this.
  16. t-rod
    t-rod
    Two months? Ha! Seriously, I hope things are better for you. I must have missed the details, I was a little preoccupied myself.
    Bad decisions make good stories.
  17. RodStRace
    RodStRace
    Sorry to hear of health issues, Fred. Hope that didn't drain the rod fund too. I am really hoping you are able to get yours moving along soon.
    Blue One, with the quality of workmanship in the rest of the build, the fan shroud is again up to the level of "Yep, great job!"
    Are you planning on an overflow tank (gasp, modern) for this? I could see a mount incorporated on the shroud. I know, more work suggestions from the peanut gallery, but better to mention now than after powder coat.
    Or even a custom shaped one that blends in? Example for shape only...
    https://puredieselpower.com/chevy-g...p-fabricated-coolant-overflow-tank-74610.html
    brEad and loudbang like this.
  18. Blue One
    Blue One
    from Alberta
    Thanks, yes an overflow tank is on the radar, probably mount one vertically on the p***enger side of the shroud probably using the shroud mounting bolts to hold it.
    I kind of like the round finned one that OTB makes as it kinda matches my other finned aluminum engine stuff.
  19. Six Ball
    Six Ball
    from Nevada
    I wish I had known in the '60s that these and other speciality fasteners were available. I would still own a '51 Ford woody, one of the straightest ones I've ever seen with the exception of a few easily replaced wooden pieces. We've learned a lot about sourcing hardware from this build. Thanks!
    loudbang, 26 T Ford RPU and Blue One like this.
  20. Blue One
    Blue One
    from Alberta
    Well the change over is complete. No more electric fan.:cool:
    The shroud is back from the powder coating shop and installed.
    502F40C3-37AF-4136-A269-09521890F803.jpeg D497B8C9-22D8-46A1-B257-F56631F6D9DF.jpeg 4A4CEEE7-6F51-4635-9B91-83BAD84AADBB.jpeg
    tomkelly88, AndersF, Stogy and 14 others like this.
  21. t-rod
    t-rod
    Looks fantastic!
  22. Stogy
    Stogy
    :rolleyes:...Spiffy...;)
    Blue One and loudbang like this.
  23. Blue One
    Blue One
    from Alberta
    Now I’ve gone and started something :eek::D
    I made the mounts for the electrical fuse panel and I’ll take it this week and get it the same color as the back of the dash.
    In the meantime I’ll work on the gauge harness.
    Stogy, loudbang, RodStRace and 5 others like this.
  24. Dick Stevens
    Dick Stevens
    Looks really good Larry, you're going to get this going yet!
  25. Mr. Mac
    Mr. Mac
    Quality work there Blue, I like it a lot.
  26. Blue One
    Blue One
    from Alberta
    My manual choke cable will go through the electrical panel and the firewall and I needed to make a bracket to hold the business end of it.
    So I took some stainless and fabricated the bracket that mounts to the rear carb.
    It might look flat in the pictures but it actually has 2 bends that raise the cable clamp about 3/8” higher than where it bolts to the carb.
    Then I polished it up.
    I made a larger rubber grommet with a small hole for the cable and installed it in the firewall. :cool:
    3AECAD0F-2209-42BC-BEC9-9EDA7867A543.jpeg 308E997C-90FF-4806-957E-81891EAA495F.jpeg 9A8EE059-88E3-4B72-81AF-764FF6A6E14D.jpeg
    Stogy, loudbang, RodStRace and 9 others like this.
  27. 26 T Ford RPU
    26 T Ford RPU
    Looks factory!!:D JW
  28. bobbytnm
    bobbytnm
    Ah, the sign of a great customized part...
    ...no one will ever notice it
    Nicely done
    Bobby
  29. Blue One
    Blue One
    from Alberta
    The panel has been powder coated in the same Wimbledon white as the back of the dash and I installed it along with the mega fuse and the Rebel fuse panel.
    Then I put the grommet in the firewall and ran all the wires out through it for the engine and all the lights.
    A9FB52C1-4D80-49E9-B869-B59F6A212971.jpeg A2C0678F-FE9E-4E90-85A3-85161EDEEC2B.jpeg
    razoo lew, The 39 guy, brEad and 8 others like this.
  30. Tim
    Tim
    from KCMO
    Progress! :D
    491E56DF-00B2-4F23-B4CE-DAFEB2DC3067.jpeg Out of curiosity what is this? Fuel filter?
