Hot Rods Show & tell. lets see your interior door & window handles
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Feb 18, 2019.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I've seen hundreds of early Ford interiors and it seems the most widely used window & door handles are the beefier Ford handles, I have the 40 Ford handles on my Deuce but I have seen them used on the Model A's on up.
    I know the original '32 handles are small and almost delicate compared to the beefier Ford handles, did this start shortly after the first '40 ended up in the junk yard? was it a trend that started after someones car was featured in a magazine? HRP
  2. A little-known swap for the early square-shank Ford handles is the '55-59 Mopar handles if you want something different. The only catch is you need the hard-to-find specialty tool for those to remove them as they use a spring catch to retain them.
    HOTRODPRIMER likes this.
  3. alchemy
    alchemy
    I used '49 Ford handles on this one. A little beefier than 30's handles, and a cl***ic look. Make sure you don't get 50's because they went to splines then.
    HOTRODPRIMER and chop job like this.
  4. 3W JOHN
    3W JOHN
    The ones in my coupe look like yours.
  5. HOTRODPRIMER
    HOTRODPRIMER
    The '50 Ford coupe window cranks & and door handles would look good on other cars. HRP
  6. alchemy
    alchemy
    They look exactly like the 49’s in my sedan. Except 50’s have a splined shaft.
  7. mgtstumpy
    mgtstumpy
    They are yet to be installed in my 46 Olds however I had them rechromed and also new ivory ****ons reproduced as they've not available. Repop Chevy ones would fit but are not the OEM colour. I drilled the rear flange of the winder and used machine thread ****on heads to attach them to handle, just like new :D
    I also added power windows and adapted the OEM splined shaft (Tapered tip) to the aftermarket switch (Flat tip shaft)
    HOTRODPRIMER and Shadow Creek like this.
  8. BamaMav
    BamaMav
    from Berry, AL
    Mine has never had window or door handles. Factory power windows and push ****ons to open the doors with....
    It's a Lincoln thing....
  9. moparjimd60
    moparjimd60
    Hard to see, but I built the door mechanism, and built the door handles out of 7/16 wrenches. $35.00 total works like a charm.
  10. low budget
    low budget
    from Central Ky
    Always better to use a wrench when possible versus the more common short cut:D...:(
