Technical UPDATE.......Squeezing a bit more out of my 283
Discussion in 'The Hokey Ass Message Board' started by Hdonlybob, Feb 27, 2019.
  1. Hdonlybob
    Hdonlybob
    Hey experts...
    Still trying to squeeze a bit more out of my 283..it is bored .060 over and a lot more....won't boar you with details..
    Do have a question though..
    It has 305 heads on it, and wanting to figure out the compression on it.
    Any way to do this ??
    Also what is the difference between a Melling C 400 P and the earlier L79 cams.
    Thanks much.
  2. Mike VV
    Mike VV
    from SoCal
    Google is your friend..!
    MANY sites that will explain your task in full and give you the ratio math to go with it.
    Mike
  3. bobss396
    bobss396
    Run the numbers on the 305 heads, they are around 76 to 82 cc, not exactly performance heads. Just looked up the 882 castings, 76 cc combustion chamber with a 1.94/1.50 valve set. You need to plug and chug what pistons, stroke, etc into a basic formula to have it puke out a compression ratio.
  4. sdluck
    sdluck
    L 79 cams are not all ground the same
  5. 6sally6
    6sally6
    Spring for a custom ground cam. NOT expensive at all and you get to tell the guy what you have and what you want.
    I like Delta Cams in Tacoma Wash. 1(800) 562-5500 ask for Ken.
    Good quality....good price....grind A LOT of stuff for the NW guys.
    6sally6
    Atwater Mike likes this.
  6. There is a formula online to do this
    Will have to know bore size, CCs of any dish, dome or valve reliefs, head gasket thickness and head combustion chamber CCs
  7. 34Phil
    34Phil
    58 cc heads
    Johnny Gee and lumpy 63 like this.
  8. saltflats
    saltflats
    from Missouri
    Didn't they make more than one 305 head?
    31hotrodguy, Johnny Gee and lumpy 63 like this.
  9. 34Phil
    34Phil
    They made millions. 58cc
  10. ricko1966
    ricko1966
    Will have to know bore size, CCs of any dish, dome or valve reliefs, head gasket thickness and head combustion chamber CCs { Anthony Myrick }
    and you'll need to know how far down the hole your pistons park
    The math is simple pi x radius squared x stroke is cylinder volume swept volume =A
    pi x radius squared x head gasket thickness and piston depth gives you that volume =B
    relief volume or dome volume and combustion chamber volume you will have to determine =C
    A+B+C divided by B+C
    anthony myrick likes this.
  11. Hdonlybob
    Hdonlybob
    I have spent a lot of time trying to figure this out on Google..so far I can not....the reason I asked for help.
  12. Hdonlybob
    Hdonlybob
    I did not put this motor together, so not sure about all the details.
    I know from the build receipts that it has a Melling C400P cam and 305 heads.
    I checked the head numbers and they are the lesser desirable heads, but do not know if anything was done to them..
    It is a standard stroke, flat top pistons and bored .060 over.
    Has Edelbrock duel plane with a 500cc Edelbrock carb
    I am very pleased with the performance of this little screamer, but as all here should understand...just looking for a little more..
  13. saltflats
    saltflats
    from Missouri
    Had that one coming. :rolleyes:
    raven and loudbang like this.
  14. Hdonlybob likes this.
  15. Hdonlybob
    Hdonlybob
  16. MAD 034
    MAD 034
    from Washington
    Steel shim head gaskets?
  17. 56sedandelivery
    56sedandelivery
    Actually, 305 heads tend to have very small combustion chambers; the most popular are the #601 with 53 cc chambers, and the #416 with 58 cc chambers. Both could be had with 1.84 intake valves. The 350 heads are another story, and I'd stay away from them with a "little 283". From that standpoint, I think he's headed in the right direction. He should however, contact a cam manufacturer that he likes/trusts, give them ALL his specifics on the car, and see what they have to say. Even with everything we know so far, rear end gear ratio will probably make the biggest difference in the seat-of-the-pants-feel. I know his Saginaw 4 speed is one of the lower first gear units (3.11 or 3.50:1). However, there's only so much you can do with ANY engine, and as they say, nothing is a subs***ute for cubic inches.
    I am Butch/56sedandelivery.
    31hotrodguy and Asphalt Angel like this.
  18. sdluck
    sdluck
    I don't believe the 350 heads with 2:02 will clear the edge of the cylinder walls.It is hard to figure out what is in your motor when you don't know,Fel pro heads gaskets are .039,oem are steel shim are the piston rebuilder which are down in the deck.L79 from chevy is different from crane or comp. Cams have changed alot since those were made.Roller cam would make a big difference.
  19. sdluck
    sdluck
    Engine vacuum would help.
  20. 6sally6
    6sally6
    Somebody please post..."just what the heck is this engine in?!!!"
    A small Nova or a big Impala?.....Long bed pick up or a T-bucket?
    Weight of vehicle plays a MAJOR part in the selection.
    Is this a 3 speed....4 speed...5 speed...powerglide...turbo 350...turbo 400...??? See what I mean?!
    2.50:1 gear??.........3.55:1.......4.11:1??????
    Why do fellas post questions and then its like pulling-hens-teeth to get basic info from them!!
    Grrrrrr
    6sally6
    Hnstray likes this.
  21. sdluck
    sdluck
  22. Mr48chev
    Find some 1960 / 61 Hot Rod, Car craft or other rod mags with tech articles as there were a **** ton of articles on how to hop up 283 V8 engines, it damned well isn't a new thing.
    Hnstray likes this.
  23. Hdonlybob
    Hdonlybob
    Hey now, don't be getting your undies in a bundle...my post was asking two simple questions...Look at it again :)
    Now, as we have wondered away so far, Here is "What and Where"
    This is in a 1963 Biscayne..see my avitar.
    Saginaw 4 speed with 3.11 first gear
    3.73 rear end
    (1965) 283 bored .060 over
    305 heads...don't remember the numbers, but not the two HO ones (also don't know what may have been done to them, if anything)
    Melling C400P cam
    Electronic distributor
    Timing at 14 degrees advance
    Edelbrock dual plane intake
    Edelbrock 500cc carb
    '63 Corvette dual snorkel air cleaner
    Vacuum at idle is (15)
    Corvette 2 1/2 ram horn exhaust
    Full 2 1/2" exhaust
    Cam comes on strong at ~3000 rpm thru ~4700 rpm
    Runs at about 3000 rpm at 60 mph
    Also remember my post ***le...want to squeeze a bit more out of it..
    NOT major rebuilding or replacements.
    Cheers.....
    clem likes this.
  24. bowie
    bowie
    A Holley mechanical secondary 600 cfm double pumper might give you a little more kick.Also possibly a ‘67 open element style Vett 350hp air cleaner.
  25. Heavy Old Steel
    Heavy Old Steel
    bolt-on's then ?
    ratio rockers?
    MSD box ?
  26. badvolvo
    badvolvo
    Sounds like you need a tuner or get it to the strip and start testing and tuning yourself. Looks like that cam should pull way past 4700 in a lil 283, got valve springs to match? What's the total timing? Any local shop with a ch***is dyno?
    bchctybob likes this.
  27. sdluck
    sdluck
    My buddy has the same cam in a 383 and it runs past 6500.What kind of fuel pressure,once again it is hard to figure out when you don't know whats in the motor
  28. sdluck
    sdluck
    Find a ch***is dyno
  29. sdluck
    sdluck
    What is the cranking compression
  30. ididntdoit1960
    ididntdoit1960
    from Western MA
    What does your timing look like? Initial? Total? that may be a place to pick up "free" power......other than that - compression - have the heads cut and get 283 bore specific head gaskets from SCE - you likely have flat tops and are lucky if your at 9:1 - the small bore 283 with flat tops can take a ton of compression and timing on pump gas - while upping the compression will be labor intensive, its cheap too.....
