Technical Olds 350 engine extra oil pressure connection
Discussion in 'Traditional Hot Rods' started by senginc, Feb 27, 2019.
  1. senginc
    senginc
    from B'ham, AL
    Getting the 69 Olds 350 engine ready for my 41 Olds.
    I would like to put the oil pressure switch at the stock front location and find a place on the rear for the 41 mechanical gauge connection
    Has anyone tried drilling and tapping the oil filter housing for an oil pressure connection ? 41 with Original Torque Thrust wheels (1).jpg
    catdad49 likes this.
  2. badvolvo
    badvolvo
    I've used a tee fitting before, so they are located at the same outlet.
  3. ol-nobull
    ol-nobull
    Hi. Nice looking ride. Drilling could be risky as you could tap into about anything. Why not use the front location and screw a br*** T into the block and run both from same location.
    Good luck, Jimmie
  4. senginc
    senginc
    from B'ham, AL
    I prefer not to run copper tubing all the way to the front of the engine. The 394 I pulled out had the oil pressure port on the oil filter adapter tucked away on right rear bottom.
  5. footbrake
    footbrake
    The front may be your only choice to be safe.
  6. oldolds
    oldolds
    You could check with Mondello.com for other places to hook up your gauge.
  7. footbrake
    footbrake
    Yes, Mondello is the place to go
