Technical Original 32 3 window fix !
Discussion in 'Traditional Hot Rods' started by Flop, Nov 18, 2017.
  1. Flop
    Flop
    Thanks guys
    Patch welded up .
    Also stepped the quarter on the rocker like ford did instead of just lapping it
    Quarter was cracked
    Getting the door gapped
    Getting there
    Tighten up a little more and the gapping is gonna be done
    Als27T, ls1yj, Stogy and 14 others like this.
  2. Flop
    Flop
    Als27T, Stogy, Nailhead A-V8 and 11 others like this.
  3. Flop
    Flop
    Luckily a nice original to copy from
    Before all the tweaking
    Pretty happy now
    Uhhhohhh
  4. Happydaze
    Happydaze
    One step forward, and two........... :).
    All great stuff:) Vicariously learning.
    Chris
  5. patsurf
    patsurf
    so do you prefer to **** 2 pieces rather than work off of the old spot weld areas?-thank you,pat
  6. Flop
    Flop
    If you are talking about where I cut the back panel out no way . I would rather spot weld the panel in like stock then have 3 feet of weld with no access to hammer it.
    ls1yj, loudbang and warhorseracing like this.
  7. patsurf
    patsurf
    ok-so final cut later?-sneak up on it...thanks!
    loudbang and Flop like this.
  8. Flop
    Flop
    Rust encapsulator while it’s all apart
    Brookville panel fits real nice
    mgtstumpy, ls1yj, dlw1932 and 7 others like this.
  9. Flop
    Flop
    Welded but some rust showed it’s facewhere the panels are doubled
    Same over here thin rusty and mig welds all over
    [​IMG] inner was cracked
    Only so much you can do with the double panels
    Got the damage out time for a new lower edge
    mgtstumpy, ls1yj, dlw1932 and 5 others like this.
  10. pumpman
    pumpman
    Flop, is that threaded for lifting or to apply pressure on the bottom piece?
    loudbang and Stogy like this.
  11. James D
    James D
    Great work...I´m amazed.
  12. Flop
    Flop
    Sets your body to gas tank gap .
  13. pumpman
    pumpman
    Thanks Flop.
  14. James D
    James D
    Do you have any guesses as to the history of this car, based on the amount of damage on the body? Think it was an old dirt track car or something?
  15. Flop
    Flop
    I don’t think because the doors matched the paint on everything else and the doors were really nice . Also gonna guess they would have ditched some wood .
    loudbang and James D like this.
  16. rockable
    rockable
    Amazing work, Flop! I'm always impressed.
    Flop likes this.
  17. Flop
    Flop
    mgtstumpy, Stogy, ls1yj and 8 others like this.
  18. big duece
    big duece
    from kansas
    Maybe you have stated this earlier in the thread, but don't recall; are you finally building a 3w for yourself? Or is this for a customer?
  19. oldbanger71
    oldbanger71
    allways impressive how you work, thanks for sharing .
    Flop and loudbang like this.
  20. Flop
    Flop
    Making gaps a tad nicer
    Riveted stippled braces in for the rumble seat hungers
    Als27T, ls1yj, mgtstumpy and 8 others like this.
  21. Flop
    Flop
    Old thin welds
    And when we decided the cowl side needed replaced
    Als27T, mgtstumpy, loudbang and 4 others like this.
  22. Flop
    Flop
    Thankfully docs car is here as a great template !!
    On the bad panel . You can see the wrinkles where it is bad
    Template on the newly shaped panel ... no wrinkles
  23. Rustygt
    Rustygt
    from Emeryville
    Flop whats the purpose of the bolt on the cowl
    Stogy and loudbang like this.
  24. Flop
    Flop
    Used it on both side to pull the cowl down because the feet on the inside of the cowl were missing .
    mgtstumpy, Stogy and loudbang like this.
  25. Flop
    Flop
    mgtstumpy, Stogy, loudbang and 4 others like this.
  26. Flop
    Flop
    Als27T, mgtstumpy, Stogy and 6 others like this.
  27. pumpman
    pumpman
    Dang Flop, is there anything on it that you haven't touched?
  28. Flop
    Flop
  29. Flop
    Flop
    Closing in on it
    Now to put a step in the rocker and work the cowl into the rocker .
