Projects The bucket of ugly! A de-uglifying thread...
Discussion in 'The Hokey Ass Message Board' started by need louvers ?, Aug 14, 2013.
  1. tfeverfred
    tfeverfred
    I ran into that with my first T. I had to mount the column 1" to the right. You could barely notice it. I mocked up a steering column and steering wheel and it appears I'll be okay this time around.
    chryslerfan55, dana barlow and GuyW like this.
  2. Blue One
    Blue One
    from Alberta
    I could de ugly that abortion easily :D
  3. 26 T Ford RPU
    26 T Ford RPU
    Great to have you back, Fred, and looking forward to you progress. :cool::D JW
    loudbang, Blue One and tfeverfred like this.
  4. tfeverfred
    tfeverfred
    Thanks. Hang on tight.... things are going to start popping.;)
  5. Blue One
    Blue One
    from Alberta
    Hey Fred for curiosity I contacted Bous and asked them the source (manufacturer) of that steering box and they told me they get them from Speedway Motors.
    I looked it up and Speedway sells their own box which you have and also the flaming river one.
    Hope the Speedway one works good for you.
  6. tfeverfred
    tfeverfred
    I think I'll be okay. I've had great service from Speedway. Oh... my engine should be ready in a couple weeks, so I ordered my headers and turnouts. Also ordered my tail lights from SoCal. '37 Ford.
  7. Blue One
    Blue One
    from Alberta
    On the tail lights, I started out with the led versions of those lights and was less than impressed with the quality and appearance of the light they produced.
    So I did a little searching and ordered a pair of proper gl*** lenses and sockets for incandescent bulbs for them and then painted the inside of the housings bright white.
    That along with Silverstar 1157 bulbs works great.
  8. tfeverfred
    tfeverfred
    Thanks, Blue! Do you have a name or link to the company?
  9. Blue One
    Blue One
    from Alberta
    Hey Fred, I used Macs. Some guys have said they are terrible, but I had no problem, I ordered a pair of lights and had them in no time at all.
    I just ordered the complete light ***embly and then swapped the lenses and bulb sockets into my painted housings.
    So, now I have a pair of Led equipped lights for swap meet material.
    The tail lights from Macs are pretty nice quality, I ordered 2 without the licence plate light, they are also available with the plate lens.
    https://www.macsautoparts.com/ford_...ens-black-body-6-and-12-volt-bulbs-right.html
    chryslerfan55, GuyW, loudbang and 4 others like this.
  10. J. A. Miller
    J. A. Miller
    from Central NY
    ^^^^^ Ok, turn the shop lights back on and finish putting that thing together.
  11. tfeverfred
    tfeverfred
    Well, my lights from SoCal are already coming. I'll check them out once installed and if there's a problem with brightness, I'll think of something. Today, I ordered my steering column drop and firewall column mount. Things are moving along nicely!
  12. Blue One
    Blue One
    from Alberta
    Gl*** lenses are available for about $11 each.
    And you’ll find that if you want to remove the led ***embly then all you have to do is straighten up the bulb socket and plug in the 1157 bulbs.
    https://www.vintageautogarage.com/1937-Ford-Gl***-Tail-Light-Lens-Red-p/f3703.htm
    chryslerfan55 and tfeverfred like this.
  13. tfeverfred
    tfeverfred
  14. tfeverfred
    tfeverfred
    Well.... my tail lights showed up today. They look good and are bigger than I thought. Only one small problem. They didn't come with any hardware. But a quick trip to the hardware store took care of that. My original plan was to attach the lights to the rear of the frame, but the upper rear shock mount is in the way. But since my tail section is shorter than most T frames, I was going to make an extending bracket to support the gas tank. So, they'll attach to that. All in all... I'm satisfied.
  15. Blue One
    Blue One
    from Alberta
    I bought the mounting brackets that So cal sells for them Fred, they’re nice in that the wires are run through them.
  16. 26 T Ford RPU
    26 T Ford RPU
    One of the nicest tail lights that graced the rear of a Ford.:cool: JW
  17. tfeverfred
    tfeverfred
    That's what I bought. Two lights and two stands. I was still surprised no hardware was included to attach the light to the stands or the stands to the car.
    chryslerfan55 and Blue One like this.
  18. Blue One
    Blue One
    from Alberta
    Right on Fred
    I’m with you on the hardware thing.
    I also had to get my hands on the 2 different sizes of bolts required.
    I used stainless ****on heads and just polished them up.
    The lights and stands truely are a thing of beauty :cool:
  19. tfeverfred
    tfeverfred
  20. tfeverfred
    tfeverfred
    The CCR firewall mount for the steering column came today along with the column drop. Both are good pieces. The column mount is powder coated. Here's a pic from CCR's website.
  21. Blue One
    Blue One
    from Alberta
    It’s such fun getting parts for the project.
    Gotta love it. :cool:
  22. RICH B
    RICH B
    Neat. Opening parts boxes is always fun. What column are you planning for?
  23. tfeverfred
    tfeverfred
    Plain Speedway 28".
    RICH B and chryslerfan55 like this.
  24. RodStRace
    RodStRace
    How is the engine/trans coming?
    You mentioned it was about ready before you got sick...
  25. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Hey Fred- Just going through the motions with the "vair box on the frame rail...... Pics speak for themselves, and encounters you might find...... Frame rail to box....plus+ angles, pitch, space, etc......
  26. tfeverfred
    tfeverfred
    I checked my setup and it looks like I'll be fine. Plenty of room for the steering wheel without having to move the column or box over.
  27. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Idea's of how to get the box mounted to the frame? , and pitman arm angle in relation to the drag link?
    Just wanna know how your going about it is all......Something's gotta give somewhere....
    I'l be waiting to see the results!:) Carry On!
  28. tfeverfred
    tfeverfred
    Well, my brackets came from California Custom Roadster and I installed them according to their plans. They've been building T Buckets for about 50 years. So, I think if there was an issue, they'd have it worked out by now. As for pitman arm angle, it's actually close to the angle on my last T Bucket, which I drove the **** out of with no issues... EVER. So, I'm confident things will be fine.
    Thanks for your concern.
  29. Hackerbilt
    Hackerbilt
    Not sure what you mean.
    Are you concerned the drag link isn't parallel with the wishbone?
    A split wishbone is a 2 link suspension that pivots like a clock hand around a single point per side.
    The pitman arm tierod end needs to be as close to that same pivot point as possible and the arm can sweep up compared to the wishbone because its still basicly pivoting around the same single point.
    If he were running a 4 link system, where the suspension has two frame pivot points per side and works like a parallelogram, the tierod must be parallel to those arms.
    To do it any other way will result in bumpsteer. (If the cars suspension has any real amount of movement.)
    It's common for people to get the two polar opposite needs confused...and then the arguments start! LoL
    chryslerfan55, brEad and tfeverfred like this.
  30. tfeverfred
    tfeverfred
    Steering column and mounts. Might be getting a new camera soon.
