Technical Degreasing cooked on engine oil
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Mar 2, 2019.
  1. Roothawg
    Roothawg
    I have a bucket of 390 Caddy parts I need to clean.
    I am looking for something I can submerge them in that will start the process. This motor must have never had an oil change.
    The inside of the oil pan, valve covers and timing cover is a 1/2” thick and black as coal. It’s cooked on as well.
    I know about the mol***es truck for rusty parts. Anything like that for coked up engine oil? Preferably something that won’t eat steel.
    I will probably end up doing the old easy off oven cleaner trick, but the local car wash guy doesn’t approve and it’s supposed to be like 8 degrees this week... woohoo
  2. D Picasso
    D Picasso
    Only thing better than oven cleaner is more oven cleaner, it seems. No-Name-O spray-lye for a dollar a can ends up being a decent value.
    I've tackled some really heinous torched-on snot with a knotted-wire cup wheel in an angle grinder.
  3. Beanscoot
    Beanscoot
    The lye aka oven cleaner aka caustic soda's effectiveness is proportional to temperature, i.e. it will be pretty poor in freezing temperatures.
    I have had excellent success with engine blocks by filling the water jackets with hot water (from a hose attached to the bottom of my hot water tank) then spraying on the oven cleaner followed with a scrub brush and the hot water rinse.
    Needless to say, the bits of lye that are flicked onto your skin while brushing will cause discomfort.
    Another technique I have found very effective for really oily and dirty parts, and "coffee grounds" type deposits is to immerse the parts in a pail of gasoline covered up with thick poly to cut down evaporation. I take them out after a few days, without any brushing or attempt to clean. I simply let the gasoline run off as well as I can and don't try to dislodge the dirt, then let the pieces dry in the sun for a day or two.
    This treatment is quite effective to extract the oils, so when the part dries, the dirt left behind is dry and chalky and easily washes off with soap and water.
    It also does not transfer too much of the dirt into the gasoline, which is beneficial because I let it settle, then decant the clear fuel and use it in my beater truck.
  4. squirrel
    Build a hot tank?
    alanp561 and egads like this.
  5. Chicken grease. Eating fried chicken always cleaned my hands off.....black when I start, clean after........where does it go?
    :D
  6. Beanscoot
    Beanscoot
    I have thought about building a hot tank by cutting a hot water tank in two. They even come with heater elements.
    It would be a nasty thing to have in your backyard, though.
  7. rusty valley
    rusty valley
    elbow grease
    harpo1313 likes this.
  8. deathrowdave
    deathrowdave
    from NKy
    When working we had a huge oven for burning insulation off electric cable so you could sell clean copper for top dollar . That oven would produce a new looking piece of cast iron from the rattiest look hunk of toilet trash you have ever seen in 2 hours . Oven cleaner is your friend on a warm block . Don’t do the brake clean then try heating it and breathing the fumes . It maybe your last experience with brake clean . Nasty stuff when heated .
    belair and egads like this.
  9. Boneyard51
    Boneyard51
    Here in Muskogee they used to sell “ Dynamic 100”. But they quit making it , then they replaced it with “ Camando Clean”. I use to keep a cut down barrel of this stuff, diluted with water. I would put the most greasy, caked up parts, soak them in it, at room temperature, for a couple of days, rinse them off with with the water hose and it would be ready to paint. Might try to find some of that stuff, if they still make it.
    Bones
  10. Roothawg
    Roothawg
    Who sells it? I have never heard of it. I heard Tractor Supply had some good stuff, but not cheap.
    I was wondering about an old electric oven? Maybe cook it at say 250 for a couple of hours?
    Boneyard51 likes this.
  11. squirrel
    a quick google for places that sell these ovens for machine shops seems to indicate 700-800 degrees is more like what you need...???? think in terms of the self-cleaning mode of a household oven
  12. VANDENPLAS and partsdawg like this.
  13. oldiron 440
    oldiron 440
    Take them to your local machine shop and give them what they need to clean up the parts, it might be less that you think.
  14. deathrowdave
    deathrowdave
    from NKy
    Camando Clean , I was thinkin that was laundry detergent , for the few and proud the Marines !
    VANDENPLAS and Boneyard51 like this.
  15. Canuck
    Canuck
    Don't use oven cleaner on aluminum parts. If a part has paint on it that you want to keep, don't use it.
    Used it on a SP400 trans for about 15 min and you could see that it was starting to etch the metal, Also took all the paint off the rivited on serial number plate.
    Canuck
  16. Roothawg
    Roothawg
    I have been youtubing home made hot tanks. It looks doable. I will improve on their designs.
  17. BamaMav
    BamaMav
    from Berry, AL
    Buddy of mine bought one of those big AG tubs, I think they make round and oval ones. Used the heating element from a house water heater. Used Purple Power or something like that, put parts in tank and let sit with heat on. They come out looking nearly new. Said he was thinking about adding a aquarium pump or something like that for a bubbler to help clean even faster.
    Kan Kustom likes this.
  18. blowby
    blowby
    from Nicasio Ca
    ^^Was thinking something like this on the propane BBQ or a fire pit.
  19. squirrel
    I was mistaken about what you wrote, you were asking if you could use an oven to keep a hot tank at 250 degrees.
    I was thinking you were asking about using an oven to bake the **** off...which is how many machine shops do it today. They run those ovens at about 700-800, and a self cleaning oven runs that or a bit hotter. I wonder if it would be feasible to use a self cleaning oven to do a few parts? I would expect it would be an old oven, near the garage...not Mom's oven in the kitchen!
    alanp561, Truck64 and Kan Kustom like this.
  20. sunbeam
    sunbeam
    I use clean bright 209 in my hot tank from chemBrite works best at 180-200 degrees. Do not use on aluminum. If it is water soluble 200degrees max.
  21. fordrodsteven
    fordrodsteven
    AND.. you could also use the oven for powder coating!
  22. RMR&C
    RMR&C
    from NW Montana
    I have seen home made hot tanks made using a steel drum w/lid and a 115v engine block heater.
    Lye was used in them in the old days.
  23. jimmy six
    jimmy six
    Start with putty knives and gasket s****ers.
  24. 2OLD2FAST
    2OLD2FAST
    from illinois
    Years ago at the old Chev garage we had a bucket full of used transmission oil , couple days would clean up grease , carbon , most anything ...
    alanp561 likes this.
  25. 28dreyer
    28dreyer
    from Minnesota
    Recently had your exact same situation with a Ranger aircooled 6 cylinder in-line aircraft engine that hadn’t run since 1950. Full of sludge from non-detergent oils of the period like automotive engines of that period.
    There is no easy, quick solution (pun intended).
    1. S****e out any sludge/carbon.
    2. Pressure wash at your unfriendly car wash, wife’s dishwasher, or at any automotive engine or transmission shop. This will leave you with the cooked on black oil layer.
    3. Soda blast will easily remove it.
    I bought a HF Soda blaster pressure tank type and with a 20% discount was about $75. Need to get used to and overcome it’s idiosyncrasies but you can also find a commercial Soda Blaster locally in all probability.
    The soda blast will not harm magnesium, aluminum, and probably plastics and fibergl***. It removes paint but not rust without distorting sheet metal.
    A local production engine rebuilder uses a roll through (double opening) commercial dishwasher to clean his smaller parts rather than putting them in his large upright pressure wash cabinet.
    dan griffin and alanp561 like this.
  26. Boneyard51
    Boneyard51
    Let me check, to see if they still make it. My nephew used to work for the original company, his job was to mix large batches of that cleaner, he may remember the formula.
    Bones
  27. Before I learned machine shops had hot tanks, we used oven cleaner and a pressure washer. Usually followed by using a torch to finish the job.
  28. I have had had luck in the past soaking parts in Varsol for a few days.
    Then clean the part out with hot water.
  29. alanp561
    alanp561
    I thought Bones had misspelled the name of the cleaner so I looked up www.commandoclean.com and I'm pretty sure that's not the stuff he was talking about. It might get rid of sludge though.
  30. 59Tele
    59Tele
    Back in '66 when I was 16 and working as a dishwasher, the chef took his lunch break and I dragged in the block, head, oil pan, crank, pistons and rods for my first car ('61 Fiat 1100) and ran them through a couple of cycles in the dishwasher. Sparkling clean, they were. The bar gl***es that came after, not so much. "I dunno, Chef. Let me drain the water and try it again".
    alanp561 and Beanscoot like this.
