Hot Rods The 4 Banger hot rod picture thread.
Discussion in 'The Hokey Ass Message Board' started by Hitchhiker, Nov 3, 2015.
  1. Zundapp 57
    Zundapp 57
    Stipes cam,Yapp equilizer manifold and cast iron lion speed head.
  2. OHV DeLuxe
    OHV DeLuxe
    from Norway
  3. Sid E. Burns
    Sid E. Burns
    Hey, could anyone tell me what those "winged" hubcaps are called or from, and which rims they fit??
    They are really cool, but my googeling brought me no answers...
    chryslerfan55 and Dustyp489 like this.
  4. dmdeaton
    dmdeaton
    They come from a fellow Hamber. fourspd2quad
    He makes them along with some nice tail lite housings.
    They fit 16 inch wires
    chryslerfan55 and Sid E. Burns like this.
  5. Sid E. Burns
    Sid E. Burns
    Thank you!
    I'm new here, p***ing time browsing while i wait for an older guy to get back from his vacation. He owns a -29 Tudor, which he promised to have a decision on whether i get to buy or not when he returns.... Exciting... :)
  6. ROCKER77
    ROCKER77
  7. Austin kays
    Austin kays
  8. Austin kays
    Austin kays
    Tim likes this.
  9. ghalperin
    ghalperin
    Powered by Winfield
    C2C3762E-757A-4531-9557-25058277BD40.jpeg 7F561587-27FA-41B2-895C-AD1C4D30B315.jpeg
    1929 Model A Roadster
    Stock springs and ride height. 6 volt positive ground. Mechanical brakes. 1933 Diamond A block; B crank, Winfield SR B carb and matching intake, cast iron Winfield Yellow head, Winfield SU1R cam, B distributor, unknown 4 into 1 tube header. Windshield chopped 5 1/2” and laid back. Steering column dropped with 2 lower clamps inserted. Roof chopped 6” in the back. Seat lowered 6" and moved back 6”. 1935 Ford wire wheels. 6.00 & 7.50 Firestone’s. Guide 903J Headlights.
    Chopped and bent Model A headlight bar. Repurposed all vinyl and canvas from 1970's stock restoration. Rumble seat. Air Force surplus seatbelts. Model A brake cross shaft repurposed into a front spreader bar and license plate holder. Model A rear bumper bracket and cross bracket repurposed into a rear nerf bar. Surfboard racks, wrapped in 1/4” cotton cord.
  10. Jet96
    Jet96
    from WY
    A4107675-92FC-47E6-9E8D-E469DFB59C71.jpeg A more recent pic- alum. Winfield head, combustion chambers were wonky. Welded/shaped so gasket had something to seal against. About 8.5:1, runs strong but very sensitive to octane... Pete1 ground me a 1007b cam. I smoothed/enlarged oil pump inlet and outlet, turned down the shaft etc.. , light flywheel/v8 clutch. Harmonic damper from Murray down south. Drove it a bunch this summer. Has race pipe for HRHC in this photo, good for additional .76 hp...
  11. 36fred
    36fred
    E21DB79F-3CAC-4C67-AC0B-8F0A87146B08.jpeg E21DB79F-3CAC-4C67-AC0B-8F0A87146B08.jpeg B54A9073-3BED-4AED-A044-D35FCBC4D92E.jpeg 3EFC67E7-6E1D-463A-8FCC-F823D6437584.jpeg 779F0AB0-2D7D-4985-82E0-6FECA8556CD1.jpeg 3635E61F-00FC-4BA1-A23A-D782A9DE801B.jpeg As I’m starting to build my 32 five window, after many years setting, I’m wanting to keep this thread alive for ideas. Many great ones already from this thread. I have a couple B motors, Winfield head, lions speed head, and Winfield up and down draft carbs, plus Charlie yap exhaust, so deciding what to run and cam questions. Thanks guys for al the pics.
  12. Six Ball
    Six Ball
    from Nevada
    Sounds like a fun build with nice parts. Cool to have them being used.
  13. Jet96
    Jet96
    from WY
    18555BB0-B683-44E7-8F5D-ABD7F8DE7FE1.jpeg Stipe cam, Brierley head, using the Burns intake carb setup from my roadster for now. Runs really good. Had to change out the old honeycomb rad. Drive it about every day. Next step is Cling's adapter'39 trans. and Lower it slightly...
  14. Jet96
    Jet96
    from WY
  15. brjnelson
    brjnelson
    Here is a few from my collection
  16. Cody Clem
    Cody Clem
    hotrodfil, GuyW, Joe Blow and 6 others like this.
  18. LSJUNIPER
    LSJUNIPER
    from ct
    Out of curiosity, how much can you get out of these motors as far as HP once all the speed goodies are on? Is it expensive? Thinking of doing the same thing to mine...
  19. ghalperin
    ghalperin
    I’m guessing that I bumped mine up 50% to 60 HP, so totally worth it.
  20. 97
    97
    Stock ....half the number of cylinders as a flathead V8, almost the same cubes, less than half the horsepower . Hopped up, NOTHING beats a Model A across the intersection, and it's twice as hard to find the same horsepower and twice the price to get there. BUT a max effort Model A or B banger can deliver the goods in spades..
    Check this out
    Paul Gommi v8 vs Joe Rodriguez banger ,
    Roadster grudge race one blown flathead, one worked naturally aspirated Banger , two fastest in their cl***es on the day, who's the winner?
  21. 97
    97
    Six Ball asked
    Do you know what transmission he runs? There was some smooth shifting going on there.
    his post seems to have disappeared but.. here goes
    Joe is on HAMB 530 Sandman...... from one of his own posts in the monthly Banger thread, just before he ran at the 17 RPM Nats (video).
    "It's a Diamond B with a Cragar 4 port cross flow head, dual 97's, long tubed headers (Full oil pressure) and a 39 trans. an early 201/V8 Halibrand, Culver City Ca. QC rear end. closed/torque tube! (Too much to list!):cool:"
    Outback, Dannerr, GuyW and 1 other person like this.
  22. Six Ball
    Six Ball
    from Nevada
    97, thanks. I deleted that post almost as fast as I posted it after watching the video again. I turned up the sound and could hear his shifts better and could tell it wasn't a T5. I spotted the quick change on the line. Is the Diamond block the aftermarket one with 5 mains......? Whatever it is sweet! Joey needs to hear it. :D Also see it smoke a v8.
    Outback, GuyW, Jet96 and 1 other person like this.
  23. 97
    97
    Yeah I posted that video on Joey's thread and I had a bit of a brain fart and posted it a second time a few pages later :cool:.
    Joe Rodriguez @530sandman hasn't been seen on the HAMB for over a year now, he used to post regularly on the Banger thread, which by the way is not only for Ford bangers( nod nod wink wink! ) but I see going by his profile that he now lives in Northern California...... He was building a 34 coupe that is probably taking up his time I guess.
    Diamond block is a Ford replacement block built into the later 30s or early 40s , said to be stronger and thicker deck or something like that, never seen one in NZ...
    The 5 mains blocks are all aftermarket, until now I think only made by engine builders like HAL for themselves, Now Todd ****imore is making them, has just got a few test blocks out recently. Only other way I know is a girdle bolted to the bottom of the block with two ghost mains.
  24. Kiwi 4d
    Kiwi 4d
    A bit going on here, a diamond B block , Serr head milled some to raise compression to a useable level, with an original cragar cover. Willys jeep rear main seal, 440 Chrysler oil pressure relief and filter , full pressure oil system, chev 348 BB pistons, light flywheel , stipe timing gear, FS ignition , home made thermostat housing ,home made headers. Medium cam ground in NZ.Murray horn front damper.its no longer a rolling road block ,but at 90 your **** crack isn’t very big. All we aimed for was to cruise at 60 all day ,which is the limit here in NZ. E2325996-0486-41FF-8430-EF7FC56EA467.jpeg 92BDCDEB-614F-47BE-B81E-18D7CA1DECD2.jpeg
  25. Six Ball
    Six Ball
    from Nevada
  26. Kiwi 4d
    Kiwi 4d
    Grace and co air cleaners that we made slightly taller to fit a better k&n type filter. Ha , regarding the carbs we had 5 of the 81 strombergs to make 2 .After 2 days of being unable to get he AF ratio dialed in getting frustrated, we finally found one mischievous 81 body was porous. Dang it all , luckily I had a new pair of 97s on the shelf which made turn around time zero , so the paint is what stromberg use.
  27. 97
    97
    It's all looking good , does it live up to expectations, I know you and your engine man put max effort into the build. Which trans did you end up using?
    But it all looks far too flash for that modern truck, you better drop it off here, I will run it in for you in an old roadster get it patina-ed up for Wendy's truck.
  28. Kiwi 4d
    Kiwi 4d
    B4 trans with 39 gears . Had a 5 speed with the jeep TT conversion, but she who must be obeyed said nope to that idea. We do have a couple of 5 speeds in rods . I presume the same rule will apply if we get the T roadster we found with a seized motor, no upgrades.
    winduptoy, Outback and Six Ball like this.
  29. LSJUNIPER
    LSJUNIPER
    from ct
  30. Six Ball
    Six Ball
    from Nevada
    Yep, A great start for sure. Don't keep you progress a secret.
    "she who must be obeyed" there must be one in each hemisphere. :eek:
