Projects How would you fix this? King pin bore
Discussion in 'The Hokey Ass Message Board' started by Chris, Mar 6, 2019.
  1. Chris
    Chris
    i installed can original Ford axle I had dropped in my 56 F100. I am ****oning it all up, but ran into a snag. The truck had a fresh king pin job and the pins slid out of the original axle no problem, on the dropped axle, they will not go in the axle. I think maybe the heat from dropping warped them a smidge. I honed and used a rat tail file in the boss on one side, but man that’s taking forever.
    Has anyone ever ran into this problem? What did you do to fix it? The king pin is 7/8 of, was thinking of picking up a 7/8 drill bit and cleaning the holes up that way?
  2. nickleone
    nickleone
    find the correct size ream.
    nick
  3. Dick Stevens
    Dick Stevens
    NOT a drill bit, use the proper sized reamer!
  4. A rat tail file and/or a drill bit are not the sort of things that should be used on the front end of a hot rod..........maybe 60 yrs ago when the car could only be expected to get to 60mph with a tailwind you might have gotten away with it but..........not in 2019.........either get the proper sized ream and acquire the skills to do it your self or take it to the man..........andyd.
  5. Mr48chev
    I know you are "do it myself rather than farm it out" but Sids repairs those as one of the processes when they drop an axle. That and set the camber to specs.
    I doubt you can find someone who can set it up on a Sunnen Hone and hone it just because of the challange of keeping the axle straight with the hone when you hone it. Also I don't know of a similar portable hone off hand.
    gimpyshotrods likes this.
  6. Onemansjunk
    Onemansjunk
    from Modesto,CA
    I have a King Pin Press Kit somewhere that has reamers for this operation-Damn thing has not been used in 30 years——Now What happened to that DAMN screwdriver?
    kidcampbell71 and VANDENPLAS like this.
  7. Boneyard51
    Boneyard51
    Too small is an easy fix with the right reamer, as has been said. Be glad it’s not too big, that’s not so easy to fix.
    You might try heating them a little to see if the pin will then slide it. Now before I get jumped onto , I said a “ little “ bit. You want the pin to be tight in the axle, before you have to buy a reamer.
    Bones
  8. hotcargo
    hotcargo
    Adjustable reamer and sneak up on it...........
  9. mgtstumpy
    mgtstumpy
    What about the business that dropped it, can they rectify things since they did the original work. I would have thought that it'd be checked for quality control before it left the building?
  10. Take is to a local machine shop, they will have a reamer in stock and it will be light work for them to do.
    How small did the hole get? By lots or just a bit?
    An adjustable reamer can be bought and used by hand to get the hole round again, slow light p***es untill it all fits?
    alanp561 likes this.
  11. I think first you need to measure how much difference in the two. I think the king pin is .812. The adjustable reamer that you can sneak up on is a good plan.....
  12. blowby
    blowby
    from Nicasio Ca
    Did the hole shrink? Or is it undersized in one direction and oversize in another?
  13. oldtom69
    oldtom69
    from grandin nd
    you said the original axle had just had a king pin replacement?are you sure the pins aren't oversize from that job?
  14. Hot Rods Ta Hell
    Hot Rods Ta Hell
    ^^^Yep, mic your pins, then ream to your needed size. Same as you would before you bore a block-the machinist should have to components on hand Pistons, etc. prior to machining.
    Ream or hone is the only way to get this matched up so you don't have excess front end slop, which would make driving it a hand full.
    It does bring up the question of having an axle dropped. Is this typical of having an axle dropped or did too much heat get applied on this one? Does the guy dropping the axle typically check/take care of this or is the expectation that the customer has work to address once he gets the axle back in his shop?
  15. Corn Fed
    Corn Fed
    With as many old Fords that you build, you should buy an adjustable reamer to do spindle bushing jobs so you have it on hand. I got one (with the alignment attachment for two holes) from McMaster Carr 10-15 years that has more than paid for itself: https://www.mcmaster.com/adjustable-reamers
    Get one. It will be well worth the $150. I have done multiple spindle bushings as well as cleaned up a few axles bosses.
    porkshop likes this.
  16. alchemy
    alchemy
    My brother (see above) and I cleaned up the bores on a few axles this winter as we were ***embling a ch***is. I think they were slightly warped during the dropping process, like yours is. We used the same reamer he uses to ream the kingpin bushings, except we used a lot more oil. Didn't seem to harm the reamer blades. Every hot rodder (or their brother) should have a king pin reamer.
    Chris likes this.
  17. ramblin dan
    ramblin dan
    I bought a 1940 ford axle with the same issue. Someone had hammered the king pins out and mushroomed the hole in the axle. Filed the high spot and reamed it.
  18. Chris
    Chris
    Thanks guys! Sounds like I will invest in a reamer. Funny thing, I have done quite a few dropped axles, this is the first one I have ever had this problem. The pin starts but only goes maybe a 1/16th ways down the hole and stops. I tried tapping it, and it's just way too tight. Popped the pin out and two sides of the bore had drag marks. So I think it is ever so slightly egg shaped. I tried a rat tail file and a wheel cylinder hone, just to see if it would clean up. But didn't make much progress. So I stopped.
    For king pins, my dad has an engine building business and I usually use his Sunnen Hone to do king pin bushings. It's slow but works very well. I thought about taking the axle there and using it, but honestly you guys are right, I should have a reamer on hand.
    Also to clarify, I am not sure on the pins and if they are oversized. I have a dial indicator but it is not digital, so it works about as good as a tape :D Another tool I need to invest in. But again, usually these things go together pretty easily for me in the past.
    As far as the guy who dropped it, I am not slighting him at all. He may have checked it and it measured fine up top. Or maybe my pins are indeed oversized? Regardless, this is something I can fix, so no harm no foul
    Thanks for the help.
  19. Chris
    Chris
    I looked at McMaster Car, the bummer is, early Ford king pins are .812 diameter, and F-100's are .8595. The reamers for the early Ford size go up to .8438...meaning the reamer for the F-100 would not work for early Fords. It is what it is, but kind of a bummer to buy a reamer that may only be used once. If it fit early Fords, I may wear it out :D
    kidcampbell71 likes this.
  20. Dick Stevens
    Dick Stevens
    Look at the adjustable reamers, they may have one that will work for both!
  21. alchemy
    alchemy
    As the go-to-guy for old Effies in the Pacific NW I think you should own a reamer that fits them. Eventually you will own every single one of those trucks, and you can send them all down the road with fresh kingpins.
    slv63 and Xtrom like this.
  22. Chris
    Chris
    Unfortunately no, the two sizes I would like to have are for .812 and .8595 pins. The reamers are for:
    .7813-.8438
    .8438-.9375
    So, I would need two reamers.
  23. Chris
    Chris
    I am sure it would get used more then once ;)
    Boneyard51 likes this.
  24. Beanscoot
    Beanscoot
    If you are patient you can probably get good old NOS reamers at a good price on the auction site. Avoid used ones unless you can see them in hand because most will be dulled to the point of being unusable.
    I tried to order some replacement blades for Cleveland adjustable reamers a couple years ago with no luck, Cleveland may have stopped making them.
  25. Graham08
    Graham08
    Atwater Mike likes this.
  26. Mic your pins and I'll mic my reamer and if it's the right one I'll mail to to you and you can mail it back.....It's not adjustable.....I used it on my '55 years ago...
  27. porkshop
    porkshop
    from Clovis Ca
    Now thats team work. Good job Mike.....
    gggholson and loudbang like this.
  28. Boneyard51
    Boneyard51
    Chris, a quick search of the dreaded auction site , I found a guy selling a whole set of adjustable reamers , individually, for 19.99 apiece. Old, but never used. Had both your sizes still available. Might check there. Forty bucks, plus shipping... problem solved.
    Contact Seller twojs .
    Bones
  29. I have a kingpin bushing reamer but it is .861 so obviously the bushing hole is a little larger than the axle hole. I also have one for the .812 and would give them to you for the postage, but don't know if it would help in your particular situation. PM if interested.
  30. Chris
    Chris
    Thanks guys. I found an adjustable reamer at Granger here in town for 35.00 that goes .8438-.9375. I'll spend the big bucks on the early Ford version beings it would get used a heck of a lot more. So I ran out and grabbed it. I also picked up a digital caliper and guess what...these king pins are .010 over, (.8695) explaining my issue. I am glad @oldtom69 mentioned it, I know oversized king pins are made but I just didn't think about it last night. So, I will ream the bores and it should be like new again. Thank you everyone for the help, I truly appreciate it. Like Gene Winfield says: "every day is a school day"
