1952-59 Ford Hope this is the right place to ask this
Discussion in 'Off Topic Hot Rods & Customs' started by sgtpontiac, Mar 5, 2019.
  1. sgtpontiac
    sgtpontiac
    from Michigan
    Wanted to know if anyone has ever tried to use a 55/56 Customline headlamp door/bezel on a 53 Ford customline... they look a bit cooler and without a 55/56 bezel to try I figured I'd ask the experts...I'm pretty sure they are pot metal so fabrication short of using the entire area of the fender surrounding the headlamp is probably not an option... Anyone tried it? Thanks Sarge
  2. Paul2748
    Paul2748
    They will not fit without modifications
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. sgtpontiac
    sgtpontiac
    from Michigan
    Thanks for that link... there is a lot of info available.... figured there would be some fab work but that part doesn't keep me from giving it a try... Thanks again...Sarge
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    I liked how this one turned out :D 1firewall.JPG
