1954 ford wagon rear end swap question
Discussion in 'The Hokey Ass Message Board' started by 51chieftain, May 24, 2012.
  1. 51chieftain
    51chieftain
    I will be swapping my stock Dana 44 out of my '54 wagon. It needs a rebuild and I think it will be cheaper to swap it for something else.
    A quick look on Craigslist found me 2 options close to home.
    1 is a Ford 8.8 out of a '91 Ranger. this has 5 lug axles and should be plenty strong ( 302, t-5 ) but i'm not sure of the width
    the other is 2 hours away and is a Ford 9" out of a '65 Thunderbird.
    Does anyone know the width of the stock '54 Dana 44, backing plate to backing plate? and also the spring perch width? I took a quick measure and got @ 51 for the axle width and about 41.5" for the perches, center to center.
    I think the thunderbird is 43" perch to perch and I'm not sure of the overall axle width. I don't have the specs for the 8.8 Ranger rear.
    I'm hoping to find some advice here on what may be the best setup for my wagon.
    Thank you!
    Mike
  2. Squablow
    Squablow
    57-59 Ford p***enger car is a 9" that pretty much bolts right in, perfect width. My '53 has one from a '70 Mach 1, works nice but is probably an inch wider than the original rear. '65 T-bird rear is probably going to be way too wide.
  3. corn field kid
    corn field kid
    A 9 inch 57 car rear end or 8 inch Maverick is probably your best bet. 57 rear is 57 3/4 inches wide from wheel flang to wheel flang. Maverick is 56 3/4 inches from wheel flang to wheel flang.
  4. Deuce Roadster
    Deuce Roadster
    :confused:
    My choice would be the 57/58/59 Ford rear end. Vastly better selection of gear ratios, strong and more available.
    I would TRY to get one from a station wagon ... because of the larger axle bearings.
    :D :D
  5. Oldmics
    Oldmics
    Got what you need in the cl***ified.
    Oldmics
  6. HOTRODPRIMER
    HOTRODPRIMER
    The 57 Ford is a great choice if you can find one,,I used a 66 Mustang under my '54 wagon which is basically the same width as the Maverick or Granada. HRP
  7. jt7282
    jt7282
    from Midland Tx
    I will be picking up a ‘59 rearend tomorrow. From a 59 Galaxie 500, I’m guessing 3.56 gears. Plan on swapping them out for 3.00 ring and pinion ASAP
  8. 6sally6
    6sally6
    Those 3.56:1 gears should get a "premo-price" when you go to sell'em! Nice ratio
    6sally6
