Hot Rods Model A body on ‘32 chassis WITH FENDERS- Help!
Discussion in 'The Hokey Ass Message Board' started by RiffRaffRoadster, Dec 24, 2018.
  1. big duece
    big duece
    from kansas
    That's cool, I only mentioned the vette style oil fill/pcv in case a guy wanted to use the "vette" valve covers without putting holes in them. The M/T valve covers with fit your era build too. images (1).jpg
    RiffRaffRoadster and Blues4U like this.
  2. pprather
    pprather
  3. Blues4U
    Blues4U
    from So Cal
    A 57 283 would take straight bolt pattern, right? He'd need adapters for those staggered bolt pattern covers.
    big duece likes this.
  4. big duece
    big duece
    from kansas
    Yea, that was a brain fart
    Sent from my SM-G900P using The H.A.M.B. mobile app
    RiffRaffRoadster likes this.
  5. pprather
    pprather
    Staggered bolt pattern was used until 59? All he needs to do is look at his current covers to see what is needed.
    Phil
    Stogy and RiffRaffRoadster like this.
  6. RiffRaffRoadster
    RiffRaffRoadster
    well - this
    Thanks Phil - seems pretty pricey, doesnt it?
  7. RiffRaffRoadster
    RiffRaffRoadster
    Stogy and jimgoetz like this.
  8. primed34
    primed34
    Fresh rebuilt 327 would oil foul a set of plugs in less than 100 miles. Put a vacuum gauge on the fill tube and it killed the engine. For sure a WTF moment. Old stock racer said remove the pcv stuff and block that off. Never oil fouled another plug. Ran the car for years like that. Just put a sock over the vented oil vent cap. You don't have to run a pcv as long as the engine is vented in someway but it's cleaner to have one.
    jimgoetz and RiffRaffRoadster like this.
  9. RiffRaffRoadster
    RiffRaffRoadster
    The old Cragar steering wheel polished up pretty well, but the original windshield frame is not looking good. Heavily pitted. Advice: have it re-chromed, buy a new one, or live with it?
    brad2v, dwollam, ClarkH and 7 others like this.
  10. tb33anda3rd
    tb33anda3rd
    if it gets rechromed, remember every time you make something look perfect, the parts that looked ok, before, will look shabby...........it is a fine line. uniformity is the goal, doing it cost effectively is the trick.
  11. alchemy
    alchemy
    Personally I'd just polish and clean everything you have, chrome, upholstery, etc. Do the mechanical rebuild and paint the body for now. You can always unbolt and replate parts later.
  12. goldmountain
    goldmountain
  13. jimgoetz
    jimgoetz
    What Alchemy said.
  14. RiffRaffRoadster
    RiffRaffRoadster
    OK - I'll polish it up as best I can, but I better not hear any of you refer to my car as a 'Rat Rod'!
  15. goldmountain
    goldmountain
    Since you are working on the windshield frame, may I suggest you dig out your hacksaw?
    Sent from my SM-T350 using The H.A.M.B. mobile app
  16. RiffRaffRoadster
    RiffRaffRoadster
    I'm****uming you mean I should chop it. I was considering chopping it slightly and leaning it back a little. There will be some that will say leave it stock. we'll see...
  17. jimgoetz
    jimgoetz
    My T windshield was chopped when I got it. When I got to the point of fitting it on the car It just didn't look right to me. I ended up chopping it just about 1 more inch. It was a lot of work for something that most people wouldn't even notice but to me it made it just right. Make yourself happy.
  18. jimgoetz
    jimgoetz
    I don't think there's much chance of that.
  19. hotrodlane
    hotrodlane
    I only read the first few pages of this thread so I do not know what has been done to it or what the plans are for it, It was very hard to read any further after seeing it with the 20" rubberband tires on it. But all I know to say is WOW! this roadster brings back so many memories for me on How we used to build them. Those so called "Rally wheels" as the OP called them were very popular back in the late 60's early 70's The Chrome steel slot mags are still one of my favorite. And I had them on my 32 as well. I have to say There is No way in this entire world I would have taken that car apart! and if I did it would only be to repair something broken. True 60's and 70's built Street rods don't show up like this very often anymore. At this point it can never be as pure and as Cool as it is in this Pic. Goodluck with it and I hope it turns out the way you want it to. badass 31 roadster.jpg
  20. RiffRaffRoadster
    RiffRaffRoadster
    Yes-I regret it now, but it will go back together just fine and be the same car only better.
    dwollam, Tim, scott27 and 3 others like this.
  21. pprather
    pprather
  22. RiffRaffRoadster
    RiffRaffRoadster
    Thanks Prather-we went in a different direction with the center cross member. The car has some home-built square tubing cross members from the ‘50s/‘60s build, so we tried to match this style with the center cross member. I’ll pass on some photos this week.
    dwollam, Blues4U, jimgoetz and 2 others like this.
  23. RiffRaffRoadster
    RiffRaffRoadster
    Some updates - Will, the builder, has been busy stiffening the frame with a tubular steel cross member...
    brad2v, RICH B, Stogy and 11 others like this.
  24. RiffRaffRoadster
    RiffRaffRoadster
    got the rear axle back from axle shop (gears were in bad shape) - all new gears and added a 'posi-track' unit...
    brad2v, catdad49, Torkwrench and 11 others like this.
  25. Looks like you got to a major turning point. It's all forward now eh?
    Stogy, jimgoetz and RiffRaffRoadster like this.
  26. Dick Stevens
    Dick Stevens
    Great to see it moving forward, the work he is doing looks good!
    Stogy, loudbang and RiffRaffRoadster like this.
  27. RiffRaffRoadster
    RiffRaffRoadster
    Yes - we should have a rolling chassis soon. Work on the body is going well. Million little decisions to make, though.
    dwollam, slv63, Stogy and 1 other person like this.
  28. RiffRaffRoadster
    RiffRaffRoadster
    the square tubing on new x-member matches what the original work on chassis looked like. Will said this stiffened up the frame significanlty after he welded it in.
    dwollam, Stogy, Shadow Creek and 2 others like this.
  29. alchemy
    alchemy
    I think that will significantly stiffen the frame and you will enjoy a much quieter and easier to drive car. What was the final decision on the rear bars?
    dwollam, Stogy and RiffRaffRoadster like this.
  30. RiffRaffRoadster
    RiffRaffRoadster
    I’ve recommended that he move the rear bars inward towards center line based on some observations here. I think he’s on board. Still looking at it.
    dwollam, jimgoetz, Stogy and 2 others like this.
